It seems like VLC gets recommended by default, almost reflexively. But does the actual experience back that up, or is the reputation running on fumes at this point?
I’ve been using VLC media player as my primary video player for a few weeks to see how it holds up in everyday use. My library is mostly MKV and MP4 files, with a mix of H.264 and HEVC, often including multiple audio tracks and subtitles. I wanted to test how it behaves in real conditions, not just with a few sample clips.
Overall, it handled most formats without requiring any setup. But over time, a couple of recurring issues started to stand out.
How It Feels to Use
From the start, VLC feels more like a cross-platform utility than something designed specifically for one system. It works the same way regardless of where you install it, which is convenient, but it also shows in the interface.
The layout is simple and functional, but it does feel dated. Controls are easy to access, but not always intuitive when you need something more advanced. The settings menu exposes a lot of options, though navigating them can take some time if you’re not familiar with the structure.
It’s usable, but not particularly refined compared to more modern players.
Playback Controls & Format Handling
In daily use, VLC covers all the basics and more. I regularly used:
- Subtitle support (including external files and sync adjustments)
- Switching between multiple audio tracks
- Playback speed control
- Basic video adjustments
Format support is where VLC still stands out. It handled MKV, MP4, AVI, and MOV without asking for additional codecs. High-bitrate files and HEVC content generally open without issues.
For most files, playback starts quickly and runs smoothly. It’s easy to see why people describe it as a multipurpose player, it can handle local files and even stream from servers via DLNA without much effort.
Audio and Video Issues
The main problem I kept encountering was inconsistency during playback. In some cases, it doesn’t play audio, even though the file works fine elsewhere.
This happened often enough to notice, especially with more complex MKV files containing multiple audio tracks or unusual encoding setups.
Sometimes switching audio tracks fixed the issue. Other times I had to restart playback or reopen the file. There wasn’t always a clear pattern, which made it harder to troubleshoot.
I also tested VLC on CachyOS and ran into the same behavior there. That made me question whether I had misconfigured something, drivers, hardware acceleration, or output settings, but after trying different options, the issue still appeared occasionally.
The practical effect is similar every time: instead of just pressing play and watching, I end up checking settings or reloading the file.
Performance & Stability
Performance is generally solid, but not perfect.
- Most 1080p and 4K files played smoothly
- Seeking through large files was responsive
- Subtitles stayed in sync
However, there were occasional slowdowns with certain formats, and I’ve seen reports (and experienced once or twice) where VLC struggles with newer codecs like AV1 depending on the system.
On macOS, there are also occasional reports of crashes, which may be related to compatibility or configuration issues.
Considering Alternatives
Because of the playback inconsistencies, I tested a few alternatives.
With Elmedia Player, playback started with both audio and video more consistently in my tests. It supports similar formats but feels more predictable with multi-track files. It also includes additional audio controls like an equalizer and presents more options directly in the interface. The trade-off is that it follows a commercial model with a Pro version.
I also briefly compared it with QuickTime Player. It’s much more limited in format support and customization, but for standard MP4 or MOV files, playback—including audio—worked reliably. It’s a simple fallback rather than a full replacement.
Final Verdict
VLC Media Player still does a lot right. It supports a wide range of formats, works across platforms, and doesn’t require extra configuration to get started.
However, in daily use, the occasional issues with missing audio or video reduce confidence. If you’re working with simple files, it performs as expected. But with more complex media, especially MKV files with multiple tracks, reliability can vary.
If you’re experiencing the same problems, including on systems like CachyOS, it might not be something you’re doing wrong. It could simply be how VLC behaves with certain files or configurations. Testing an alternative player can help confirm that.
VLC earns its rep for one reason. It plays more files out of the box than almost anything free. For a lot of people, that is enough.
But no, it is not flawless. Your playback issues, subtitle bugs, and random perfomance dips are not some weird personal failure. I’ve seen the same pattern. VLC is great at broad support. It is weaker at consistency.
I differ a bit from @mikeappsreviewer on one point. I think VLC is still fine as a backup player, not a main one, if your library has mixed codecs, weird muxing, multiple audio tracks, or external subtitles. The moment your files get messy, VLC starts showing its age.
A practical way to judge it:
- Test the same file in VLC and Elmedia Player.
- Try one simple MP4, one HEVC MKV, one file with ASS subtitles.
- Seek around fast, switch audio tracks, toggle subtitles, resume playback.
If VLC fails on the same file more than once, stop troubleshooting for hours. Swap players. That saves time.
Elmedia Player has been smoother for me with subtitle rendering and multi-track files. Fewer odd starts. Less menu digging. If you want a VLC alternative for Mac, Elmedia Player is worth a look.
So, VLC is good. It is not magic. The hype is old, and your experiance matters more than the meme.
VLC is good, but people talk about it like it’s some untouchable holy relic of freeware, and that’s where I disagree.
What VLC does well is obvious. It opens almost anything, it’s free, and it exists on basically every platform. That alone keeps it relevant. So the hype didn’t come from nowhere. But “best free video player” and “best player for your actual daily use” are not always the same thing.
I mostly agree with @mikeappsreviewer and @waldgeist that VLC’s biggest weakness is consistency, but I’d push it a little further: the problem is not just age, it’s that VLC often feels like a toolbox first and a polished player second. If you have to keep wondering whether this file will stutter, whether subtitles will render right, or whether audio will vanish until you poke a setting, that matters more than theoretical format support.
Also, I think some people overrate VLC because it used to be the default answer for codec chaos. Back in the day, that was a huge deal. Now? A lot of players handle common formats pretty well, so VLC doesn’t automatically win just because it can brute-force open weird files.
If your issues are subtitle glitches and perfomance dips, I wouldn’t just assume “that’s normal.” That’s exactly the kind of thing that makes a player annoying over time. A video player is supposed to disappear and let you watch stuff. VLC sometimes makes itself part of the experience, and not in a fun way.
For Mac especially, I’d seriously look at Elmedia Player. Different angle from what @mikeappsreviewer mentioned: I think its bigger advantage is that it feels more focused in everyday use. Less fiddly, less “where is that setting again,” less random jank with subtitle styling. Not perfect either, but for a VLC alternative on Mac, it’s one of the few that actually feels like a step sideways or up instead of just a different flavor of compromise.
So yeah, VLC is really good at being universal. It is not automatically the best. If your real-world experience has been bad, you’re probly not missing something. The hype is just older than the current reality.
VLC is good, but I think people sometimes confuse “legendary” with “best right now.”
I agree with @waldgeist, @andarilhonoturno, and @mikeappsreviewer on the general point that VLC’s reputation comes from broad file support. Where I disagree a bit is this: for some users, that one strength still outweighs the rough edges. If you constantly open oddball files from different sources, VLC can still be the least annoying option overall.
But if your daily experience is subtitle glitches, laggy seeking, random audio weirdness, or UI friction, then no, you are not imagining it. VLC can feel dependable in theory and irritating in practice.
The real question is not “is VLC objectively good?” It is “does it disappear and let you watch stuff?” If the answer is no, switch.
For Mac, Elmedia Player is a sensible alternative.
Elmedia Player pros:
- cleaner everyday playback experience
- better subtitle handling in many real-world cases
- easier controls for audio tracks and playback options
- feels more Mac-native and less clunky
Elmedia Player cons:
- some features are locked behind paid upgrade
- not as universally known as VLC
- if you love deep tinkering, VLC still exposes more knobs
So my take: VLC is still worth keeping installed, just not worth defending like a sacred cow. If it keeps annoying you, move on and use Elmedia Player as your main player instead.
