Can I Recover Deleted Files From Recycle Bin After A Restart?
I deleted some important files, emptied or changed the Recycle Bin, and then restarted my Windows PC before realizing I still need them. I’m trying to find the safest way to recover deleted files from the Recycle Bin after a restart without overwriting anything.
If you already emptied the Recycle Bin, don’t keep using that drive if the file matters. Deleted files often aren’t wiped immediately. Windows usually just removes the pointer to the file and treats that space as available again. Once something new gets written over it, recovery gets a lot harder or may not be possible.
First, check the Recycle Bin again just in case. Search for the filename, but also look for the folder it used to be in. If the file was deleted inside a folder, it may be easier to spot that way. If you find it, right-click it and choose Restore.
If it’s definitely gone from the Recycle Bin, look for a backup before trying recovery tools. Go to the folder where the file used to live, right-click the folder, and choose Restore previous versions. If there’s a version from before the deletion, open it and copy the file back out.
You can also get to File History here:
Control Panel > System and Security > File History > Restore personal files
Use the arrows to move through older backup dates, then restore the file you need if it shows up.
If you don’t have a backup, recovery software is the next option. A tool like Disk Drill can scan for deleted files that Windows no longer lists.
The important part is where you install and save things. Don’t install the recovery app on the drive you’re trying to recover from, and don’t recover the file back to that same drive. Use another drive if possible.
A typical recovery attempt looks like this:
Select the drive the file was deleted from.
Run the Search for lost data scan.
Preview the files it finds, if previews are available.
Choose the items you need.
Recover them to a different drive.
A deep scan may still find data even if the original name or folder path is gone. Preview helps, but don’t assume the file is good until you open the recovered copy and check it.
Disk Drill may include some free recovery on Windows, but that limit can change, so check the current allowance in the app or on the official site.
One more thing: if this was on an SSD, recovery can be hit or miss. Many SSDs use TRIM, which can clear deleted data blocks after deletion. If TRIM has already done that, recovery tools may not have anything usable to bring back.
Bottom line: stop using the drive, check backups, then scan from another drive and recover to another location. The less you write to the affected drive, the better your odds.
Don’t run disk cleanup, defrag/optimize, chkdsk, or start installing recovery apps onto the same drive where the deleted files were. Those are the kinds of “normal fixing” steps that can make this worse, because they create writes or move data around.
A restart by itself doesn’t mean the files are automatically gone. It just means Windows had another chance to write logs, updates, temp files, browser cache, thumbnails, and other junk to the drive. If the files were on a second drive, your odds may still be decent. If they were on your main C: drive, the restart may have lowered your chances, but it doesn’t make recovery pointless.
@mikeappsreviewer is right about checking backups first. I’d be extra cautious with the recovery tool step, though. If you use something like Disk Drill from the Microsoft Store, don’t install it to the same drive you’re trying to recover from if you can avoid it. If the lost files were on C:, it may be safer to stop using that PC, remove the drive and scan it from another computer, or boot from another drive if you know how. Recovering the files back to the original drive is another common mistake, since that can overwrite the very data you’re trying to save.
Set expectations too: after the Recycle Bin is emptied, you may get files back with missing names, wrong folders, or partial corruption. Previewing a file is useful, but the real test is opening the recovered copy from a different drive and checking that the contents are actually intact.
Don’t keep cloud sync running while you experiment, especially if the deleted files were in Desktop, Documents, Pictures, or another folder backed up by OneDrive. A lot of people think “Recycle Bin” only means the Windows bin, but if OneDrive, Dropbox, Google Drive, or similar was involved, there may be a second trash/recycle area online. Pause syncing first if you can, then check the web version of that service and its deleted files or version history.
I agree with @jeff that the restart itself is not the fatal part. The real problem is what got written afterward. But the cloud angle is worth checking before scanning the disk, because it is cleaner and doesn’t risk overwriting anything. If the file was synced, you might be able to restore the exact name and folder path from the cloud trash instead of getting a pile of nameless recovered fragments from a deep scan.
If you changed the Recycle Bin settings, like lowering its size or setting it to delete immediately, don’t assume that tells you what happened to every older file. Each drive has its own Recycle Bin behavior, and synced folders may have their own separate recovery path too. I’d check cloud trash, other devices that may still have a copy, email attachments, recent file lists, and app-specific autosave folders before running recovery software. If none of that turns up anything, then use a recovery tool from another drive and save the results somewhere else, as already mentioned.
If the files are genuinely important, treat the drive like evidence and make a copy of it before you do much else. Scanning the original drive over and over is usually less risky than writing to it, but it still keeps the machine running, and Windows can keep making background changes while you “just try one more thing.”
The cleaner approach is to shut the PC down, connect that drive to another computer, and make an image or clone of the affected drive to a separate disk. Then run recovery software against the image or cloned copy. That way, if the first recovery attempt is messy, you still have the original drive in the same condition instead of slowly burning through your chances.
This matters more for the C: drive than for a second storage drive. If the lost files were on D: or an external hard drive, you can often be less dramatic: unplug it, don’t save anything to it, and scan it from another machine. If they were on C:, every normal boot can create logs, updates, search index changes, browser cache, thumbnail files, and other junk in the same free space where your deleted files may be sitting.
Disk Drill or a similar recovery tool can be useful, but I would not make the first experiment on the only copy of the damaged situation if the files really matter. Scan from another drive, recover to another drive, and assume the recovered files may need sorting. Sometimes you get the folder names back. Sometimes you get a pile of “file000123.docx” type results and have to open them one by one.
For cheap and fast, check obvious duplicates first: sent email attachments, downloads folders, phone copies, USB sticks, recent document lists, and app temp/autorecovery folders. That can save hours. But if there is no backup and the file value is high, stop poking at Windows and either image the drive or hand it to a recovery shop. The restart did not automatically ruin everything, but continued normal use is what usually does.
