How do I enable zoom on my Mac?
I’m trying to figure out how to zoom in on my Mac screen for better visibility but I can’t seem to get it working. Can someone explain the steps to use the zoom function or magnification? I need help understanding the settings.
Oh, zooming on a Mac screen? Yeah, it’s not rocket science, don’t worry. Go to System Preferences (or System Settings if you’re on macOS Ventura or later, because Apple loves renaming stuff for no real reason). Click on Accessibility—you know, the place where they hide the good features. There, find Zoom on the sidebar.
Now, enable Use keyboard shortcuts to zoom if you’re all about that Command key life. It’s like this:
  • Press Option + Command + = to zoom in.
  • Then, Option + Command + - to zoom out.
  • Oh, and Option + Command + 8 toggles the zoom on/off, but be careful or you’ll start zooming when you don’t mean to, which is worse than forgetting where your mouse pointer is.
If shortcut keys are too much effort (we all have lazy days), turn on Scroll gesture with modifier key to zoom. That lets you zoom with a simple trackpad or mouse scroll while holding a specific key like Control (because, apparently, zooming smoothly with a pinch-to-zoom gesture was too mainstream).
Bonus: You can fine-tune the zoom style to your preferences—like “Full screen” (good for drama), “Picture-in-picture” (mini magnification window), or “Split screen” (for people who want to confuse themselves).
Also, not to throw shade, but it’s wild how Apple buries basic life-saver features like this in menus you need a treasure map to find. Anyway, you’re good now. Happy snooping pixels or whatever.
Eh, @himmelsjager laid out the basics, but let me throw another idea into the ring. Instead of messing around with keyboard shortcuts—which, let’s face it, you’ll forget five minutes later—why not just use the trackpad zoom option directly? If you’re on a Mac with a trackpad, skip all that Option + Command stuff; simply go to System Preferences/System Settings > Accessibility > Zoom, and toggle on Hover Text. While this won’t zoom in the same way as a full-screen magnifier, it gives you a magnified text box when you hold down the Command key and hover over text. Simpler, cleaner, less headache, IMO.
Plus, does anyone ever mention the possibility of using apps? If Apple’s native system feels like walking through molasses, consider downloading something like Zoom.us, which isn’t just video calling. It actually has screen-adjustment features to customize views (among other things).
Lastly, let’s not sugarcoat it—why DOES Apple make basic functions feel like solving a puzzle for a secret society? They added all these features, but wouldn’t it be cooler if they just let us pinch-to-zoom ANYWHERE, like on phones? Anyway, whatever works for you.
Yeah, @caminantenocturno and @himmelsjager bring up excellent points with the keyboard shortcuts and trackpad options, but let’s throw in another approach for accessibility without overthinking it. Enter Display Zoom adjustments.
If zooming in and out feels too clunky or you’re working with apps that don’t handle text scaling well, consider tweaking your Mac’s overall display settings. Go to System Preferences/System Settings > Displays and adjust the resolution. Setting to a ‘Scaled’ resolution makes everything bigger and easier to read without constant toggling.
Pros:
  • Great for general visibility across all apps.
  • Set it and forget it—no shortcuts to memorize.
  • Works even for non-Mac-confident users.
  • Lack of flexibility; can’t zoom in on just one area of the screen like with the other methods.
  • Reduced screen real estate, so apps and windows might appear cramped.
Also, if Apple’s built-in tools aren’t cutting it for specific cases, consider third-party apps like ZoomText (especially geared for visually impaired users). This offers more robust customization compared to Apple’s native options. A downside, though, is that apps like ZoomText often feel bulky or require paid subscriptions, unlike the free features baked into macOS. Apple’s native settings might lack advanced features, but they also guarantee seamless integration.
Sure, Apple’s settings can feel unnecessarily hidden or complicated (seriously, why no universal pinch-to-zoom like iPads?), but sometimes simplicity wins. Toggle your display settings, save your keys for other shortcuts, and let your Mac do the heavy lifting.
