5 Calls App Review
I’ve been trying the 5 Calls app to get more involved in political action, but I’m not sure if I’m using it effectively or if there are better alternatives. Can anyone explain how it’s worked for them, what they like or dislike, and whether it’s actually making a difference? I’d really appreciate detailed feedback before I commit to using it long term.
I’ve used 5 Calls on and off for a few years. Here’s what worked and what felt weak for me.
How it works best
  1. Set a tiny goal
    Do 1 issue per day, not every issue.
    Each issue is like 3 to 5 calls.
    I usually pick 1 topic I care about, then call both senators and my rep. Done.
  2. Prep before you call
    Read the script once, then put it in your own words. Staffers hear the same script a lot.
    I keep this format:
    • “My name is [name]. I live in [city, ZIP].”
    • “I’m calling about [bill / issue].”
    • “I want Sen/Rep [Name] to [support / oppose] it.”
    • One short reason.
    • “Is the senator’s position decided yet”
  3. Track what you did
    The app lets you check off calls.
    That helps you stick with it for more than a week.
    I set a 10 minute block right after lunch. No notifications, I just open the app.
What I like
• Low friction. It gives you phone numbers, a script, and a summary. Less time doomscrolling, more time acting.
• Issues are time-sensitive, so you hit things when staff is tracking them.
• Easier for shy people. Having the script in front of you helps if you freeze.
What I do not like
• It sometimes lags on local issues. My city stuff never shows up, so I use it only for federal.
• Scripts feel a bit copy-paste. If you read them word for word, staff hears the same call 20 times.
• Hard to measure impact. Offices log calls, but you do not see stats in the app.
How to make it more effective
Use it as one piece of your routine, not your whole strategy. My mix looks like this:
• 5 Calls for quick federal calls.
• Email directly from my rep’s site for longer points.
• Attend one local meeting per month, like city council or school board.
• Join one org on the issue I care about, like ACLU, Sunrise, local tenants union, etc.
Alternatives to try
• Resistbot. Lets you text and turns messages into faxes or letters. Good if you hate phone calls.
• CallParty. Similar idea, with reminders and campaigns.
• Your reps’ own newsletters. Many send alerts when they take positions or ask for input.
• Local mutual aid or advocacy groups. Impact there feels clearer, and you meet people.
How I know it matters at least a bit
I interned in a congressional office in college. Staff logged every call as “for” or “against” an issue.
On hot bills, we got hundreds per day.
No single call flipped policy, but patterns shaped what the member mentioned in briefings and what they prioritized.
Your calls go into those counts.
Simple way to use 5 Calls well
• Pick 1 or 2 issues you care about most.
• Call the same offices consistently on those topics.
• Keep a short personal script in your Notes app.
• Treat it like brushing teeth. Small, regular, not heroic.
If you feel burned out, cut back to once or twice a week but keep the habit. The app works best as a long-term drip, not a one-week sprint.
I’ve used 5 Calls a decent amount too, and I’ll come at it from a slightly different angle than @sonhadordobosque.
For me it works best not as a daily habit app, but as a “spike” tool. I open it when:
  • there’s a specific bill I’m already following, or
  • something hits the news and I want to do more than rage-scroll.
So instead of “1 issue per day,” I bunch it: maybe 20 minutes once or twice a week when something matters to me. The streak mindset just stressed me out and made me feel like I was failing activism homework.
What I actually like about it
  • Triage: It surfaces what’s currently moving in Congress so I don’t have to dig through a million advocacy emails.
  • Clarity: Even if I don’t use their exact script, their summaries are a quick way to learn what’s going on. Half the time I open it just to understand an issue better.
  • Phone focus: The fact it’s only about calls keeps me from wandering off into social media “activism.”
What bugs me / where I disagree a bit
  • Over-focus on federal: That’s not just a limitation, it can give you a slightly warped sense of what “political action” is. State and local decisions often affect you more, and 5 Calls is pretty weak there.
  • “Any call is good” isn’t always true. If I don’t understand the bill well, I’d rather not call than read a script I don’t really stand behind. So I spend extra time fact-checking outside the app.
  • It still feels like “solo” action. You don’t see feedback, other callers, or results in any meaningful way. That can drain motivation over time.
How to make it feel more effective (different angle)
Instead of focusing on habit, I try to focus on leverage:
  1. Pick your leverage point
    • If your reps already agree with you, calls are more like “backup support” than persuasion. In that case, I focus my energy more on:
      • local boards, commissions, school boards
      • state legislature stuff (usually easier to move)
    • If your reps are on the fence or opposed, 5 Calls is better, because staff is actually counting yes/no.
  2. Use one call to trigger more action
    A single 10 minute burst for me sometimes looks like:
    • Open 5 Calls, pick one urgent issue
    • Call all 3 federal offices
    • Take 5 more minutes to:
      • text a friend who cares about that issue with a 1–2 sentence summary and numbers to call
      • drop a short post in whatever group chat / Discord / FB group you use
        That “small organizing” part does more than the extra 2 calls I might have made.
  3. Combine with state-level trackers
    This is where 5 Calls really needs help. I pair it with:
    • my state legislature’s bill tracker site
    • one or two local orgs that do email alerts on state bills
      Then I use 5 Calls for federal, and my own phone/email for state. The skill you build with 5 Calls (short, direct asks) translates perfectly.
Alternatives I’ve liked, but in different roles
  • Resistbot is great for when I am totally peopled-out and cannot handle a real human on the line. I don’t treat it as a “replacement,” more like a backup on high-anxiety days.
  • Local orgs’ “call days” are actually more motivating for me than any app. When 20 people are all hitting phones at the same time, you feel less like you’re yelling into a void.
  • Your reps’ town halls and office hours. Super underused. One question at a public event can have more impact than 10 scripted calls.
How to tell if you’re using 5 Calls “effectively”
Ask yourself these instead of just counting calls:
  • Can I explain the issue in my own words now?
  • Do I know my reps’ positions on my top 2–3 issues?
  • Have I turned at least one other person into a caller or emailer?
    If the answer is “yes” to even one or two of those, you’re already ahead of where most people are, regardless of what the app stats say.
If it starts to feel like busywork or guilt fuel, that’s your cue to:
  • use it only when there’s something you really care about
  • shift more energy to local / state or to an organization where you see concrete wins
TL;DR: 5 Calls is a solid tool, but it’s a hammer, not a whole toolbox. Use it in bursts around key fights, pair it with state/local stuff and at least one group, and ignore the idea that you need to be on it every single day to “count.”
