I’m trying to recover photos and video files from a CompactFlash card after several folders suddenly disappeared. The card still shows used space, but the missing folders and files won’t appear on my camera or computer. These files are important, and I need help figuring out the safest way to recover data from the CF card without making the problem worse.
CF card went unreadable? What I’d do first
Yeah, I’ve had this happen after a shoot. You get home, plug in the reader, and the card throws errors or half the folder is gone. Feels bad fast. Still, if the CompactFlash card isn’t physically wrecked, your photos and video often still sit on the card. What’s broken is usually the file map, not the data itself.
So the first few minutes matter more than the software.
Do these three things now
Stop using the card.
Pull it from the camera. Don’t shoot more frames. Don’t test it by copying random files over. Every write raises the chance your old data gets replaced. -
Refuse the format prompt.
Windows and macOS like to pop up a message saying the card needs formatting. Don’t accept it. A format rewrites file system info and makes recovery messier. -
Use a real CF card reader.
I would skip connecting the camera over USB. In my experience, direct camera connections often hide the low-level disk access recovery tools need. A dedicated reader works better.
Check whether the computer sees the card
On Windows, open Disk Management. On Mac, open Disk Utility.
If the CF card appears there with about the right capacity, you still have a decent shot at doing this yourself. If it does not appear at all, or the card took physical damage, you’re getting into lab-recovery territory. One example is the CleverFiles recovery center.
For software, this YouTube link was included, so here it is as-is:
About recovery software
I’ve tried a few over time. The free route exists, but it gets annoying quick.
PhotoRec does find files, sure, but the workflow is rough. It spits recovered items into big piles and your original names are gone. If you shot a long event, sorting that mess is no fun. Recuva is easier, though I’ve seen it miss or mishandle RAW formats from pro cameras.
The one linked in the original post is Disk Drill. The useful part for me is file preview before recovery. If you’re staring at CR2, NEF, ARW, or large video clips, preview saves time and cuts down on blind restores.
The recovery steps I’d follow
1. Install the recovery app on your computer drive
Put it on your internal drive, not on the CF card. Sounds obvious, but people slip here when stressed.
2. Make a byte-for-byte image first if the card looks unstable
This matters more than most people think. If the card disconnects, freezes, or reads slow, clone it first and work from the image. Disk Drill includes imaging for this. A full image gives you one stable source instead of hammering a card that’s already acting weird.
3. Scan the card, or the image
Run the full scan and let it finish. Don’t stop halfway because the first results look empty. Some tools find the easy stuff early and the buried stuff later.
4. Preview before restoring
Open some photos. Check a few videos. Make sure the files aren’t just showing names with broken content behind them. I learned this one the hard way after recovering a wedding set where thumbnails looked fine but several clips were dead.
5. Recover to a different drive
Send the restored files to your computer’s main drive or an external SSD. Do not write them back to the CF card. If you recover onto the same card, you risk overwriting the missing files you still haven’t pulled off yet. Kinda brutal, but true.
If the videos come back broken
This part trips people up.
Large video files fragment more easily than stills. So if a recovered clip won’t open, it doesn’t always mean it’s gone. VLC sometimes helps. In its input and codec settings, set broken or incomplete AVI handling to “Always Fix”. For Windows, Untrunc is another free tool people use to rebuild damaged headers.
Not magic. Still worth trying.
After the files are safe
Once your photos and videos are copied somewhere solid and you’ve checked them, then look at the card itself.
On Windows, run CHKDSK. On Mac, try First Aid. If the card seems stable after that, I’d still reformat it in the camera before using it again. If the card has failed more than once, I’d retire it. Flash media gets flaky, and I don’t like gambling with paid work.
Short version
If your CF card is unreadable:
- stop using it
- don’t format it
- use a dedicated reader
- confirm it appears in Disk Management or Disk Utility
- scan it with recovery software
- preview files
- restore to a different drive
That order matters. Mess up the order and recovery odds drop.
If the used space still shows up, your files are often still there. What’s missing is the directory entry, hidden flags, or a damaged DCIM structure. I agree with @mikeappsreviewer on stopping all writes. I’d add one thing first, check if the folders were marked hidden.
On Windows:
Open File Explorer, View, then enable Hidden items.
Then open Command Prompt and run:
attrib -h -r -s /s /d X:*.*
Replace X with your CF card letter.
I’ve seen CF cards come back from “empty” to normal after that. No scan needed.
If that fails, I’d skip CHKDSK at this stage. Small disagreement there. CHKDSK sometimes “fixes” a bad file system by moving lost entries into FOUND.000, which is not ideal before recovery. Recover first, repair later.
Also check the card on Linux if you have access to it. A live USB plus ls, fdisk, or testdisk often shows files Windows hides or mangles. TestDisk is worth trying before file carving because it restores folder structure better than tools like PhotoRec.
My order would be:
- Show hidden files.
- Clear hidden/system attributes.
- Make an image of the CF card.
- Try TestDisk on the image.
- If structure is gone, scan with Disk Drill for photo and video recovery.
- Save output to another drive.
Disk Drill helps when the folders are gone but RAWs and video clips still exist by signature. Preview matters a lot with CF recovery.
Also, this short video covers the process well:
CF card data recovery tips for missing folders and hidden files
One more thing. If your camera still reads some files, copy those first by hand. Don’t wait. Cards go from flaky to dead prety fast.
If the card still shows used space, I’d also check for one thing nobody does until too late: whether the partition itself got weird, not just the folders.
@mikeappsreviewer covered the “stop using it” part, and @andarilhonoturno is right that hidden attributes can make a card look empty. Where I slightly disagree is jumping into filesystem fixes too soon. I would not run any repair utility, and I also would not trust the camera to “see what’s there.” Cameras are terrible diagnostic tools.
What I’d do:
- plug the CF card into a reader
- check if it shows the correct size in Disk Management or Disk Utility
- note the file system type, or if it shows as RAW/unallocated
- if it mounts, try browsing it with a different file manager before scanning
- if it does not mount properly, make an image first and work from that only
Another thing worth trying is a hex/sector viewer or even a Linux live USB. Sometimes the DCIM folder is toast, but the actual file records are still partly there and Linux will expose more than Windows does. If the partition looks damaged but present, TestDisk can sometimes rebuild the directory tree better than pure carving tools.
If structure recovery fails, then yeah, Disk Drill is probly the practical move for CompactFlash card recovery. It’s better for pulling photos and video files when the folders vanished but the underlying data still exists. Preview is the key part. If your RAWs or clips preview correctly, your odds are decent.
One more tip: sort recovered files by signature/created time after recovery, not just by filename. Missing folder jobs often come back messy and out of order.
Also, if you want more community recommendations on CF card recovery software, this thread is pretty relevant:
best CF card data recovery software recommendations
If the card drops connection, clicks, gets scorching hot, or disappears randomly, stop the DIY stuff. That’s where pepole usually turn a recoverable card into a dead one.
