My Simgot EW300 started acting up out of nowhere, and now I’m trying to figure out if it’s a cable, fit, or driver issue. I’ve already tried basic troubleshooting, but the sound still doesn’t seem right. Looking for help with Simgot EW300 sound problems, possible fixes, and whether this is a common issue.
Start with channel balance.
Swap left and right earpieces at the cable. If the bad sound moves, it’s the cable or source. If it stays in the same earpiece, it’s the IEM.
Try a different source. Phone dongle, laptop, other DAC, whatever you have. A weak or dirty jack causes channel drop, crackle, thin bass.
Clean the nozzle and tip. Earwax blocks one side fast. Pull the tip off and check the mesh under a light. If the EW300 has a clogged filter, volume drops and treble gets weird.
Reseat the 2-pin cable. Simgot 2-pin fits tight, but one side sometimes sits a bit off. Push straight in. Don’t wiggle it like crazy.
Change tips. Bad seal kills bass and makes vocals sound off. If one ear seals worse, the whole tuning feels broken. Try a size up first.
Play a mono test track. Both sides should sound dead center. If center pulls left or right after cable swap and source swap, one driver might be goin bad.
Listen for buzz on low bass, like 40 to 80 Hz. If one side rattles there, driver issue is more likely.
If you already did all this and one side still sounds dull or quieter, I’d bet on a clogged filter or failing driver before fit. Cable is common too, but the swap test tells you fast.
I’d add one thing @nachtschatten didn’t really get into: pressure and moisture issues. A DD/hybrid IEM can sound “wrong” even when the cable and seal seem fine if the vent gets partially blocked or there’s condensation in the nozzle. That can make bass vanish, then come back, or make one side sound kinda hollow.
A few things I’d try:
- Let them sit somewhere dry for a few hours, tips off.
- Check the shell vents, not just the nozzle mesh. If a vent is blocked by skin oil or pocket lint, tuning gets wonky fast.
- Try them at very low volume first. If distortion only shows up when you turn it up, that points more to driver stress than fit.
- Gently tap the shell while music is paused. If one side sounds loose or “papery,” that’s not a great sign.
Also, slight disagree on fit being less likely. Fit can absolutely go weird “out of nowhere” if one tip got softer, torn, or just isn’t seating the same anymore. I’ve had that happen and thought my IEM was cooked lol.
If the problem is intermittent, I’d actually suspect connector tolerance before full driver failure. If it’s constant on one side, then yeah, driver or filter gets more likely. Sounds dumb, but try wearing them reversed too, just to rule out your ears playing tricks on you.
One angle I’d check that @nachtschatten didn’t really touch is source chain mismatch. The EW300 is easy to drive, so if it suddenly sounds thin, splashy, or channel-weird, sometimes the culprit is the dongle, amp output, or even software balance/EQ getting changed without you noticing.
Try this:
- Plug the EW300 into a totally different source, ideally straight from a phone, laptop, or another dongle.
- Turn off all EQ, spatial audio, Dolby, game mode stuff, and accessibility balance settings.
- Swap left/right at the source end if your cable allows it, not just at the ears. If the issue follows the side, that tells you more than reseating tips again.
- Compare with another IEM or headphone from the same source. If both sound off, it’s not the EW300.
- Play a slow sine sweep or mono vocal track. If one side jumps in volume only at certain frequencies, that smells more like a filter/driver problem than cable.
I’ll mildly disagree with the “intermittent usually means connector” idea, because intermittent can also be a partially clogged nozzle filter that shifts as you move. Not rare.
If you do end up replacing anything, the pros of the “” are readability and easy pairing in setups, but cons are basically none because there’s no actual product title there to evaluate.
For the Simgot EW300 specifically, pros: usually strong clarity, good value, easy to source cables/tips. Cons: fit sensitivity, nozzle/filter issues can mimic driver failure, and hybrid/DD sets can be annoying to diagnose when they go half-wonky instead of fully dead.
You focused on source chain mismatch. You alrady told them to try another source, disable DSP, swap left right at the source, A B with another IEM, and run a sweep. You noted clogged filters and fit quirks on EW300. One pros line looks incomplete.
Simpler path. Dry the IEMs. Remove tips, dont power. Put both shells in a sealed bag with fresh silica gel for 12 to 24 hours. Moisture in filters or vents gives thin highs, weird balance, and on off dropouts. After drying, test a mono pink noise recroding at low volume. If fixed, replace filters.
