How can I stop apps from constantly running in the background on Android?
Lately my Android phone has been slowing down, draining battery fast, and using more data than usual. When I check the settings, I see a bunch of apps always running in the background even when I’m not using them. I’ve tried force stopping and disabling a few, but they seem to restart on their own. Can someone walk me through the best way to properly stop or limit background apps without breaking important notifications or system features? I’d really like to improve performance and battery life while still keeping essential apps working.
You are seeing normal Android behavior, but some apps abuse it. Here is what helps in practice.
  1. Turn off background data for noisy apps
    Settings → Network & internet → Data usage → Mobile data usage
    Tap the app → Disable “Background data”.
    Do this for social apps, shopping apps, news apps. They ping servers a lot.
    You will still get data when you open them.
  2. Restrict battery for problem apps
    Settings → Battery → Battery usage → View all apps.
    Tap an app → choose “Restricted” or “Optimized” instead of “Unrestricted”.
    On Samsung
    Settings → Battery and device care → Battery → Background usage limits
    Enable “Put unused apps to sleep”.
    Add spammy apps to “Sleeping apps” or “Deep sleeping apps”.
  3. Stop auto start and autologin where possible
    Some vendors have an “Auto start” list under Settings → Apps or Special access.
    Turn off auto start for apps you do not need 24/7.
    Inside each app, disable “run at startup”, “keep me logged in”, “sync in background” if present.
  4. Turn off sync you do not need
    Settings → Passwords & accounts or Users & accounts.
    Tap each account → turn off sync for stuff you do not care about.
    Email and messaging need sync. Random promo or storage apps do not.
  5. Disable or uninstall junk
    Long press app → App info.
    If you never use it → Uninstall.
    If uninstall is not possible → Disable.
    Disabling stops it from running and removes it from the app drawer.
  6. Use “Developer options” background limits
    Enable Developer options
    Settings → About phone → tap Build number 7 times.
    Go back → System → Developer options.
    Find “Background process limit” → set to “Standard limit” or “At most 3 processes”.
    If you go too aggressive, apps reload more often and may feel laggy.
  7. Stop force closing everything
    Task killer apps and constant swipe-away in recents often hurt.
    Android keeps some apps in RAM without draining battery much.
    Heavy killing makes them restart and waste more battery and data.
  8. Check for bad actors
    Install an app like “SD Maid SE” or “DiskUsage” style tools for storage and cache checks.
    Use built in battery stats.
    If 1 or 2 apps sit at the top of battery and data all the time, replace them with lighter alternatives.
  9. Update system and apps
    Buggy versions leak battery and wakeups.
    Settings → System → System update.
    Play Store → Manage apps and device → Update all.
  10. Last resort options
    If your phone is old and bloated by years of installs, a backup plus factory reset often helps.
    If storage is almost full, free up space. Under 5 to 10 percent free space, things slow down hard.
If you share your phone model and Android version, you get more precise steps, since menus move around a bit between brands.
You’re not crazy, Android does look like it has “too many” apps running, but the fix is more about control than nuking everything.
@hoshikuzu covered the standard stuff really well (data limits, battery restriction, disabling junk, etc.), so I’ll skip repeating those and add a few angles that people usually miss:
1. Focus on wakeups, not just “running”
What really kills battery and data is how often apps wake your phone, not just sitting in RAM.
  • Go to Settings → Battery → Battery usage
    Check which apps are high under Background time, not just total.
  • If something like Facebook, TikTok, or a random shopping app has hours of background time, that’s the one to target hard.
RAM usage on its own is mostly harmless. Constant wakeups are the real villian here.
2. Turn off “draw over other apps” and special access
Some apps keep themselves alive by using special permissions.
Check: Settings → Apps → Special app access. Look at:
  • Display over other apps
  • Picture-in-picture
  • Modify system settings
  • Alarms & reminders
  • Install unknown apps
If a shady cleaner app, free VPN, or random keyboard is in there, remove those privileges. It keeps them from wriggling into the background so much.
3. Notifications = background work
If an app is spamming you with notifications, it’s also almost certainly waking in the background.
  • Long press a notification → Turn off notifications or customize.
  • Or go to Settings → Notifications → App notifications and shut off categories you don’t care about (promo, offers, trends, etc).
Sometimes killing 80% of notification noise equals killing 80% of dumb background activity.
4. Use “Data Saver” system-wide
This one actually works and people ignore it.
  • Settings → Network & internet → Data Saver → On
Then whitelist only the apps you actually need unlimited background access for (messages, email, maps maybe). Everything else will get heavily throttled in background, which also has a nice side effect of reducing their wakeups.
This does more than just toggling background data app by app, and plays nice with Android’s own logic.
5. Be careful with super-aggressive background limits
Here I’ll slightly disagree with going too wild on Developer Options like “at most 3 processes.”
Yeah, it stops background stuff, but:
  • Apps reload constantly.
  • Scrolling feels jerky.
  • Music / podcast / fitness apps may randomly die.
If you try it, treat it like a test, not a permanent setting. If your phone starts feeling worse, go back to Standard limit.
6. Replace heavy apps with lighter clients
Some apps are just pigs and no amount of “optimization” fixes them. Common offenders:
  • Official Facebook app
    → Try Facebook Lite or just use it in a browser with a home screen shortcut.
  • Twitter / X, TikTok clones, certain shopping apps (Shein, AliExpress, etc)
    → Use web versions or lighter alternatives where possible.
If one app is always at the top of battery & data charts, it’s usually faster to ditch it than fight it.
7. Watch out for “cleaner” and “booster” apps
If you installed any “RAM booster,” “phone cleaner,” “battery saver” app, uninstall it.
They often:
  • Constantly run in the background
  • Kill other apps so Android restarts them
  • Show ads while pretending to “optimize”
Android already does its own memory and battery management. Third-party boosters mostly just get in the way.
8. Check your launcher and keyboard
People never suspect these two, but they run all the time.
  • Try a different launcher if yours is ad-heavy, shows news feeds, or “smart suggestions”. Those need constant background activity.
  • Same for keyboards that push stickers, themes, and “trending GIFs” nonstop. Gboard or a simple keyboard is usually lighter than random theme-heavy ones.
9. Use Wi-Fi and Power Saving properly
  • When you know you’ll be on low battery: turn on Power saving mode instead of killing apps one by one. It auto-throttles background stuff globally.
  • Use Wi-Fi whenever you can. Some apps behave way more aggressively on mobile data because they constantly “check in” or load smaller but more frequent updates.
If you want more targeted advice, mention your phone brand + Android version. Samsung, Xiaomi, OnePlus etc all hide extra background-control menus in different places, and some of them are actually more effective than Android’s default tools.
Short version: stop fighting “background apps” in general and go after the few that are abusing the system. Android likes filling RAM; that is not the enemy.
Here are angles that complement what @hoshikuzu already laid out:
1. Use per‑app “foreground services” control
On newer Android versions:
  • Go to Settings → Apps → [problem app] → Battery
  • Look for something like Allow foreground services in background or Allow background activity
Turn that off for any app that should not be constantly “live” (shopping, social, crypto, cleaners). This hits those annoying “always running” notification apps.
Why this works: Foreground services are how apps stay pinned in memory with a permanent notification. Revoking that is more effective than just “Force stop.”
2. Stop abusive auto‑start & “run at boot”
Some vendors hide this in different spots:
  • Samsung: Settings → Apps → pick app → under “Mobile data / Battery,” disable “Allow background activity” and “Allow background data use” together so it does not revive on boot as aggressively.
  • Xiaomi / Oppo / Vivo type phones: look in Security / Permissions / Auto start and uncheck junk apps.
This is one of the few places I do not completely agree with relying only on Android’s automatic control. OEM tools are sometimes the only thing that really stops a misbehaving app from jumping up at every reboot.
3. Let Android’s own “App Standby” do the dirty work
Instead of manually killing stuff every time:
  1. Stop opening apps you rarely need “just to check.”
  2. Go to Settings → Battery → Battery usage
    Then tap the app → set it to Restricted or Optimized.
Once you stop touching it, Android’s App Standby buckets will push it into a “rarely used” state and severely limit background work. It is slower but more stable than ultra‑aggressive task killers.
4. Disable “instant sync” inside apps themselves
A lot of background activity comes from in‑app sync settings, not Android:
  • Email apps: set sync to 15 min / 30 min, or manual, instead of “Push” for non‑critical accounts.
  • Cloud backup / photo apps:
    Turn off auto backup over mobile data and restrict to Wi‑Fi & charging.
  • Social / shopping apps: kill settings like auto play video, preload feeds, auto refresh, live updates.
These cuts often save more battery than any system‑wide tweak because they remove scheduled jobs and push events.
5. Use a workflow instead of constant micromanaging
Instead of chasing background apps every day, set this pattern:
  1. Weekly check:
    Battery usage, data usage. If an app is consistently near the top in background usage and you do not need it always on, restrict it.
  2. Every new install:
    Open the app, go straight to its settings, turn off:
    • “Personalized ads,” “recommendations,” “news feed widgets”
    • Unnecessary notifications
    • Auto sync / auto play
Do this once and you rarely need to revisit.
6. About “phone cleaner / optimizer” type tools
@hoshikuzu already said uninstall them, and here I fully agree. They increase wakeups, run constant services and “optimize” by killing apps that Android will just spin up again, which wastes more power.
If you really want a tool, use the built‑in vendor one in the Settings / Device care section rather than a random store download. The built‑in ones at least respect system limits.
7. Quick checklist you can run through today
  • Restrict or uninstall any app that:
    • Frequently shows a permanent notification for no good reason
    • Uses hours of background time compared to foreground
    • Has its own “news / feed / promo” section inside the app
  • Turn on system Data Saver and Battery Saver when traveling or on low battery, instead of “closing all apps.”
As for the product title “”: there is effectively nothing to tweak or configure there since it is just mentioned as text, but here is how such a tool would typically stack up in this context:
Pros of “”:
  • Could centralize control over app background behavior if it exposed Android’s existing knobs in one screen
  • Might be useful for quickly reviewing which apps wake most often or consume data
Cons of “”:
  • If it behaves like many third‑party “cleaner / booster” apps, it can itself become another background hog
  • Duplicate features of what Android and your manufacturer already provide in Settings
  • Risk of over‑killing apps, which causes more restarts and sometimes worse performance
Given that, you are usually better off mastering the built‑in controls you already have before adding any extra layer.
If you share your phone model and Android version, you can get pointers to the exact hidden background‑control menus your brand uses, which is often where the real power is.
