Need help setting up my new Apple Watch from scratch
I just got my first Apple Watch and I’m totally new to using one. I’m confused about the initial setup steps, pairing with my iPhone, and which settings I should turn on or off for things like notifications and fitness tracking. Could someone walk me through the best way to set up an Apple Watch for a smooth first-time experience, including any important tips or common mistakes to avoid?
Here is a clean setup flow from zero that usually works well.
  1. Pairing with iPhone
    • Charge both iPhone and Watch. Update iOS first in Settings > General > Software Update.
    • Press and hold the side button on the Watch until the Apple logo shows.
    • Put the Watch near your iPhone. A popup should appear on the iPhone. Tap Set Up for Me.
    • Use the iPhone camera to scan the swirling pattern on the Watch. If that fails, tap Pair Manually and follow the code steps.
    • Pick Set Up as New Apple Watch, not restore. That keeps things simple for a first watch.
  2. Basic choices during setup
    On the iPhone Watch app during setup:
    • Wrist preference: pick left or right. This affects orientation and Digital Crown.
    • Passcode: choose one, and enable Wrist Detection. This helps Apple Pay and locks the watch when off your wrist.
    • Apple Pay: you can skip for now and add later in Watch app > Wallet & Apple Pay.
    • Shared settings: allow it to share settings with iPhone for features like Do Not Disturb and Focus.
  3. Notifications (stop it from buzzing nonstop)
    On iPhone, open Watch app > Notifications:
    • For Messages: choose Mirror my iPhone if you like your current behavior. If it feels noisy later, switch to Custom and set alerts only from favorites.
    • Phone: keep on. This is one of the most useful parts.
    • Mail: set to Custom and limit to VIP or important accounts.
    • Social apps (Instagram, Facebook, TikTok, etc): I suggest off on the Watch. Keep these on the phone only.
    • Calendar, Reminders: keep on. Short, useful taps.
    Rule of thumb: if you would not stop to handle it in 5–10 seconds, turn it off on the Watch.
  4. Fitness and health setup
    On iPhone Health app and Watch app:
    • Open the Health app, tap your profile, set height, weight, age, sex. This helps calorie estimates.
    • On the Watch app > Workout:
  • Turn on Precision Start if you want manual Start for workouts.
  • Turn on Auto-pause for running and cycling if you stop often.
    • On Watch app > Privacy: enable Fitness Tracking and Heart Rate.
    • Open the Workout app on the Watch and start a quick Outdoor Walk, even for a few minutes, so the Watch begins tuning its calorie and heart rate estimates for you.
  1. Activity rings setup
    On the Watch, open the Activity app:
    • Set Move goal. If you are starting out, pick a lower number like 300–400 kcal. You can adjust later in the Activity app with a long press.
    • Stand and Exercise are fixed at 12 hours stand and 30 minutes exercise.
    Try to close the Exercise ring with brisk walks. You do not need a gym for that.
  2. Battery and display tweaks
    On the Watch, open Settings:
    • Display & Brightness:
  • Start with medium brightness.
  • Set Wake on Wrist Raise to on, but turn off Wake on Crown Up if it bothers you at night.
    • General > Background App Refresh: turn off for apps you do not care about, like random third-party ones that sync in the background.
    • If Always On is available on your model, decide based on battery. If battery feels weak, turn Always On off.
  1. Useful watch face setup
    Press and hold the watch face:
    • Swipe to pick a simple face like Modular, Infograph Modular, or Activity Digital.
    • Add complications you use often:
  • Top: Activity rings.
  • Corners: Weather, Calendar, Workout, Heart Rate.
  • Bottom: Battery or Timer.
    Keep one clean “work” face with minimal info and one “fitness” face with lots of data.
  1. Sleep and do not disturb
    On iPhone, Watch app > Sleep:
    • Set your sleep schedule if you want tracking.
    • On the Watch, open Settings > Sleep, turn on Sleep Mode.
    This dims the screen and cuts random alerts at night.
    You can also use Focus in iPhone settings to sync Do Not Disturb between phone and Watch.
  2. What to turn off at first
    Good starting cuts so it feels less overwhelming:
    • Turn off:
  • Social media alerts in Watch app > Notifications.
  • Email from non-important accounts.
  • Random app install: in Watch app > General, turn off Automatic App Install.
    This stops every iPhone app from dumping its watch version on you.
  1. A quick daily routine
    This keeps things simple and useful:
    • Morning: check Activity rings and weather on the watch face.
    • Daytime: quick replies to texts and calls if phone is not in your hand.
    • Workout: start one when you walk, run, or cycle so your stats are logged.
    • Night: use Sleep Mode or a Focus so it does not ping your wrist a lot.
If anything feels too noisy, long press alerts on the Watch and tap Deliver Quietly or Turn Off on Apple Watch. That one gesture fixes most annoyances fast.
I’ll come at this from a slightly different angle than @waldgeist, who gave a very “clean” setup. I’m more in the “set it up fast, then fix the annoying parts later” camp.
I’ll skip the step‑by‑step pairing part since that’s covered already, and focus on what actually matters once it’s paired.
1. During setup: what to skip on purpose
When the iPhone Watch app walks you through setup:
  • Skip Apple Pay on first run. Get used to the watch first. You can add cards later in Watch app → Wallet & Apple Pay.
  • Skip installing all apps if it asks. Choose Install later.
    Then go to Watch app → General → turn off Automatic App Install.
    Otherwise you’ll get 30 useless apps you never touch.
I kinda disagree with setting up “everything” right away. Less stuff at first = easier to live with.
2. Notifications: start almost empty, add only what earns its place
People usually do this backwards. They let everything notify them, then spend a week turning junk off.
I’d do:
  1. On your iPhone, open Watch app → Notifications.
  2. For the first few days:
    • Allow only:
      • Phone
      • Messages
      • Calendar
      • Reminders
    • Turn off / Don’t mirror:
      • Mail (all of it, at first)
      • Social media
      • Shopping & delivery apps
  3. After a day or two, ask yourself:
    “Did I actually need to know this on my wrist?”
    If yes, turn that app on. If no, keep it phone-only.
On the watch itself: when something annoying pops up, scroll down and tap “Mute for Today” or “Turn off on Apple Watch” from that notification. Fix it in the moment so you don’t have to hunt later.
3. Fitness & Activity: don’t let the rings bully you
The Activity rings are cool, but also kinda judgey.
  • On the watch, open Activity the first time and set:
    • Move goal to something easy, like 250–350 calories.
      Ignore the “suggested” goal if it seems high. You can change it later by pressing and holding on the Activity screen.
  • Don’t stress the Exercise ring at first. Quick walks totally count.
  • In the Workout app on the watch:
    • Scroll to a workout (Outdoor Walk, whatever), tap the three dots, and check the settings like alerts and auto pause.
    • I actually like turning on “Auto-pause” for walking too, so the stats don’t run while you stand at lights.
What I’d do in week 1:
Just start a workout whenever you go for a decent walk. Ignore pace, VO2 max, all the fancy stuff. Let the watch collect data; you can nerd out on it later if you want.
4. Settings that quietly make the watch feel way better
On the watch:
  • Settings → Sounds & Haptics
    • Turn the Alert Volume down a bit.
    • Leave Haptic Alerts on “Default” or “Prominent” if you miss taps.
  • Settings → Display & Brightness
    • Medium brightness is fine.
    • If your watch supports Always On, try it off at first. Turn it on later if you feel the battery can handle it.
  • Settings → General → Wake Screen
    • Keep Wake on Wrist Raise on.
    • I’d turn off “Wake on Crown Up” to avoid random wakeups.
Small thing that helps a ton: Silent Mode.
Swipe up for Control Center, tap the bell icon. I keep mine silent 90% of the time and just rely on haptics.
5. Sleep & night behavior
If you sleep with the watch:
  • On iPhone: Watch app → Sleep
    • Set a sleep schedule if you want tracking.
  • On the watch: Settings → Sleep
    • Turn on Sleep Mode so the screen stays dim and unbothered.
If that all feels like too much, bare minimum:
Use Do Not Disturb / Focus at night so your wrist is not buzzing at 2 a.m.
6. Watch face strategy that isn’t overwhelming
Instead of one “perfect” face, make two:
  1. Everyday face
    • Simple analog or digital.
    • Complications: Activity rings, Weather, Calendar, maybe Battery.
  2. Workout face
    • A data‑heavy face like Modular or Infograph Modular.
    • Add Workout, Heart Rate, maybe Music or Podcasts.
Press & hold the face to switch. This is nicer than stuffing everything into one cluttered screen.
7. First week “checklist” that actually helps
For your first week, this is enough:
  • Morning: raise wrist, glance at time + weather + rings.
  • During the day: answer calls / quick texts from the watch when your phone is buried.
  • Any time you go for a walk that’s >10–15 minutes: start an Outdoor Walk.
  • At night: swipe up, make sure Silent or Sleep / Do Not Disturb is on.
If something is annoying you, long-press the notification or open the app’s settings in the Watch app on your phone and kill it. The watch should feel like a helper, not a needy pet.
If you say what you mainly want it for (fitness, work stuff, staying off your phone, etc.), people here can suggest a more “tuned” setup just for that.
If @kakeru is “set it up clean” and @waldgeist is “set it up fast, fix later,” I’ll go with “set it up around your life.”
I’ll skip the basic pairing steps they already nailed and focus on how to make the watch feel like it belongs to you, not the other way around.
1. Decide the role of your Apple Watch first
Before toggling settings, answer this for yourself:
“What is this thing mainly for in my life right now?”
Pick one primary role to start:
  1. Fitness tracker
  2. Mini phone on the wrist
  3. Focus / productivity helper
  4. Health & mindfulness gadget
You can mix them later, but starting with one keeps the setup sane.
If you pick: Fitness tracker
Here I half‑disagree with both @kakeru and @waldgeist:
  • They’re right about not overwhelming yourself, but I’d turn ON more workout data from day 1, because old data is the most valuable later.
Do this:
  • In the Watch app on iPhone
    • Workout
      • Turn on:
        • Precision Start
        • Auto‑pause for running and cycling
        • Alerts for splits / pace if you think they will motivate rather than stress you
    • Privacy
      • Fitness Tracking: On
      • Heart Rate: On
  • On the watch
    • Open Workout once and scroll through the types so it suggests relevant ones in the future.
    • Try at least one Outdoor Walk and one Free training this week.
Why I differ a bit:
People often baby the watch “until they’re serious.” Then they regret having half‑baked data. Let the watch over‑collect. You can ignore what you do not care about.
If you pick: Mini phone on the wrist
Both other posts lean toward cutting notifications hard. I want to offer a middle path:
  • Mirror your iPhone for:
    • Phone
    • Messages
    • Calendar
  • Then add 1 or 2 “work critical” apps:
    • Example: Teams, Slack, or your main email account only.
Trick:
For email, instead of turning it off entirely, set VIPs in the Mail app on your iPhone, then on the Watch only notify for VIP. That gives you “boss / family break through” alerts without constant buzz.
And on the watch itself, master this move early:
  • When any notification annoys you
    • Scroll down on it
    • Tap “Turn off on Apple Watch”
Live tuning beats trying to guess all the right settings on day 1.
If you pick: Focus & productivity
Here’s where I actually disagree with both of them a bit: I think the most powerful feature for new users is Focus sync, not just Do Not Disturb.
On iPhone:
  1. Settings
  2. Focus
  3. Set up at least:
    • Work
    • Personal
    • Sleep
Then in each:
  • Allow calls from:
    • Favorites or specific groups
  • Allow only key apps: Calendar, Reminders, maybe Messages
Now in the Watch app:
  • General
    • Turn on “Mirror my iPhone” for Focus.
Result: switch to Work focus on your phone, and your watch automatically follows. This keeps the watch from becoming “phone 2.0 distraction edition.”
If you pick: Health & mindfulness
Do more than just Activity rings:
  • On iPhone:
    • Health app
      • Fill out your medical details.
      • Turn on:
        • Heart notifications (irregular rhythm, high/low rate if supported).
  • On Watch:
    • Install and pin:
      • Mindfulness app
      • Heart Rate
    • Mindfulness:
      • Turn OFF hourly reminders if they feel spammy.
      • Turn ON a single “wind down” reminder before bed.
This way your watch nudges you a few times when it matters, not all day.
2. Watch faces: one “noise” face, one “quiet” face
Instead of the common “work face” vs “fitness face” idea from the others, try:
  • Quiet face
    • Super minimal. Time, maybe date, that is it.
    • Use this when you do not want to be nagged.
  • Noise face
    • All your complications: Activity, Weather, Calendar, Workout, Heart Rate.
    • Use this during active / busy parts of the day.
Press and hold on the face to switch. Think of it like “wrist mode switch” for your brain.
3. Battery strategy from day 1
Nobody talks about this early enough.
Instead of turning everything off to chase battery, do this:
  • Use the watch normally for 2 or 3 days.
  • At the end of day 3, check:
    • Settings
    • Battery
    • Battery Health & usage pattern
If you are ending your days below 20% regularly:
  • Turn off:
    • Always On display (if your model has it)
    • Background App Refresh for any app you do not use daily
    • Reduce motion if you like a snappier, simpler feel
I disagree slightly with turning Always On off by default. Many people like the “real watch” feel. I say: try it ON first. If your battery is terrible, then turn it off.
4. How to “learn” the watch without reading a manual
For your first 3 to 5 days:
  • Whenever you ask “Can this thing do X?”
    • Press the Digital Crown
    • Scroll through apps slowly
    • Tap anything that looks related and see its settings.
Two gestures to practice until they are muscle memory:
  • Swipe up: Control Center
    • Silent Mode
    • Find iPhone
    • Battery
  • Swipe down: Notifications
    • Long press and mute / turn off right there.
You will learn faster from “situational poking around” than from a long tutorial.
5. Where @kakeru and @waldgeist fit into this
  • @kakeru gave a very structured starter kit. Great if you like checklists and a clean, minimal setup.
  • @waldgeist offered a quicker, “just get going and trim later” approach.
What I am adding is:
  • Start by choosing the role the watch plays for you.
  • Use faces and Focus modes as your main control surfaces.
  • Let the watch over‑collect activity data early. You can ignore it now and appreciate it later.
Pros of setting it up this way:
  • It feels like your tool, not a generic template.
  • Less chance of notification fatigue.
  • Better long‑term fitness and health data.
  • Easy to expand: you can add more roles later without resetting everything.
  • Takes a bit more thinking up front.
  • You might flip watch faces and Focus modes often until it becomes natural.
  • If you choose “mini phone” as your main role, you must be disciplined about trimming notifications or it will still get noisy.
If you post what you mainly want from the watch (like “I sit at a desk all day and just want to move more” or “I hate my phone but still need to be reachable”), people can help you dial-in a very specific setup from there.
