I’ve trained a few AI models locally that work well in tests, but I’m stuck on how to actually deploy them to a real production environment. I’m not sure what tools, platforms, or best practices I should follow for scalability, monitoring, and security. Can someone walk me through practical options or a step-by-step approach to deploying AI models successfully?
You are at the fun part now. Here is a practical path for getting a Scala based model into production.
Decide how you expose the model
Easiest pattern is “model as a service” over HTTP.
Options:- Build a small Scala HTTP API. For example with Akka HTTP, http4s, or Play.
- Load the model on startup. Keep it in memory. Serve predictions via POST /predict.
- Use JSON in and out.
Package the model
- If you trained with Python, export the model to ONNX or TorchScript.
- In Scala, use:
- DJL (Deep Java Library) to load ONNX, PyTorch, TensorFlow.
- Or use JVM friendly frameworks like XGBoost4J, LightGBM4J, Smile, or Spark ML if that matches your model.
- Keep the model file in a versioned storage location:
- S3, GCS, Azure Blob, or a private registry.
- Put a version in the filename and in your app config. Example: MODEL_VERSION=1.3.2.
Containerize
- Write a Dockerfile:
- Base image: eclipse-temurin:17-jre or similar.
- Copy your fat JAR.
- Copy or download the model during build or on startup.
- Expose one port, like 8080.
- Build and run it locally:
- docker build -t my-model-service:1.0 .
- docker run -p 8080:8080 my-model-service:1.0
Pick a serving platform
Simple options if you do not want heavy infra:- AWS
- ECS with Fargate, or EKS with Kubernetes.
- Use Application Load Balancer in front of tasks/pods.
- GCP
- Cloud Run works well for stateless model services.
- Azure
- Azure Container Apps or AKS.
- If you already have Kubernetes:
- Create a Deployment for the model.
- Use a Service and an Ingress.
- If you want “ML flavored” serving:
- Seldon Core on Kubernetes for canary, A/B, metrics.
- KFServing / KServe if your org uses Kubeflow.
- BentoML if you are fine running Python services, but you said Scala so less ideal unless you wrap Python.
- AWS
Logging and monitoring
Minimum:- Request logs with:
- Model version.
- Input size or key input metadata.
- Latency.
- Outcome status codes.
- Export metrics:
- QPS, p95 latency, error rate.
- Use Prometheus plus Grafana or cloud equivalents.
- Tracing:
- OpenTelemetry for tracing across services if your stack already uses it.
Performance
- Load test with k6, Gatling, or JMeter.
- Measure:
- p50, p95, p99 latency.
- CPU and memory usage.
- Tune:
- Batch predictions if your use case allows it, like process 8 or 16 requests at once inside the service.
- Adjust JVM flags, for example:
-Xms and -Xmx to stable values. - Use warmup logic to load the model before accepting traffic.
Reliability and rollout
- Use rolling updates:
- In Kubernetes, set Deployment strategy rollingUpdate.
- Keep at least 1 pod always ready.
- Blue green or canary:
- Run v1 and v2 in parallel.
- Send 5 to 10 percent traffic to v2 at first.
- Automatically roll back on high error rate.
Data and model management
- Store training data schema in version control.
- Store model metadata separately:
- Model version, training data version, training code commit, metrics.
- Tools:
- MLflow or DVC for tracking models and experiments.
- Only promote models that pass both offline and online checks.
Typical stack example for Scala
- Model: exported to ONNX.
- Serving app: Scala 2.13 or 3 with Akka HTTP or http4s, DJL for inference.
- Packaging: sbt-assembly to build fat JAR.
- Container: Docker with Temurin JRE 17.
- Platform: Kubernetes on EKS, GKE, or self hosted.
- Observability: Prometheus, Grafana, Loki, OpenTelemetry.
Security and limits
- Put the service behind an API gateway.
- AWS API Gateway, Kong, NGINX Ingress, or Envoy.
- Add:
- Auth, for example JWT.
- Rate limiting.
- Request size limits to defend against giant payloads.
Minimal starter setup if you want something fast and simple:
- Scala HTTP microservice.
- DJL or your model library.
- Docker.
- Cloud Run or ECS Fargate.
- Prometheus style metrics and JSON logging.
If you share more about your stack, like Python vs JVM training, GPU needs, traffic level, we can narrow this down further.
If your goal is “Scala in prod” specifically, you actually have more options than just “wrap it in a Scala HTTP service and Docker” like @cacadordeestrelas outlined.
Some extra angles that might fit better depending on what you already have:
Skip ONNX sometimes
If the models were trained in Python and you still have Python infra, exporting to ONNX or TorchScript and then loading it on the JVM is not always worth the pain. For low or moderate traffic, a Python-serving stack (e.g. FastAPI + Uvicorn) behind your Scala backend can be totally fine.
Your Scala app calls the Python service over HTTP or gRPC. You keep Scala for the “business” side, Python for the ML.
People over-optimize this step and spend weeks fighting ONNX quirks that give them like 5 percent speedup at best. -
In-process vs out-of-process
You do not have to load the model into the same JVM as the rest of your app. Two patterns:
In-process: what @cacadordeestrelas suggested
- Pros: simplest deployment, low latency.
- Cons: model crashes or leaks memory, it takes down the whole app.
Sidecar model service:
- One container runs the Scala HTTP API, another container in the same pod runs the model (Scala or Python).
- Communicate via localhost.
- Easier to roll different model versions without touching the “main” app.
- Use an existing JVM-serving stack
If you are already on Spark or Flink, you can sometimes avoid writing a custom HTTP service at all:
Spark Structured Streaming:
- Use Spark ML pipelines and serve via something like Spark Thrift Server or even Livy.
- Not ideal for low-latency, but great for batch or micro-batch scoring.
Flink:
- For continuous scoring, bake your model into a Flink job.
- Very nice when the data is streaming anyway.
For classic request/response APIs, I personally like http4s in Scala 3 plus a thin model layer.
- Don’t forget feature parity
One thing people mess up: training vs serving features.
Whatever feature engineering you used for training must exist in prod in exactly the same way. Some options:
- Shared feature library in Scala:
- Move all feature transforms to a shared JVM module that both training and serving can use (training via Spark/Scala or even using that module from Python via Py4J, if you are brave).
- Feature store:
- If you are on AWS/GCP/Azure, check feature store offerings or use Feast.
- The key is: the same logic, same joins, same normalization. Otherwise the model looks “bad” in prod for no reason.
- Simple autoscaling option
Instead of going straight to Kubernetes like everyone loves to suggest:
- For CPU-only and moderate QPS:
- AWS App Runner or GCP Cloud Run can autoscale your containerized Scala service with way less complexity than full-blown Kubernetes.
- You can still expose /metrics and use logging the same way.
I’d honestly start with:
- Scala microservice with your favorite HTTP lib
- Either:
- In-process model in JVM if you can load it directly
- Or a very thin Python inference service if your model stack is PyTorch / TF and you do not want export hell
- Containerize once
- Run on Cloud Run or App Runner
- Observe, then decide if it is worth the jump to fancy tools like Seldon, KServe, etc.
What does your current stack look like?
- Trained in Python or Scala already?
- Need GPU?
- Expected QPS / latency targets?
Those three answers will basically choose the tools for you.
I’d zoom out a bit and talk about how you run models in Scala over the long term, not just where you stick the HTTP service.
Both @chasseurdetoiles and @cacadordeestrelas focused on the “model-as-a-service + Docker + cloud” path, which is solid, but there are a few higher‑level choices you should make first.
1. Decide your serving pattern before picking tools
You basically have three realistic patterns for Scala:
Online sync inference
- Example: user hits
/recommendations, you call the model, answer in < 200 ms. - Put the model in a small Scala microservice (Akka HTTP, http4s, Play, doesn’t matter much).
- This is what the other replies largely covered.
Async / job-based inference
- You drop requests into a queue, do inference in a worker, write results to a DB or cache.
- Scala works well here with Kafka + a JVM consumer or something like Alpakka.
- You avoid tail latency headaches and can batch aggressively.
- If your product can tolerate “seconds” latency, this is often more robust than a hot HTTP model.
Batch inference
- Nightly or hourly runs: Spark jobs in Scala using Spark ML or loading an exported model.
- This is criminally underrated: for a lot of “personalization” and scoring, daily batches are enough.
If you pick pattern 2 or 3, you may not even need a dedicated “model service” at all, which is where I slightly disagree with the “always wrap it in an HTTP service” approach.
2. JVM vs external serving: choose one and commit
You essentially have:
JVM-native serving (Scala / Java in-process)
- Pros:
- Simple deployment story (one container).
- Easy to use JVM observability (Micrometer, Prometheus, etc.).
- Cons:
- ONNX / DJL / Java bindings sometimes lag behind Python ecosystems.
- Advanced models and custom ops can be painful.
- Pros:
External model runtime (Python or dedicated server)
- Pros:
- Use PyTorch / TF / Hugging Face in their “native” environment.
- Faster iteration on model code.
- Cons:
- Cross-language overhead (network hop).
- Two stacks to maintain and deploy.
- Pros:
If your models are not extremely latency sensitive (say p95 can be < 300 ms) and you iterate on them frequently, I would not rush into ONNX or JVM bindings. A thin Scala client calling a Python FastAPI server is often more pragmatic early on.
Later, when models stabilize, then migrate to ONNX + DJL as @chasseurdetoiles suggested. Treat JVM in-process serving as a “phase 2” optimization, not the starting point.
3. Feature pipeline > model wrapper
Most production misery comes from feature mismatch, not from Dockerfiles. Before anything else, get this right:
- Put all feature transformations into a shared library where possible.
- If your training is in Python and serving in Scala, encode transforms in a data language, not code:
- Example: YAML / JSON configs that define normalization, bucketing, one-hot encodings.
- Scala service interprets those configs.
- Python training pipeline reads the same configs.
- Alternatively, centralize features in a store (Feast or cloud feature store), then both training and serving pull from the same definitions.
This is one area where I gently disagree with just “export model + load in DJL and you’re done.” If you ignore the feature system, you ship something that “works” technically but gives nonsense predictions.
4. Architecture choices that make life easier later
A few patterns that play really nicely with Scala models:
Separate “model API” from “product API”
- Product API: Scala service that handles auth, business logic, response shaping.
- Model API: small internal service (Scala or Python) that does only: validate input, run model, return output.
- Benefits:
- You can redeploy model versions without touching product endpoints.
- You can put aggressive resource limits and autoscaling only on that model service.
Cache aggressively at the edge
- Many ML predictions are somewhat stable for a user or an item.
- Use a TTL-based cache (Redis, in-memory, Cloud CDN / CloudFront) keyed by
(user, feature-hash, model-version). - Reduces QPS to the model a lot, so you do not need exotic infra.
Shadow deployments by default
- Even without KServe or Seldon, you can implement a simple “shadow” in Scala:
- Main path: call
model_v1. - In background: asynchronously call
model_v2, log outputs, but do not affect the response.
- Main path: call
- This can be done with a tiny Scala wrapper and does not require complicated ML tooling.
5. About the mysteriously named product: How To Deploy Ai Models I’ve trained a few AI models locally...
Assuming this refers to a written guide or course with that title, it can be useful as a conceptual overview, especially if it walks through:
- Packaging models
- Environment isolation
- Versioning and rollback
- Monitoring and retraining loops
- Likely structured end-to-end, which is good when you are overwhelmed by choices.
- Could provide copy-paste templates for CI, Docker, or infra that you adapt to Scala.
- Helps with “what comes after v1” such as retraining and governance, which many code-first answers skip.
Cons
- Anything generic with that kind of title tends to be Python-centric, with less depth on Scala and JVM serving.
- Might overemphasize specific cloud services or MLOps platforms that you do not actually need yet.
- Risk of giving the impression that you must adopt a heavy stack before you even have traffic.
Use it for ideas and checklists, not as dogma. Cross-check its flows against the JVM- and Scala-specific approaches that @cacadordeestrelas and @chasseurdetoiles described.
6. How to tie this together into something you can deploy next week
A pragmatic sequence that differs slightly from the other answers but still plays nicely with them:
Pick pattern
- If you need < 200 ms and expect real traffic soon: online sync inference with a model service.
- Otherwise: async worker from a queue, or batch.
Lock in serving stack
- Short term: if you already train in Python, run a Python inference container and call it from Scala.
- Medium term: once your model stabilizes, export to ONNX and use DJL in Scala.
Implement a tiny feature spec layer
- Define transforms in JSON/YAML and consume them from both training and serving.
- This gives you “feature parity” even with mixed-language stacks.
Choose deployment target by complexity, not hype
- Very low complexity: Docker + Cloud Run / App Runner.
- Only jump to EKS / AKS / GKE when you have multiple services and real scaling pain.
From day 1, add:
- Model version tagging in logs.
- Simple counters for success / failures / latency.
- A cheap way to shadow a new model (even just logging to a separate index).
That mix will mesh well with the detailed HTTP + Docker + K8s strategies from @chasseurdetoiles and @cacadordeestrelas, while keeping the focus on architecture, features, and language boundaries, which are usually the real sources of pain.
If you share whether your models are mainly tree-based (XGBoost, LightGBM) or deep learning, and your latency / QPS targets, you can narrow this even further, because the Scala story is quite different for gradient-boosted trees vs big neural nets.
