I’m trying to permanently delete my Cash App account, not just log out or uninstall the app. I’ve already moved my remaining balance to my bank, but I’m worried there might still be linked bank info, payment history, or personal data stored on their servers. Can someone walk me through the correct steps to completely close and delete the account, and anything I should do first (like exporting records or canceling subscriptions) so I don’t run into problems later with charges or tax records?
Here is the full delete process for Cash App, not logout, not uninstall.
Make sure your balance is zero
• You said you moved it to your bank, good.
• Check for pending deposits or refunds. Cancel or wait for those to finish. -
Cash out and remove linked stuff
• In Cash App, tap your profile icon (top right).
• Tap “Linked Banks”.
• Remove your bank and any cards.
• If you used a Cash Card, stop using the physical card. Cut it up. -
Download your account history first
If you care about records, do this before you delete.
• Use a browser, go to cash.app and log in.
• Go to Settings.
• Look for something like “Statements” or “Export CSV” under “Documents” or “Account & Settings”.
• Download your transaction history.
This gives you a local copy if you ever need proof of payments, disputes, taxes, etc. -
Deactivate / close account in the app
On the app:
• Tap profile icon.
• Tap “Support”.
• Tap “Something Else”.
• Find “Account Settings”.
• Tap “Close your Cash App account” or “Delete your account”.
• Follow the prompts, they might ask to confirm via SMS or email. -
Confirm the account is gone
• After closing, the app logs you out.
• Try logging back in with your old number or email.
• If it says no account exists, you are done.
If it still logs you in, repeat the close process or contact support. -
Contact Cash App support if you are paranoid about data
Official policy, from their help pages, says they keep some data for legal and regulatory reasons.
This includes things like:
• Transaction records.
• Identity info used for KYC (name, SSN last 4, etc).
• Info needed for fraud monitoring and compliance.
They do not fully wipe every trace from their internal systems, same as banks and most fintech services.
You can still:
• Go to Settings in browser or app.
• Use the “Support” option.
• Ask them to confirm your account is closed and no payment methods stay active.
• Ask for data handling details or request data access / deletion where law applies, like under CCPA or GDPR if you qualify. -
Extra privacy steps on your side
• Delete the app after the account is closed.
• If your card or bank username reused passwords, change those passwords.
• Check your email and SMS for phishing. Scammers target people that used Cash App before.
Quick reality check on your concerns:
• Linked bank info for transfers stops working once your account is closed, and once you remove them from “Linked Banks”.
• Payment history is no longer visible to you, but they log it internally like any financial service.
• No new payments or Cash Card charges from that account after closure.
So the max privacy you get is:
Zero balance, no linked banks or cards, account closed via the app, then verify by trying to log in and, if you want, by messaging support about closure and data handling.
Most of what @boswandelaar wrote is solid, but a few extra angles if you’re trying to be really done with Cash App:
Think about recurring stuff, not just balance & banks
Everyone mentions zeroing the balance and unlinking banks, but check for:- Subscriptions that were using your Cash Card number (streaming, apps, etc).
- Any friends / family who treat your $cashtag like an address on file.
Tell them you’re shutting it down so you don’t have random “where’d my payment go?” msgs later.
Email + phone cleanup
After you close the account in the app:- Search your email for “Cash App” and look for any open support tickets or verification emails that might give access routes.
- If you used a phone number you’re planning to give up, close the Cash App account first. Some people report weirdness when a new person gets their old number and tries to sign up. Not super common, but why risk the confusion.
Privacy / data angle (the part that kinda sucks)
Even when you “delete” the account, financial companies usually keep:- Transaction logs
- Identity verification info
- Regulatory / anti-fraud data
So no, your payment history is not truly gone from their servers. If that’s your biggest worry, go into their support and specifically request: - Confirmation that the account is closed and cannot be reactivated
- What data is retained and for how long
- Deletion or restriction of processing where you’re legally entitled (GDPR / CCPA stuff)
Do not expect “total wipe,” because that’s just not how regulated financial data works.
Check your bank / card side too
Even after unlinking in Cash App:- Look at your bank statement to make sure no “Cash App Authorization” or small test charges keep popping up.
- If anything weird keeps hitting, go nuclear and request a new card number from your bank. Mild hassle, but it 100% severs that connection.
Social / security fallout prevention
- If you used the same password on Cash App and somewhere else, change it everywhere.
- Turn on 2FA on your email and bank accounts. A lot of Cash App “issues” people complain about are actually email or phone hijacks, not Cash App itself.
- Watch out for follow‑up phishing: texts like “Reactivate your Cash App account” after you’ve closed it are almost certainly scams.
Reality check on “permanent”
Once you:- Remove linked banks/cards
- Export whatever history you care about
- Close the account from inside the app
- Verify you can’t log in again
…you’re basically at max user‑level deletion.
The rest is database retention that only they control. You can push via privacy laws, but you can’t force them to violate financial record‑keeping rules.
If your goal is “no money can move, nobody can charge me, nobody can send me anything, and I’m not using this again,” that’s achievable.
If your goal is “every trace deleted from Cash App’s internal systems forever,” that’s not really a thing for any fintech app right now, no matter what their marketing implies.
You already got the “how” from @sternenwanderer and @boswandelaar, so I’ll focus on the “aftercare” and where people usually mess up when they think their Cash App account is “gone.”
1. Assume Cash App keeps a shadow of your data
Both other replies are right that financial services have to retain records. Where I’ll push a bit further: do not rely on generic support replies like “we’ve deleted your data.” That usually just means “we closed your user-facing account.”
If you are in a GDPR / CCPA region, file a formal data request (access + deletion / restriction), not just a casual “please delete my data” ticket. Use the legal/privacy contact in their policy, not only in-app chat.
2. Lock down identity reuse, not just the app
After closing the account:
- Consider changing the email alias used only for Cash App, if you had one.
- If your phone number is tied to multiple money apps, tighten that: add SIM PIN, disable easy number porting where your carrier allows it. Most “Cash App hacks” start with phone or email compromise, not with the app itself.
3. Watch for data brokers, not just Cash App
Your activity might also flow to:
- Credit bureaus or fraud databases
- Behavioral / anti-fraud networks
You cannot fully stop this, but you can: - Periodically check your credit reports for accounts referencing Cash App or its bank partner.
- Opt out of data brokers where possible, especially if privacy is your main driver for deleting.
4. About “permanent” account reuse
People sometimes find that:
- Reusing the same phone/email later can create a new Cash App profile that looks like a “resurrected” account.
To avoid confusion, once you’ve closed the account and confirmed it is gone, treat that phone/email pairing as “burned” for Cash App. If you ever go back, use a different combo.
5. Where I slightly disagree with the others
They recommend fully removing linked banks before closing, which is good hygiene, but in some edge cases your bank link info will still be referenced internally for a while. That is normal.
The part that really matters is:
- Your bank or card must stop accepting new Cash App charges.
So on top of unlinking, set alerts in your banking app and be ready to request a new card number if any stray test or micro charge appears. That is your hard kill switch, not only the “Close account” button.
6. Pros & cons of going this “max privacy” route
- No new transfers, no active payment methods.
- Stronger control over identity reuse and phishing exposure.
- Better paper trail if you ever need to prove what you asked Cash App to do with your data.
Cons
- Some data remains for years due to regulations.
- You may need to juggle new cards, new email, or extra security steps.
- If you later regret deleting, you probably will not restore the old history or cashtag setup.
@sternenwanderer nailed the practical full-delete process, and @boswandelaar added solid risk-mitigation tips. Your next moves are more about legal & security clean‑up than more buttons to tap: formal privacy requests, watching your bank like a hawk, and tightening phone/email security so nothing related to that old Cash App account can be abused later.
