I recently switched from an iPhone to an Android phone and just realized I can’t find a FaceTime app in the Play Store. Most of my friends and family still use FaceTime on their iPhones, and I really need a simple way to join their calls or start video chats with them from my Android. Are there any legit methods, links, or workarounds that let Android users use FaceTime with iPhone users without a bunch of technical setup?
Short answer, no FaceTime app for Android, and you will not run FaceTime natively on your phone.
You still have a couple of workable options though:
Join FaceTime calls from Android
- Only iPhone, iPad, or Mac users start the call.
- Your friend opens FaceTime, taps “Create Link”, then shares that link with you by SMS, email, WhatsApp, whatever.
- You tap the link on your Android. It opens in Chrome.
- You type a name, hit Join, and wait for them to let you in.
- It runs in the browser, so no app for you, and quality depends on your connection and browser.
This only works when they remember to send a link. You cannot call them directly through FaceTime from Android.
Use a cross platform app for everyday stuff
If you want something you control from your side, use one of these with your friends and family:-
WhatsApp
• Works on iOS, Android, desktop.
• Video calls are stable.
• Uses phone numbers, so easy for non techy folks. -
Google Meet
• Built into Android and Gmail.
• iPhone users install the app or use a link in Safari.
• Good for bigger family calls. -
Zoom
• Better for big groups or scheduled calls.
• Overkill for quick one to one, but it works across everything. -
Signal
• More privacy focused.
• Smaller user base though.
What I would do
- Keep FaceTime links only for people who refuse to move off FaceTime.
- Set up one primary cross platform app with your close group.
- Get everyone to add you there and create a family or friends group chat so video is one tap away.
FaceTime on Android is browser only, invite only, and controlled from the Apple side, so for daily use you get better control with WhatsApp, Meet, or similar.
Short version: there’s no real FaceTime app for Android, and you’ll never get full, iPhone-style FaceTime control on Android. Apple keeps that walled off on purpose.
@codecrafter already covered the FaceTime-link-in-browser trick pretty well, so I won’t rehash the step‑by‑step. I’ll just add a few angles and alternatives from actually living this mixed iOS/Android life.
1. What FaceTime on Android really is (and isn’t)
- It’s basically a web guest experience.
- You can’t:
- start a FaceTime call
- see who’s “available”
- call people straight from your contacts
- You can only:
- join when an Apple user sends you a link
- use it in Chrome/Edge/etc
So if you need something “I can tap and just call my mom anytime,” this setup kinda sucks.
2. Why depending on FaceTime links gets annoying fast
This is where I slightly disagree with @codecrafter’s “keep FaceTime links for people who refuse to move” idea. In theory that sounds fine. In practice:
- They forget to send the link.
- You’re waiting, they’re waiting, both thinking the other should start it.
- It’s awkward to text “can you send me a FaceTime link again?” every single time.
If FaceTime is your primary way of seeing people, relying on links will drive you a little nuts.
3. What actually works long-term
The cleanest solution is to normalize one cross‑platform app with your core people and treat FaceTime as “Apple‑only bonus” they use with others.
Some real‑world patterns that work well:
“Default for everyone” app
Pick one and push for it:- WhatsApp if your crowd already texts internationally or likes simple number-based setup.
- Google Meet if they’re used to Gmail/Google Calendar already.
- Messenger if your entire family basically lives on Facebook.
The key is not having 5 different apps where nobody remembers where to call you.
Tie it to something they already do
- Have a family group chat in WhatsApp / Messenger and use the video button in that thread.
- Put it on the home screen for your less techy relatives and tell them “Tap this to video me, not FaceTime.”
One-on-one with stubborn iPhone folks
For that one person who absolutely lives in FaceTime:- Ask them to always start the call and treat you as the “Android guest.”
- Or set up a recurring cross-platform alternative:
- “Every Sunday at 5, I’ll call you on WhatsApp/Meet.”
Once it’s a ritual, the app matters way less.
4. Stuff that’s technically possible but not worth chasing
You might see sketchy “FaceTime for Android” clones or guides saying:
- Install iOS in a VM
- Use some random “FaceTime compatible” app
Skip that. Best case, it doesn’t really integrate with iPhone FaceTime. Worst case, you’re installing garbage.
5. What I’d personally do in your shoes
- Accept that real FaceTime control is gone on Android. That’s just the deal.
- Pick one cross‑platform app and tell people:
“For video calls with me, use X instead of FaceTime.”
- Keep the browser FaceTime join as a backup, not your main option.
It’s not as smooth as when everyone’s on iOS, but once your core group gets used to a single shared app, it’s honestly fine. The frustrating part is the transition, not the end state.
You basically have three layers to think about here: what you can do today with FaceTime, what will realistically keep your family happy, and what you should avoid wasting time on.
1. FaceTime reality check (building on what’s already said)
@codecrafter and @mikeappsreviewer nailed the core:
- No native FaceTime app on Android
- No way to start FaceTime calls yourself
- You are a “guest in the browser” only
Where I’ll push back slightly: treating FaceTime links as a regular thing is painful not just because people forget, but because it breaks the whole “just tap their name and call” habit you had on iOS. For non‑techy relatives, any extra step is usually a deal breaker.
So instead of thinking “How do I keep using FaceTime?” it’s more useful to think “How do I keep the experience similar?”
2. How to keep things simple for iPhone‑only relatives
Practical strategies that actually survive more than a week:
Alias yourself to a single icon for them
- Put one app on their home screen: WhatsApp, Messenger, or Google Meet.
- Rename it on their phone if needed (some launchers let you do this) to something like “Call [Your Name].”
- Result: for them it still feels like “tap one thing, see your face.”
Exploit what they already open a lot
- If your family lives in Facebook, Messenger video is often easier than teaching them anything else.
- If they live in WhatsApp, just use that.
- If they rely on Gmail / Calendar, Google Meet works naturally because invites and links land in places they already check.
Use FaceTime only as a fallback
- Reserve FaceTime links for rare or special cases, not daily calls.
- Otherwise you will end up constantly texting “Can you send me a link again?” and resenting it.
Here I agree with @mikeappsreviewer that you should have a cross‑platform “home base,” but I’d go further and say: stop encouraging FaceTime at all for those people once the alternative is set.
3. Things people try that are not worth it
You might see advice like:
- “Install an iOS emulator on Android”
- “Use some ‘FaceTime compatible’ app from the Play Store”
Skip all that.
There is no legal, stable way to run real FaceTime on Android. Any app promising “FaceTime for Android” is either clickbait, spyware risk, or just a basic generic video caller with a misleading name.
4. How to structure your contact life so it doesn’t get messy
Instead of juggling five different apps, do this:
- Pick one primary video app per group
- Family: maybe WhatsApp or Messenger.
- Friends: maybe WhatsApp, Signal, or Telegram.
- Tell them explicitly:
“If you want to video call me, use WhatsApp instead of FaceTime now.”
- Update your name/status where you can:
- WhatsApp “About”: “On Android now, use WhatsApp to video call.”
- Group description: “Use this group for video calls instead of FaceTime.”
This sounds bossy, but if you do not set a clear default, people will keep trying FaceTime first and be confused why it fails.
5. Brief note on products & tradeoffs
There is no actual “FaceTime for Android” product like the empty placeholder term you wrote (let’s call it the “FaceTime Android Companion” for discussion). If such a thing existed, here is how its pros and cons would realistically look:
Pros of a hypothetical “FaceTime Android Companion”
- Central place to receive and manage FaceTime links
- Could keep a list of Apple friends and their links or invite presets
- Might integrate with your contacts so you do not hunt through SMS or chats for old links
Cons of a hypothetical “FaceTime Android Companion”
- Still would not let you start FaceTime calls on your own
- Entirely dependent on Apple not breaking or blocking the workaround
- Another app to maintain that still gives you second‑class status compared with a simple WhatsApp or Meet call
- Privacy and security question marks if it is not from Apple
Compared with simply using WhatsApp, Google Meet, Zoom, Signal, or Messenger, this kind of middleman app would give you more complexity without fixing the root problem that Apple keeps FaceTime tightly controlled.
6. Where you go from here
Concrete plan that works in real life:
- Pick your main cross‑platform app.
- Message your close contacts:
“I switched to Android, so FaceTime doesn’t really work for me anymore. Can we use [App X] for video calls from now on?”
- Set up family/friends group chats and pin them.
- Teach the least techy person once, on their phone, where to tap to call you.
- Keep the browser FaceTime link trick only for that one relative who absolutely refuses to change.
You cannot replicate the iPhone‑style FaceTime experience on Android, but you can get something just as smooth if you commit to one alternative and push everyone there instead of trying to cling to FaceTime itself.
