Cursor Ai Review – Useful For Coding?
I’ve been testing Cursor AI to speed up my daily coding work, but I’m not sure if I’m using it effectively or if it’s even worth committing to long term. Sometimes it feels helpful for refactoring and debugging, other times it adds confusion or misses obvious issues. I’d really appreciate feedback from developers who use Cursor AI regularly: how do you integrate it into your workflow, what are its real strengths and weaknesses, and is it reliable enough for production-level code?
I’ve been using Cursor daily for about 4 months on TypeScript, Python and a bit of Go. Short version. It helps a lot if you change how you work. It feels useless if you treat it like a fancy autocomplete.
Here is what I learned.
  1. Where Cursor helps
  • Refactoring
    • Multi file refactors with the chat are solid.
    • Example: Renaming a core type across 20 files. Cursor proposed edits in seconds and got about 90 percent right. I reviewed the diff and fixed the rest.
    • Use short prompts like:
      • “Refactor this file to remove duplication with X.ts.”
      • “Extract these 3 functions into a new util and adjust imports.”
  • Debugging
    • Paste failing test output, select relevant code, then:
      • “Here is the test failure and relevant code. Explain the bug and propose a minimal fix.”
    • It often spots off by one errors, missing await, wrong prop names faster than I do.
  • Writing boring glue
    • API handlers.
    • DTOs and mappers.
    • Repetitive CRUD stuff.
    • Good use is: write one clean example yourself, then “generate the same pattern for these 5 more cases.”
  1. Where it wastes time
  • New greenfield features
    • If you let it design the feature, you spend more time fixing structure and naming.
    • Better flow:
      • You write the high level structure and interfaces.
      • Then ask it to fill in small pieces.
  • Complex domain logic
    • It guesses business rules wrong.
    • Use it to explain code or write tests, not to invent the logic.
  • Long vague prompts
    • If your prompt sounds like a product spec, the result is fluff.
    • Keep context tight. Small file ranges. Clear goal.
  1. How to set it up so it pays off
  • Good project context
    • Keep types and interfaces clean. Cursor relies on them.
    • Add clear docstrings or comments for key modules. It reads those.
  • Strong tests
    • The more tests you have, the more you can let it “go wild” and then run tests to catch its mistakes.
    • I often do:
      • “Write tests for this module, cover edge cases.”
      • Then run them, see what fails, adjust.
  1. Practical daily patterns
  • “TDD helper”
    • You write a failing test.
    • Then:
      • “Make this test pass without changing the test signature.”
    • Good for small utility functions and reducers.
  • “Review my change”
    • After you edit a file:
      • “Review this diff for bugs and missed cases. Suggest concrete fixes.”
    • It catches null checks, async issues, and performance footguns.
  • “Explain legacy”
    • Select weird old code:
      • “Explain what this does in 5 bullet points. Point out risks if I change it.”
    • Great when you inherit garbage.
  1. When it is worth paying long term
I think it is worth it if:
  • You spend most of your day in one large repo.
  • You write in languages and frameworks it handles well. TS, JS, Python, Go, React, Node all feel fine.
  • You are ok with reviewing every line it edits, like you review a junior dev PR.
I think it is not worth it if:
  • You only code a few hours a week.
  • You work on tiny scripts or one off stuff.
  • You expect it to write features from scratch while you lean back.
  1. How to tell if you are “using it well”
Some rough checks:
  • You often accept or slightly edit Cursor proposals, instead of rewriting them from scratch.
  • You ask it to operate on selected code or specific files, not the whole repo each time.
  • Your time goes to design and decisions, not to typing boilerplate.
If you want to test it more seriously, try this simple experiment for a week:
Day 1 to 2
  • Only use it for:
    • Explaining code.
    • Writing tests.
    • Small refactors in one file.
Day 3 to 5
  • Use it for:
    • Multi file rename or refactor.
    • Generating repetitive handlers or components from one example.
Compare your git diff size and review time to a week without it. If you see more completed work with no increase in bug rate, it is worth keeping. If you feel you spend more time correcting it than coding, turn it into a “helper for tests and refactors only” instead of a general coding buddy.
So, yeah, it feels hit or miss at first. Once you limit it to refactor, tests, glue code, and targeted debugging, it starts to pull its weight.
I’m in a similar spot as you: tried Cursor to see if it could be a real part of my daily toolbox instead of just “GPT in an editor.” Short version: it can be worth it long term, but only if it fits your actual workflow and personality, not just your stack.
A few points that slightly disagree with @sonhadordobosque and might help you decide:
  1. Greenfield features aren’t always a waste
    They said greenfield is where it wastes time. I’d say: it depends on the size.
  • For small to medium new features, I actually get value from:
    • Writing a short spec in a comment at the top of a file
    • Sketching bare-bones interfaces
    • Then asking Cursor:
      “Implement this feature inside these boundaries. Do not add new dependencies.”
      It still messes up business logic, but it’s great for scaffolding: routes, DTOs, basic validation, wiring things together. I just don’t trust it with the domain rules.
  1. Try it as a “code designer’s rubber duck,” not just a refactor bot
    Most people either use Cursor as:
  • Autocomplete on steroids, or
  • “Do stuff for me” bot.
    A middle ground that works for me:
  • I write the design: data flow, key types, comments describing invariants.
  • Then I ask Cursor questions like:
    “Given this design, what are 3 alternative ways to model this?”
    “Where are the likely failure points in this flow?”
    This is less about code gen and more about “second brain” for architecture. Surprisingly useful, especially on larger TS/Go codebases.
  1. Use it to enforce your style, not invent one
    Where it really paid off for me long term was style consistency:
  • I feed it a few examples of:
    • How we write error handling
    • How we structure services/controllers
    • How we name things
  • Then prompts like:
    “Rewrite this file to match the patterns used in X.ts and Y.ts. Keep behavior identical.”
    If you don’t enforce your own style, Cursor tends to drift and you end up with a franken-codebase.
  1. Turn it into a strict reviewer, not a co-author
    One underrated mode: treat Cursor as a linting reviewer with teeth.
  • After a chunk of work, ask:
    “Review this diff for:
    1. potential race conditions
    2. blocking I/O in hot paths
    3. missing input validation
      Answer only with concrete issues, no compliments.”
      You’ll get fewer “nice code!” fluff responses and more specific “here’s where you probably screwed up.” This saves me more time than having it generate code sometimes.
  1. When it definitely isn’t worth it long term
    Based on what you wrote, I’d say it’s not worth sticking with if:
  • You don’t like reading diffs carefully. Cursor is relentless about touching more code than you intended. If reviewing generated code annoys you, it will slowly drive you insane.
  • Your tasks are mostly small scripts, migrations, or random one-offs. Spinning up context for Cursor and sculpting prompts is slower than just typing.
  • You’re already fast at refactors and debugging and enjoy that part. Cursor mostly amplifies what you already do; it doesn’t magically fix a bad workflow.
  1. Simple test to see if it’s “worth committing”
    For 1 or 2 weeks, track very roughly:
  • How many hours per day coding
  • How often you:
    • Accept Cursor changes with small tweaks
    • Reject and rewrite from scratch
      If more than ~60–70% of its suggestions end up heavily rewritten, it’s not worth a subscription for you right now. If you’re mostly nudging and accepting, the value is likely there, even if it doesn’t always feel magical.
  1. One subtle “gotcha” people ignore
    Cursor can push you into over-engineering:
  • Because “asking for just one more helper” is easy
  • Because it can quickly generate patterns and abstractions
    If you notice your codebase getting more generic, layered, and abstract than it needs to be, that’s Cursor plus developer ego teaming up. I actually wrote in my notes:
“If I wouldn’t write this abstraction manually, I don’t let Cursor create it.”
So, if it feels hit or miss: that is normal. The deciding factor is not “Is Cursor good?” but “Does Cursor match how I like to work?” Try treating it more like:
  • Architecture sparring partner
  • Style enforcer
  • Paranoid reviewer
    …instead of just autocomplete or feature writer. If that still doesn’t move the needle in a couple weeks, you’re probably better off canceling and just using occasional external AI chat for explanations and quick snippets.
Cursor Ai Review – Useful For Coding? Short answer: “it depends” is doing a lot of work here.
You already noticed the split: it feels great for refactors / debugging, flaky for actual feature work. I’ll zoom in on different angles than what @sonhadordobosque covered.
Where Cursor shines that people underuse
1. Navigating & understanding unfamiliar code
If you’re in a big repo or legacy app:
  • Use ‘what’s the minimal set of files I need to read to change X?’ as a prompt over the current file + related modules.
  • Ask: “Trace how data flows from this handler to the DB. List only function names and files.”
This isn’t codegen, it’s orientation. You save brain cycles that usually go into grepping and tab-hopping. For a lot of day-to-day work, this is more valuable than autocomplete.
2. Automating boring cross-cutting changes
Not refactors in the “clean this file” sense, but repo-wide changes like:
  • “Migrate all fetch calls to a single HTTP client wrapper.”
  • “Update all instances of XLogger to YLogger and adjust options accordingly.”
You let Cursor propose the mechanical bits, then you review by pattern, not line by line. This is where it feels like a multiplier instead of a toy.
Where I disagree a bit with the “greenfield is meh” take
I actually like Cursor for prototyping throwaway greenfield:
  • Spikes, PoCs, “let’s see if this approach even compiles.”
  • Tiny internal tools or admin scripts that you don’t care to maintain for 5 years.
Here, I let it generate more than I’d tolerate in production. The value is in compressing the “is this approach viable?” phase into an afternoon. If it works, then I rewrite the important pieces more carefully.
If your day job includes lots of spike work or design validation, this matters. If you mostly polish stable code, then @sonhadordobosque’s caution holds more weight.
Subtle productivity killers to watch for
1. Context overkill
People load the entire repo, give a long prompt, then watch it hallucinate. Try the inverse:
Give it too little context first, then gradually expand until it stops guessing and starts grounding. If you constantly paste 10+ files, your “Cursor Ai Review – Useful For Coding?” answer will skew negative just from cognitive fatigue.
2. Chat tab addiction
If you live in the side chat instead of inline edits / diffs, you’ll start writing about code more than writing code. For actual delivery, inline edits + quick accepts/rejects beat giant natural-language conversations.
How to know if Cursor fits your personality, not just stack
Some personality markers where Cursor tends to pay off:
  • You like to annotate your code with comments, mini-specs, invariants. Cursor eats that up.
  • You naturally think in terms of “what pattern should I use here?” rather than “let’s just hack it in.”
  • You actually enjoy reviewing diffs and nitpicking details.
If you are:
  • Impatient with reviews
  • Happy to just brute-force a fix
  • Someone who prefers tiny, local edits
Then Cursor can become friction instead of leverage.
Very rough pros & cons for sticking with Cursor long term
  • Great at speeding up large, boring, mechanical changes.
  • Strong for understanding and navigating complex or unfamiliar codebases.
  • Can compress spike / PoC work so you validate ideas faster.
  • When guided with your comments and patterns, can keep your style consistent across many files.
Cons
  • Tends to over-edit and touch more code than necessary, which punishes you if you hate diff reviews.
  • Easy to drift into over-engineering or needless abstractions because “AI can make more layers.”
  • Needs deliberate prompting and context curation; if you’re lazy with setup, results feel random.
  • For small one-off scripts, trivial bugfixes, or already-familiar code, it can be slower than just typing.
Practical way to decide if it’s worth committing
Run a 1–2 week experiment with actual numbers:
  • Count features / fixes where Cursor saved >30% time vs you doing it solo.
  • Count times it sent you down a wrong path, or you scrapped its work entirely.
  • Pay attention to mental load: are you more drained after AI-heavy days or less?
If the net result is:
  • You ship more, feel less mentally burned out, and you’re mostly editing its work instead of rewriting, Cursor is likely worth keeping.
  • You’re spending lots of time “fixing” its help, getting annoyed at diffs, and still feel the need to mentally re-derive everything it does, then your answer to “Cursor Ai Review – Useful For Coding?” is probably “not for me, at least right now.”
@sonhadordobosque covered some nice “second brain” and reviewer patterns; if layering my points on top of those still doesn’t move the needle after a focused trial, you’re probably better off cancelling and using a generic chat model occasionally instead of baking Cursor into your daily workflow.
