How To Transfer Data From Android To Android
I just got a new Android phone and I’m confused about the best way to transfer everything from my old device, including apps, photos, messages, and settings. I want to make sure I don’t lose any important data during the move. What’s the safest and most complete method to transfer data from Android to Android using built-in tools or trusted apps?
Fastest way is to let Google and the phone makers do the work for you. Here is a clean path that avoids losing stuff.
  1. Prep your old phone
  • Update Android and apps from Play Store.
  • Charge both phones.
  • Connect both to Wi‑Fi.
  • Go to Settings > System > Backup.
  • Turn on Backup to Google Drive.
  • Tap “Back up now”. Wait until it finishes.
This backup includes
  • App list and some app data
  • Call history
  • SMS (on newer versions or if you use Messages)
  • Wi‑Fi networks
  • Some settings and wallpapers
Photos and videos are separate.
  1. Make sure photos and videos are safe
    Option A: Google Photos
  • Install or open Google Photos on old phone.
  • Settings > Backup & sync > turn it on.
  • Choose “Original quality” if you care about full res and have storage.
  • Leave phone on Wi‑Fi until upload finishes.
Option B: Local copy to PC or external storage
  • Plug old phone into PC with USB.
  • Copy DCIM and Pictures folders to your computer.
    Or use an OTG USB drive and a file manager app and copy directly.
  1. Start your new phone setup
    When the new phone first boots
  • Pick language and Wi‑Fi.
  • When it asks “Copy apps & data”, choose “Next”.
  • You get two main choices:
    • Using cable: USB‑C to USB‑C or old phone’s cable with adapter. This is usually faster and more complete.
    • Using wireless: Use “Set up nearby device” or “Using your old device” and follow the prompt on both phones.
If it offers “Copy from Android phone” with QR code
  • Scan it with your old phone.
  • Approve connection.
Pick what you want to move
  • Apps
  • Photos and videos
  • SMS
  • Call history
  • Device settings
Let it run. Keep both screens on and plugged in if transfer is big.
  1. Restore from Google account
    After or during setup
  • Sign in with the same Google account you used on the old phone.
  • When it asks which backup to restore from, pick your old phone.
  • Select what to restore.
The phone pulls
  • Home screen layout on some brands
  • Wi‑Fi networks
  • Call history
  • Texts
  • App list from Play Store
Apps reinstall automatically from Play Store in the background.
  1. Messenger and chat apps
    These need separate attention.
WhatsApp
  • On old phone, in WhatsApp, go to Settings > Chats > Chat backup.
  • Backup to Google Drive and include videos if you want.
  • On new phone, install WhatsApp.
  • Register same phone number.
  • It will find the Drive backup and offer restore.
Other messengers like Signal, Telegram, Viber
  • Check each app’s backup settings.
  • Some use cloud backup with your account, some use local file export you move manually.
  • Do this before you reset or stop using the old phone.
  1. Photos and videos on the new phone
    If you used Google Photos
  • Install Google Photos.
  • Log in with same account.
  • Turn on Backup & sync.
  • Your stuff appears once it syncs.
If you copied to PC or USB
  • Plug new phone into PC or USB drive.
  • Copy files into DCIM or Pictures on the new phone.
  1. Internal files, downloads, documents
  • Use the old phone’s Files app.
  • Copy important folders like Download, Documents, WhatsApp Media to a PC, USB or cloud like Drive.
  • Then copy them onto the new phone in similar folders.
  1. Double check before wiping the old phone
  • Check contacts. If you saved them to Google account, they show at contacts.google.com.
  • Check photos and videos on new phone or in Google Photos.
  • Open key apps like banking, 2FA, authenticator, before you reset the old phone. Some 2FA apps require account migration.
  1. If your brand has its own transfer tool
  • Samsung: Use Smart Switch. It moves almost everything, including some app data.
  • Xiaomi, OnePlus, Pixel, etc, have their own tools. On the new phone, check Settings or the initial setup for “Transfer”, “Clone phone”, “Smart Switch” and follow prompts.
Short version
  • Turn on Google backup.
  • Turn on Google Photos backup.
  • Use the new phone’s built in “Copy apps & data” with cable or wireless.
  • Manually back up special apps like WhatsApp and authenticator.
Do all that and you avoid missing apps, photos, or SMS. The only pain is logging in again to some apps, but there is no perfect fix for that yet.
If you already followed most of what @viajeroceleste wrote, you’re like 80% there. I’d focus on the stuff that doesn’t always migrate cleanly, because that’s where people usually get burned.
Here’s what I’d add / do differently:
1. Don’t trust just one backup
Google’s built‑in backup is fine, but I wouldn’t rely on it alone. Do at least two of these:
  • Google backup (already mentioned)
  • Manual backup to PC (copy full internal storage, not just DCIM)
  • Cloud service (Drive, Dropbox, Mega) for really critical docs
If one fails or corrupts, you’ve got a second safety net.
2. Deal with 2FA and security apps first
This is where most people get stuck after wiping the old phone.
  • If you use Google Authenticator:
    • Use the “Transfer accounts” option to move codes to the new phone.
  • If you use Authy:
    • Enable multi‑device in settings, install on the new phone, let it sync, then turn multi‑device back off if you’re paranoid.
  • Banking apps / government apps:
    • Open each one on the old phone, look for “Device change”, “Re‑register” or similar. Some lock to the old device and are a pain to re‑activate.
Do all this before you reset or sell the old phone.
3. Contacts sanity check
People assume their contacts are in Google, then realize half of them were stored “On device” only.
On the old phone:
  1. Open Contacts app
  2. Settings
  3. Export contacts
  4. Export to .vcf file and save it somewhere safe (Drive, email to yourself, etc.)
On the new phone:
  • Import that .vcf into Google account contacts. That way you’re not at the mercy of manufacturer tools.
4. Messaging: avoid weird surprises
Google Messages and WhatsApp are mostly covered already, but:
  • If you use a non‑Google SMS app, see if it has an export/backup option. Some store SMS/MMS in custom ways that Google’s restore does not catch.
  • RCS chats sometimes behave weirdly when switching phones; give it a bit of time to resync after you log in on the new device.
5. App data reality check
A lot of folks expect all app data to move. That’s… optimistic.
Stuff that usually does not fully come over:
  • Games without cloud saves
  • Old apps that ignore Android backup APIs
  • Apps that store data in weird folders
Workaround:
  • For any app you really care about (long games, note apps, etc.), open its settings and look for:
    • “Backup”
    • “Export data”
    • “Sync account”
Use those. Relying only on system‑level migration is asking for a minor heartbreak.
6. MicroSD and local storage tricks
If either phone has a microSD slot:
  • Copy Photos, WhatsApp Media, Download, Documents to SD on the old phone
  • Pop SD into the new phone
  • Move or re‑index from there
This can be faster and avoids flaky wireless transfers.
If not, a USB‑C flash drive or OTG adapter works similarly. Way more predictable than Bluetooth or random “phone cloning” apps from the Play Store.
7. After setup: verify before wiping
On the new phone, go through this checklist:
  • Contacts: random scroll through the list, not just a couple names
  • Photos: check a few old ones from different years
  • WhatsApp / Signal / Telegram: scroll up in older chats and see if history is there
  • Calendar: confirm events months in the past and future
  • Files: open your important PDFs, work docs, etc.
  • 2FA: test logging into at least one site that uses it
Only when you’re satisfied, factory reset the old phone.
8. One thing I slightly disagree with
I wouldn’t blindly trust the “let Google and the phone maker do everything” approach like @viajeroceleste suggests as the “clean path.” It’s convenient, but the more critical your data is, the more you should treat that as the baseline and then add manual backups on top. The slick setup wizards are great until they silently skip that one app or folder you actually needed.
If you do:
  • Google backup
  • Manual export of contacts
  • Dedicated backups for chat apps + 2FA
  • Manual copy of important folders (Download, Documents, WhatsApp, maybe a few others)
you’re pretty much bulletproof. The rest is just waiting for apps to reinstall and re‑logging into stuff, which sadly no one has fully solved yet.
Skip the overlap with @viajeroceleste for a sec and focus on what usually gets weird around the transfer, not in the transfer tool itself.
1. Decide your “transfer strategy” before you start
You’ve basically got 3 approaches:
  1. Cloud‑centric
    • Log into your Google account, let Android restore apps, settings, and some data.
    • Good if you already use Google Photos, Drive, Keep, etc.
    • Weak spot: offline data in niche apps and games.
  2. Local & cable‑centric
    • Use the official cable transfer in the Android setup wizard when possible.
    • More reliable for large media libraries and app installs.
    • Weak spot: can be slow, and some app data still will not clone.
  3. Hybrid
    • Let Google handle apps / settings.
    • Manually copy “problem” folders (Download, Documents, some app folders) to a PC or USB‑C drive.
    • This is what I recommend for most people.
I slightly disagree with relying heavily on “manual everything” like a lot of people suggest. For non‑power users it adds risk: more manual steps = more chances to forget one. For you, aim for hybrid: guided transfer first, then a short manual pass.
2. Before anything: clean your old phone a bit
You do not want to migrate years of junk.
  • Uninstall apps you haven’t opened in months.
  • Clear out obvious garbage in Downloads (duplicate PDFs, installers, random memes).
  • In gallery apps, quickly delete blurred photos, accidental screenshots, etc.
Result: your transfer is faster, backups are smaller, and it is easier to verify afterwards.
3. Think in categories, not just “backup the phone”
Instead of “I want everything,” go down this list and tick things off:
  • Identity & security: passwords, 2FA, banking, government apps.
  • Communication: calls, SMS/RCS, WhatsApp/Signal/Telegram.
  • Personal knowledge: notes, to‑do lists, password managers, calendar.
  • Media: camera photos, screenshots, WhatsApp media, downloaded media.
  • Work/study: PDFs, office docs, school apps, authenticator for work accounts.
  • Niche stuff: health trackers, smart home, IoT, VPN, authenticator for gaming or crypto.
If any of those categories feels “scary” to lose, open those apps and look for a specific export / cloud sync, in addition to what the system migration does.
4. Call logs, voicemail, and stuff people forget
These often get missed:
  • Call history
    • Some dialer apps back it up, some do not.
    • If your carrier app or OEM dialer has a “backup” option, use it.
    • If you truly need that history, consider a dedicated call log backup app, then restore on the new phone.
  • Voicemail
    • Visual voicemail is usually carrier tied and may not move automatically.
    • Save important voicemails as audio files where possible.
  • Custom ringtones / notification sounds
    • If you downloaded your tones, they live in Ringtones / Notifications / Alarms folders.
    • Manually copy those folders to a PC or USB‑C drive, then to the new phone.
5. Photos & videos: decide on “single source of truth”
If you still keep everything only in device storage, use this migration as an excuse to fix that.
Options:
  • Google Photos as the main hub:
    • Once all photos from old phone are backed up, treat the cloud as the master copy.
    • On the new phone, just sign in and let it resync.
  • Local‑first with your own archive:
    • Copy DCIM, Pictures, and sometimes WhatsApp / Media to a PC or external drive.
    • Keep that archive as your personal photo vault, separate from any phone.
My preference: cloud + a once‑per‑year export to a PC/drive. That way a bad migration can never wipe memories.
6. Streaming & DRM apps: accept the re‑login pain
This is unavoidable for:
  • Netflix, Prime Video, Spotify, etc.
  • Some offline media players using DRM or internal libraries.
Make a mental list of 5–10 “critical access” apps and be ready to:
  • Re‑enter passwords
  • Re‑approve devices
  • Re‑download offline playlists or episodes
Do this early so you don’t discover it on a long flight with no Wi‑Fi.
7. After transfer: do a deliberate 15‑minute audit
Once your new phone is set up:
  1. Open the app drawer, scroll slowly from top to bottom.
  2. Ask: “What am I sure I had on the old phone that I don’t see here?”
  3. For each missing app, decide: reinstall from Play Store or let it die.
Then check:
  • One old contact from “way back” to confirm deeper history came over.
  • Photos from different years.
  • A few old chat threads (especially those with media).
  • Calendar a year back and a year forward.
If all of that looks good, then you are safe to consider wiping the old device.
8. About the mysterious product title: How To Transfer Data From Android To Android
Used as a guide topic, “How To Transfer Data From Android To Android” fits exactly what you are doing: a structured checklist rather than just pressing “Copy” and praying.
Pros:
  • Encourages you to think in categories (apps, media, security, cloud vs local).
  • Easy to turn into your own written checklist so you do not skip critical items like authenticator codes or contacts.
  • SEO friendly if you ever document your process to help friends or coworkers.
  • It can make the whole process feel more complicated than it really is if you are not selective about what you actually care to keep.
  • Over‑planning can tempt you into redundant backups that burn time without real benefit.
Compared to what @viajeroceleste outlined, this angle is more about designing your personal migration strategy than about which buttons to press. Use their concrete steps, then add this higher‑level checklist on top so you do not miss the edge cases.
