How To Hide Apps On Android
I need to hide a few apps on my Android phone so they don’t show up on the home screen or app drawer, but I still want them installed and usable. I’ve checked my settings and don’t see a clear option. Are there built-in methods, launchers, or safe tools that can hide apps without rooting or breaking anything, and what are the pros and cons of each?
Short version. You have three main paths:
  1. Use built in “Hide app” in your launcher
  2. Use a secure folder / work profile
  3. Use a third party launcher or hiding app
Details below.
  1. Check your stock launcher first
    This depends a lot on brand.
Samsung
• Long press home screen
• Tap Settings
• Tap “Hide apps on Home and Apps screens”
• Select apps
They disappear from drawer and home, still installed. You open them through search or by unhiding.
OnePlus / Oppo / Realme (depending on version)
• Settings
• Privacy
• “Hide apps” or “App lock and hide”
• Pick apps
Some versions move them to a hidden space, often need a PIN or swipe code.
Xiaomi / Redmi / Poco
• Settings
• Apps
• App lock
• Enable app lock
• Then “Hidden apps”
Select apps. Access often by pinching out on home screen or special gesture.
Huawei / Honor
• Settings
• Privacy
• App lock
Sometimes a “PrivateSpace” profile where you install apps separately.
If you do not see “Hide apps” anywhere, your stock launcher likely lacks it.
  1. Use a secure folder or second profile
    Good if you want some privacy on a shared phone.
Samsung Secure Folder
• Settings
• Security and privacy
• Secure Folder
• Set it up
• Install or move apps into Secure Folder
Those apps will only appear inside Secure Folder. You need your Samsung or lock screen credentials.
Android work profile (like Shelter or Island)
Shelter (FOSS) uses Android work profile.
• Install Shelter from F-Droid
• Set it up
• Clone apps into the work profile
• Then pause or hide work profile icon
To others it looks like those apps are not on main profile.
  1. Use a third party launcher
    If your stock launcher has no hide option, this is the easiest.
Nova Launcher
• Install Nova Launcher
• Set as default home app
• Nova Settings
• App drawer
• “Hide apps”
• Select apps
They vanish from app drawer. You still see them via search in Nova if you allow it, or by direct shortcut.
Microsoft Launcher, Smart Launcher, etc offer similar “Hide apps” options.
  1. “Disable” vs “Hide”
    In Settings > Apps, if you press “Disable” on a system app, it disappears, but it stops working. That is not what you want for apps you still use.
  2. How to open a hidden app
    Depends on method:
    • Hidden from launcher: often via search in the launcher, or by re-adding icon from app info.
    • Secure Folder: open Secure Folder, then the app.
    • Hidden space / private space: open hidden area with the special gesture or PIN.
  3. Quick privacy tricks
    If you share your phone:
    • Use separate user profile in Settings > System > Multiple users. Install those “secret” apps only in your profile.
    • Or lock apps with App Lock if your brand has it, so even if they show, others cannot open them.
If you share which phone model and Android version you use, people here can tell you the exact menu path, since OEMs love to hide these options in slightly different spots.
If you’ve already tried what @voyageurdubois outlined and still aren’t happy, there are a few “side door” tricks that work even when your launcher has zero hide options.
  1. Use widgets or direct shortcuts instead of icons
    Uninstall the app icon from the home screen, then:
    • Long‑press home screen
    • Add “Activity” or “Shortcut” (depends on launcher / apps like “Activity Launcher”)
    • Point it to a specific screen inside the app (like a note, a vault, etc.)
    Result: the actual app icon is gone from drawer (if hidden via launcher or work profile), but you keep a boring‑looking shortcut like “Tools” that opens it.
  2. Rename and “camouflage” with dual apps / clones
    On brands that support app cloning / dual apps:
    • Enable “Dual apps” / “App cloner” for the app you want hidden
    • Keep one copy visible with a generic icon/name like “System service” using an icon pack / custom launcher
    • Hide the original copy completely using whatever hide method you do have
    You use the ugly “fake” version, while the obvious one is invisible.
  3. Abuse Guest / user profiles creatively
    Most people either go all‑in on extra profiles or ignore them. You can do:
    • Main profile: normal, clean set of apps
    • Secondary user: install the “secret” apps here only
    Then:
    • Turn off fast user switching from lockscreen (if your ROM allows)
    • Only switch to that user when you’re alone
    There’s no app to “find” at all in your main profile. This is better privacy than simple hiding.
  4. Change default handlers to keep things from popping up
    Some “hidden” apps betray you when they try to open links, PDFs, etc.
    • Settings > Apps > Default apps
    • Make sure your “cover” apps handle browsers, PDF readers, dialer, etc.
    So your hidden browser or messaging app never auto‑launches in front of someone.
  5. Notification discipline
    A lot of people hide the app then forget about:
    • Notifications
    • Recent apps screen
    • Suggestions in “Share” and “Recent apps”
    Mitigations:
    • Turn off notifications for those apps completely or hide content on lockscreen
    • In Settings for “Suggestions” / “Recent apps”, disable app suggestions if your skin allows it
    If the icon is hidden but its notifications scream at the top bar, that’s not really hidden.
  6. Don’t rely on “Disable” or “Hide from recents” as a privacy trick
    Minor disagreement with the general idea that launcher hiding is usually enough. Technically yes, but anyone moderately curious can:
    • Open Settings > Apps and scroll
    • Use Play Store > Manage apps
    • Use a file manager to see installed packages
    If you actually care about people not finding out the app exists at all, work profile, secondary user, or Secure Folder (where available) are much more honest solutions.
If you share your exact phone brand / model, the real magic is often in some weirdly named feature like “Private space” or “Hidden toolbox” that the OEM hid three menus deep.
Skip the usual “hide app in launcher” tricks for a second; you already saw what @voyageurdubois covered. Let me hit angles they did not lean on as much and add where I slightly disagree.
1. Use “work profile” as a stealth container
Instead of clones or guest mode, a proper work profile (via Android’s built‑in work profile support or an MDM‑style app from Play Store) is underrated.
How it helps
  • Apps inside the work profile have separate icons and data.
  • Many launchers let you toggle off showing work profile apps, so they disappear from drawer and home.
  • You can pause the work profile so apps stop running and sending notifications.
Where I disagree a bit with the “dual app” approach
Cloned apps can still look suspicious in Settings > Apps because you end up with two installs of the same thing. A work profile groups them more “officially” and might look like a job requirement rather than something you did to hide stuff.
Cons
  • Slight overhead: more notifications and more setup.
  • Some ROMs make the profile indicator obvious in the status bar.
  • Clean separation, better than just launcher hiding.
  • Easy to temporarily “lock away” everything by pausing the profile.
2. Use a launcher with per‑folder lock instead of only “hide”
Most people just use the “Hide apps” toggle, but some launchers let you create password‑protected folders or panels.
Pattern that works nicely
  • Put all sensitive apps in a folder.
  • Enable folder lock or fingerprint lock for that folder.
  • Change folder name and icon to something dull like “Office” or “Utilities”.
This sidesteps the problem @voyageurdubois raised about people checking Settings > Apps. Sure, they could still find installs, but in day‑to‑day use no one casually opens every folder, then passes authentication.
  • Quick access for you, low friction.
  • Looks like normal organization, not hiding.
Cons
  • If someone knows your unlock method, the whole trick collapses.
  • Still not true “they never know the app exists” privacy.
3. Focus on search suppression, not just icons
Even if you hide icons, Android search and launcher search often betray you.
Checklist most people forget:
  • Settings > Apps > [App] > “Appear in search” or “App search” (wording varies). Turn off any “show results” type option.
  • In your launcher’s settings, look for “Search results” or “Suggestions” and untick those apps specifically.
  • On some OEM skins, disable “Show app in search bar” per app.
This side-step is missing in a lot of threads. You can have a fully hidden icon, but one accidental search on the home bar exposes the app name and icon.
4. Keyboard & autofill leaks
Even if you follow the notification discipline and link handling advice from @voyageurdubois, two more leaks exist:
  1. Keyboard suggestions
    • Your keyboard can learn app names and terms from those apps.
    • In keyboard settings, clear personal dictionary and disable “learn from apps / contacts” if you really care.
  2. Autofill providers
    • Password managers can leak service names and icons in autofill popups.
    • Switch to a more generic looking autofill provider or turn off “show suggestions for unknown apps.”
These are subtle but often overlooked if someone is watching you type.
5. Use “How To Hide Apps On Android” style routines: automation
Instead of relying purely on static hiding, you can automate “stealth mode.”
Ideas using automation apps:
  • When you leave home Wi‑Fi, automatically:
    • Pause work profile or secondary user.
    • Disable notifications for a set of apps.
  • When you plug in headphones (private time signal), re‑enable those apps or open a specific activity like a vault screen.
This gives dynamic privacy. The phone looks different in different contexts without you doing long manual steps every time.
6. When not to bother hiding at all
Contrary to some suggestions, hiding is sometimes worse than just being honest about “utility” apps:
  • If people who borrow your phone are relatively tech‑savvy, a bunch of obviously absent basics (like no alternate browser or no gallery replacement) can itself be suspicious.
  • Having a few “utility” or “file manager” style apps in plain sight, configured with proper lock screens, may blend better than extremely aggressive hiding.
So the trick is to decide what you truly want:
  • “They cannot quickly open this app” vs
  • “They cannot tell the app is installed at all.”
Work profiles, second users, or OEM private spaces are for the second case. Simple launcher or folder tricks are fine for the first.
7. About competitors & tradeoffs
Compared with what @voyageurdubois wrote, the approach here leans more on:
  • Work profiles as the main stealth layer.
  • Search / keyboard / autofill leak prevention.
  • Automation so you are not constantly toggling things by hand.
Their methods are solid on clones, widgets, and user profiles. I just think clones are more overhead than necessary if your goal is long‑term, low‑maintenance concealment, and work profile or private space gives a cleaner separation.
If you share your exact phone model, the discussion can pivot into which OEM feature to lean on (like “Private space,” “Hidden folder,” or vendor‑specific secure containers) and tie these strategies directly into that.
Use Android’s screen pinning instead of hiding apps. It solves the common case, lending your phone to someone.
Open Settings, search for “App pinning,” then enable it. Require your PIN to exit. Before handing over your phone, open the allowed app, open Recents, tap its icon, then select Pin.
The person stays inside one app. Your home screen, app drawer, messages, and settings remain inaccessible. Your sensitive apps stay installed and work normally. Setup takes about one minute, tho menu names vary by phone.
Hidden icons still leave a trail in places nobody here mentioned: battery usage, data usage, and storage breakdown. Open Settings and look at battery for the last day, or mobile data by app, and the ‘invisible’ app is sitting right there with its name and a usage number next to it. So the launcher tricks and even folder locks solve the glance test, not the poke-around test.
Screen pinning from @rapidgurux8304 is the one bit of this thread I’d actually reach for first, because it matches the real situation most people have. You’re not hiding from a forensic examiner, you’re handing your phone to a friend or a kid for two minutes. Pin one app, they can’t wander, done. It’s free, it’s built in, and there’s nothing to maintain. The catch is you have to remember to pin before you hand it over, and if you forget once the whole point is gone.
Where I’d push back on the general drift here is the amount of setup people are stacking up. Work profiles, automation on Wi-Fi leaving home, autofill provider swaps, keyboard dictionary clearing. That’s a lot of moving parts for something you’ll forget to keep in sync in a month. If your goal is genuinely ‘nobody can tell this app exists,’ a second user profile is the cleanest single move and you don’t have to babysit five settings. If your goal is just ‘don’t want it cluttering my drawer,’ the plain hide toggle is fine and you can stop there. Pick which problem you actually have before building the fortress.
