I tried copying a folder of scanned sewing patterns from a hard drive a client sent me for a catalog job. The copy started fine, then sat on the same file long enough that I canceled it. How do I clone the drive so I can work from the copy and leave the original alone? I have an empty drive with more space than the client’s drive, and the original still shows up when I plug it in.
If those scans are the client’s only copy, unplug the drive and ask whether they want professional recovery before you try again. If they have a backup, ask them to send the patterns from that instead. A stalled copy doesn’t prove the drive is failing, but I wouldn’t keep retrying that file to find out.
If you go ahead, I’d use GNU ddrescue from a Linux live USB to make an image file on your empty drive. Use lsblk -o NAME,SIZE,MODEL,SERIAL,MOUNTPOINTS to identify both drives. Leave the client’s drive connected but unmount its partitions, and keep the empty drive mounted. Assuming the empty drive is mounted at /mnt/recovery, the first pass is sudo ddrescue -n /dev/sdX /mnt/recovery/client.img /mnt/recovery/client.map. Replace /dev/sdX with the client’s whole-drive device and verify the mount path before pressing Enter. The image holds the data. The map file records progress so you can resume without rereading what you’ve already copied.
Once that pass finishes, disconnect the original and open the image read-only. Copy the patterns you need into your job folder and check that the scans open all the way through, especially the one that stalled. If the image won’t mount, that’s when I’d look at hard drive repair software in the disk repair software guide and try recovery on a copy of the image, not on the client’s drive.
An empty drive the same size as the client’s can still be too small to hold the image file. A raw image covers the whole source disk, even if the patterns occupy only a tiny part of it. I’d use hard drive repair software in imaging mode and check the destination’s actual free space before starting. Leave room for the scans you’ll extract if they’re going on that drive too.
Ask the user to re-send the scans from the folder. If this is their only copy, inform them that the reads have stopped.
To clone, use drive recovery software with resume functionality and logging. Unfortunately, some of this software can be confusing to find resume options. Ensure that the disk isn’t mounted. Choose the disk as your source and save the image and log files to an undamaged disk. Set the number of retries to 0 to allow cloning to proceed on the rest of the folder without waiting for this file.
When the cloning completes, remove the original disk and open the image (in read only mode). Attempt to open the required scans. If these open successfully return the disk and attempt again.
All the contents of the drive will be cloned. As such, any file within the folder you were asked to copy could be included. Even any apparent free space may include partial data from deleted files.
Ask the client: “The copy got stuck on a scan. I can try making a temporary copy of the whole disk and pulling the patterns from that. Is that okay, or do you have another copy of the folder?” This means that you are asking them to allow this data to be copied, but are not (yet) telling them that their drive is dead.
Getting permission
If given permission, we would create an image file and store it on an encrypted drive locally. We would also not store the image file and progress file within the same folder as your catalogue project (especially if this project is synchronised with a common working area). If opened, make sure to open the image as read only. Within the project, we would add only the scans. This means that if we share the project folder with the designer, we are not sharing the entire clients drive.
Agreement on deletion
It may be best to get agreement on when to delete this image. If the source drive is unstable, it may be better to return the recovered contents to a different drive. It may be best to get agreement on this during conversation, rather than guessing after sending the catalogue.
