How Do Ai Agents Work
I keep seeing people talk about AI agents, but I’m still confused about what they actually do and how they work in real situations. I tried reading a few articles, and most of them were either too technical or too vague. I need a simple explanation of how AI agents make decisions, use tools, and complete tasks so I can understand whether they’re useful for automation, business, or everyday work.
Think of an AI agent as a loop.
  1. It gets a goal.
  2. It looks at data.
  3. It picks an action.
  4. It checks the result.
  5. It repeats until done or blocked.
A plain chatbot stops at step 2 or 3. An agent keeps going.
Real example. You say, ‘Find me 3 cheap flights to Denver next weekend and put them in a spreadsheet.’
The agent might:
  1. Search flight sites.
  2. Compare prices and times.
  3. Filter bad options.
  4. Write rows into a sheet.
  5. Ask you if bag fees matter.
That feels ‘smart,’ but under the hood it is usually an LLM plus tools plus rules.
The parts are pretty simple:
  1. Brain, the LLM. Reads your prompt and decides next step.
  2. Tools. Web search, email, database, calendar, code runner, API calls.
  3. Memory. Stores your prefs or prior steps.
  4. Planner. Breaks a big task into smaller ones.
  5. Guardrails. Stops dumb stuff, like deleting files or spending money.
Why people hype them up. They reduce hand-holding. Instead of asking AI for one answer, you give it a job.
Why they fail. The model guesses. Tools return bad data. Steps drift. It loops. It misses edge cases. This is why many agents work fine in demos and then faceplant in messy real work.
Rule of thumb. If your task has clear steps, clear data, and a way to check results, an agent does ok. If your task needs taste, judgment, or high stakes decisions, keep a human in the loop.
So yeah, an AI agent is not magic. It is a model doing task management with tool access. Sometimes useful. Sometimes kinda janky.
The simplest way I explain it: an AI agent is just AI that can keep working after the first reply.
A normal chatbot is like:
  • you ask
  • it answers
  • done
An agent is more like:
  • you ask
  • it answers a little
  • then it goes off and does stuff
  • then comes back
  • then maybe does more stuff based on what happened
Where I slightly disagree with @voyageurdubois is that people sometimes make agents sound more organized than they really are. A lot of them are not some elegant ‘planner’ system. Sometimes it’s basically a model, a few tool permissions, and a bunch of if/then logic held together with duct tape lol.
Real-world examples:
  • customer support agent that looks up orders, refunds, and shipping status
  • sales agent that reads leads, drafts emails, updates CRM
  • IT agent that checks alerts, restarts services, opens tickets
  • personal agent that books meetings, summarizes docs, reminds you about stuff
What makes it an ‘agent’ is not intelligence in some sci-fi sense. It’s autonomy. It can take multiple actions toward a goal without you manually prompting every single step.
Why people get confused is because marketing muddies it up. Some ‘agents’ are just chatbots with one extra button. Some are legit useful. Big difference.
Best test:
If it can observe, decide, act, and adjust, it’s probly an agent.
If it just answers once, it’s mostly just chat.
So yeah, less magic robot, more ‘LLM intern with app access.’ Useful sometimes, kinda messy often.
Think of an AI agent as a worker loop, not just a smart reply box.
What @voyageurdubois said about autonomy is basically right, but I’d add one thing: the important part is state. Agents usually remember what they were trying to do, what already happened, and what to try next. That is what makes them feel “active” instead of reactive.
A simple mental model:
  1. Goal
    “Refund this order” or “find 20 qualified leads”
  2. Inputs
    User message, database info, emails, calendar, tickets, APIs
  3. Reasoning
    Figure out the next best action
  4. Tool use
    Search, write to CRM, send email, call an API, update a record
  5. Check result
    Did it work, fail, or need clarification?
  6. Repeat
    Keep going until done or blocked
That loop is the real thing people mean by agent behavior.
Where I slightly disagree with the “LLM intern with app access” framing is that it can undersell the boring engineering part. In practice, the useful agents are often less about raw AI brilliance and more about guardrails, permissions, retries, logging, and handoff rules. The flashy demo is the easy part. The hard part is making sure it does not refund the wrong customer or spam the wrong lead list.
Real situations where agents actually help:
  • triaging support tickets and routing edge cases to humans
  • pulling data from 3 systems and producing one answer
  • monitoring workflows and taking the first recovery step
  • doing repetitive back office tasks with approval gates
Pros for ‘’:
  • can reduce manual clicking and context switching
  • works well for repetitive multi-step tasks
  • can operate across tools faster than a person
Cons for ‘’:
  • error handling matters a lot
  • permissions can get risky fast
  • “autonomous” often still needs supervision
My test is slightly different from @voyageurdubois:
If it has a goal, memory, tool access, and a feedback loop, it is probably an agent.
If it just generates text, even cleverly, it is still mostly a chatbot wearing a hard hat.
