After unplugging my external hard drive, Windows now shows “The parameter is incorrect” when I try to open it. I need help figuring out how to access the drive without losing files and what safe fixes or data recovery steps to try first.
Don’t format it yet. That’s the big thing. Windows may keep pushing you toward formatting, but if the issue is file system corruption, your files may still be sitting there just fine.
I had this happen on an older WD external drive. Windows kept throwing 'The parameter is incorrect.' and I assumed the drive was dead. In my case, it wasn’t. The file system was messed up, but the data was still recoverable.
Before trying to repair anything, I’d do a few basic checks:
- Swap the USB cable.
- Try a different USB port.
- Plug the drive into another computer.
- Check Disk Management and see whether the drive shows up with the right capacity.
- Look at the SMART status using something like CrystalDiskInfo, or the SMART monitor in Disk Drill.
If SMART shows a bunch of reallocated sectors, pending sectors, or other serious warnings, I’d treat the drive like it’s failing. Don’t keep poking at it more than you have to.
If the drive is still detected, I’d recover the files first and worry about repairs later. CHKDSK can help with logical errors, but I wouldn’t run it right away unless the important stuff is already backed up or recovered. On a badly damaged file system, it can make recovery messier.
For recovery, Disk Drill has worked well for me in this kind of situation. It can sometimes read a drive even when Windows refuses to open it because of the “parameter is incorrect” error.
If the drive seems unstable, the safer route is to make a full disk image first. Then scan the image instead of the physical drive. That way you’re not putting as much stress on hardware that might already be on its way out. After that, run a Universal Scan, preview the files, and recover them to a different drive. Don’t recover files back onto the same problem drive.
The free Windows version lets you recover up to 100 MB, which is at least enough to confirm whether your files are showing up properly before paying for anything.
Once your files are safe, then I’d start trying fixes:
- If Windows still sees the file system, try CHKDSK with
chkdsk X: /r. - If the drive shows as RAW, or CHKDSK won’t run, try TestDisk. It’s not as beginner-friendly, but it has saved plenty of damaged partitions.
If you’ve already copied off everything important and those repair attempts don’t help, a quick format is usually the next thing to try. That rebuilds the file system and may clear the error if corruption was the cause.
But if the error comes back after formatting, I wouldn’t trust that drive anymore. At that point it’s probably not just a software problem.
Also, if the drive is clicking, disconnecting randomly, vanishing from Disk Management, or showing serious SMART warnings, skip the DIY stuff and contact a professional recovery service. With a physically failing drive, every extra power cycle can make things worse.
And yeah, this is the kind of thing that makes backups feel a lot less optional. External drives are useful, but they’re still hardware, and they can fail with almost no warning.
If the drive is disconnecting or taking forever to appear, stop testing it on Windows and don’t run CHKDSK yet. That error can be simple file system damage, but it can also be a flaky USB bridge or a drive that drops out mid-read. I agree with @mikeappsreviewer on recovering first, but I’d try removing one variable too: if it’s a 3.5’ external, check the power adapter, and if it’s an enclosure-style drive, try another enclosure or SATA-to-USB adapter if you can. Don’t “initialize,” don’t format, and don’t accept any Windows repair prompts until the important files are copied somewhere else. Disk Drill/TestDisk/etc. are fine tools, but none of them fix a dying connection, so make sure the hardware path is stable before scanning for hours.
Stop double-clicking the drive in Explorer if it keeps freezing or throwing the same error, because Windows will keep retrying reads and that can make a weak drive worse. A safer quick check is to see whether it shows the correct size in Disk Management, then try copying only the most important folders first from a recovery tool or from a Linux live USB, preferably read-only if you know how. I’d be careful with “scan and fix” even if Windows offers it, since that changes the file system before you know what is still recoverable. Disk Drill or similar is fine for seeing whether the folder tree is intact, but recover to another disk, not back to that external. If the drive disappears during copying, treat it as hardware trouble, not a Windows error.
