Need advice building an English to Bengali translation app?
I’m trying to build an English to Bengali translation app but I’m stuck on choosing the right tech stack, APIs, and approach for accurate, natural translations. I’d really appreciate guidance on best tools, example architectures, and any common pitfalls so I don’t waste time going in the wrong direction.
If your goal is “accurate, natural” EN → BN, treat it like two separate problems:
  1. translation quality
  2. product and infra
Here is a practical breakdown.
  1. Decide on offline vs online
Online only
  • Easiest: call a hosted model API.
  • Options
    • OpenAI / similar LLM APIs for translation + tone control.
    • Google Cloud Translation API (supports Bengali, good for general text).
    • Microsoft Translator Text API.
Pros: no model training, simple to start.
Cons: latency, cost per request, data leaves device.
Hybrid
  • Do main translation via API.
  • Run small language model or rule layer on device for post edit and UX (spelling suggestions, dictionary, offline fallback phrases).
Pure offline
  • Needs on device model.
  • Look at
    • Marian NMT models for en–bn on Hugging Face.
    • M2M100, NLLB, or small LLaMA like bilingual variants, then quantize.
  • More work, but better for privacy and weak internet.
If you are stuck, start online, then move to hybrid.
  1. Pick your core translation engine
Fast MVP
  • Go with a cloud API:
    • Backend in Node, Python, or Go.
    • Simple REST endpoint: /translate that hits the provider.
  • Use batching for long text.
  • Cache frequent phrases in Redis.
More control, better “natural” tone
  • Fine tune an open model for EN ↔ BN.
  • Data sources
    • OpenSubtitles EN–BN pairs.
    • Global Voices.
    • GNOME / KDE / Ubuntu Bengali translations.
    • Wikipedia parallel corpora.
  • Clean the data:
    • Filter out long outliers, weird unicode, junk lines.
    • Use language ID to ensure English on source, Bengali on target.
  • Training stack
    • Use Hugging Face Transformers with Marian or M2M100.
    • Train on a GPU (A100 or even 2×T4 for small models).
  • Serve with
    • FastAPI or Node.
    • Use ONNX or bitsandbytes 8 bit for latency.
  1. Make translations sound natural
Bengali has formality levels, word order issues, and borrowed English words.
If you ignore those, output feels robotic.
Practical tricks:
  • Add “style tags” in prompts or inputs
    Example with LLM API:
    “Translate to Bengali. Tone: formal. Output in native sounding Dhaka dialect.”
  • Post processing layer
    • Custom dictionary for domain terms.
    Example: leave “CPU” as “CPU”, do not translate awkwardly.
    • Replace direct calques with more common Bengali phrases.
    For example:
    “take action” → “পদক্ষেপ নেওয়া” instead of weird literal.
  • Feedback loop
    • Add “rate this translation” in app.
    • Log bad ones.
    • Use them as fine tuning or rules.
  1. UI and UX details
People switch direction and script a lot.
Your UI helps keep it usable.
  • Detect language automatically
    • Use fastText or langdetect on the backend.
    • If user writes Bengali in Latin script, offer transliteration help.
  • Input helpers
    • Bengali keyboard integration.
    • Transliteration support: “amar naam” → “আমার নাম”.
    Check open source transliteration libs for bn.
  • Output options
    • Simple / formal switch.
    • Copy button.
    • Speak output using TTS
    Google TTS or Coqui TTS for Bengali.
  1. Example architecture
MVP (cloud based):
Client
  • React Native or Flutter app.
  • Calls /translate API.
  • Basic auth + rate limiting.
Backend
  • FastAPI or Express.
  • Endpoint /translate:
    1. Detect language of source.
    2. If English → Bengali, pick engine.
    3. Call provider API or local model.
    4. Run postprocess rules (dictionary, punctuation fix, spacing).
    5. Return JSON.
Services
  • Translation provider (OpenAI, Google, etc).
  • Redis cache for frequent phrases.
  • Database (Postgres or Mongo) for logs, feedback, and user prefs.
Later stage
  • Swap API engine with your own hosted NMT or LLM.
  • Add A/B experiment between providers or models.
  1. Tech stack suggestions by effort
Lowest effort
  • Frontend: React Native.
  • Backend: Node + Express.
  • Provider: Google Cloud Translation for text, Google TTS for voice.
Balanced
  • Frontend: Flutter.
  • Backend: FastAPI.
  • Provider: OpenAI for translation + style.
  • Hugging Face small EN–BN model on your backend for cheap traffic.
Higher effort, more control
  • Backend: FastAPI + ONNX runtime.
  • Model: fine tuned Marian en–bn, served from your infra.
  • Extra: rule based normalizer for colloquial Bengali, profanity filter, etc.
  1. Quality measurement
You will guess quality wrong if you only eyeball.
  • Automatic metrics
    • BLEU, chrF, COMET.
    • Use a held out EN–BN test set.
  • Human eval
    • Ask 3 native Bengali speakers.
    • Score fluency and adequacy 1 to 5.
    • Compare provider vs your model.
  1. Rough costs
Cloud API
  • Google Translation: about 20 USD per 1 million characters.
  • If average message is 100 characters, that is 10,000 translations.
Self hosted
  • One GPU instance (T4) on a cloud is about 200 to 300 USD per month.
  • Good if you run many translations, or need data control.
If you share a bit more about target use case, like chat, legal, education, or casual phrases, people here can suggest more tuned models and rules.
I’d tweak a few things compared to what @sternenwanderer suggested, especially if “natural Bengali” is your main goal.
  1. Start from your domain, not the tech
    Before APIs and stacks, lock this down:
  • Is it chatty daily stuff, exam prep, news, legal, medical?
  • Who’s your user: school kids, migrants, professionals, grandparents?
    Naturalness in Bengali changes a lot with domain and audience. “Perfectly fine” for tech blogs can sound bizarre in family chat.
  1. Don’t rely on one engine
    Instead of picking a single API/model, think ensemble:
  • Provider A (e.g. Google / MS) for short, general messages.
  • Provider B (LLM like OpenAI or a fine tuned HF model) for longer or nuance heavy inputs.
  • Simple heuristic router:
    • if len(text) < N and no domain terms → A
    • if user toggled “more natural” or text is long → B
You can even show “Alternative phrasing” from the second engine for power users.
  1. Put Bengali rules in front, not as an afterthought
    Everyone says “post processing,” but for EN → BN it helps to explicitly model Bengali decisions:
  • Formality flag: informal তুমি vs formal আপনি vs very formal জনাব/মহাশয় style. Persist this per user.
  • Region preference: Dhaka vs West Bengal. Even if you cannot fully localize, you can at least:
    • prefer “কি” vs “কী” usage patterns
    • choose between certain common synonyms.
  • Borrowed English terms: keep a small JSON config of what to keep untranslated (CPU, RAM, Wi‑Fi, startup, app) and what to always translate.
Wire that config so you can adjust it without redeploying code.
  1. Handle colloquial English explicitly
    A lot of Bengali users type extremely informal English:
  • “gonna”, “wanna”, half sentences, emoji, code switching like “amar mom is very strict”.
  • Pre normalize English before translation with a lightweight layer:
    • expand “gonna” → “going to”
    • map some common Hinglish / Banglish style words to clean English.
This alone boosts quality of any engine you plug in.
  1. Lightweight quality loop instead of early fine tuning
    I slightly disagree with jumping to fine tuning early. For a first real user app:
  • Log: source, output, user rating, and if they “edit before sending”.
  • If they edit, diff the original vs edited Bengali. That gives you real correction pairs from your users.
  • Once you have a few thousand of these, then consider fine tuning or at least building rule lists from the most common edits.
This is cheaper and less painful than pre collecting huge generic corpora that might not match your domain.
  1. Concrete stack idea that stays flexible
    Backend:
  • FastAPI or Express, whatever you’re productive in.
  • Simple pipeline:
    1. Detect language & script.
    2. Normalize English.
    3. Route to translation engine A or B.
    4. Apply BN style rules + dictionary.
    5. Return main + optional alternative translation.
Models/APIs:
  • Start online with 2 engines. For example:
    • Cloud MT (Google/Microsoft) for speed and baseline.
    • An LLM API for “better tone” + explanations.
  • In parallel, experiment with a small HF en‑bn model locally so you can swap later if cost explodes.
Client:
  • Add a “tone” toggle (casual / neutral / formal).
  • Add “see another version” button. That’s how you collect data for which engine/rule combo users prefer.
  1. Don’t overfit to BLEU at the start
    If you only chase BLEU/chrF/COMET you’ll “optimize” toward stiff textbook Bengali. For a translation app, I’d:
  • Use automatic metrics to avoid regressions.
  • But let 2 or 3 native speakers in your target demographic judge 100+ examples.
  • Prioritize their pain points (too formal, weird word choices, wrong idioms) over 1–2 BLEU points.
  1. Plan cost from the user side
    Rough template:
  • Estimate daily active users and average characters per request.
  • Multiply: DAU × req/user × chars/req.
  • Price that against your chosen API.
    Then decide where a self hosted model actually makes sense. Many ppl jump to “I’ll host Marian + GPU” while never hitting traffic levels that justify the ops stress.
If you share what your primary use case is (e.g. study helper, chat translator, document viewer, caption translator), you can shrink this a lot and maybe even hard code domain specific choices to get way more natural Bengali without a huge ML setup.
Skip the stack for a second and define “good enough” Bengali for v1:
  • Target tone: exam-style neutral, friendly chat, or “newspaper”?
  • Direction: mostly EN → BN, or also BN → EN and BN → BN rephrasing?
Once that’s fixed, here are angles that complement what @techchizkid and @sternenwanderer already laid out.
1. Don’t ship a “generic translator”; ship a mode
Instead of a single translate button, consider modes that hard-code choices:
  • “Chat Bengali”
    • Informal pronouns, more contractions, allow English tech terms to pass through.
    • Loose about perfect grammar but must feel native.
  • “Study / Exam Bengali”
    • More formal vocabulary, prefers full verb forms, avoids slang.
    • Stronger alignment to textbook style.
Mode can change:
  • Which engine you call (LLM vs NMT).
  • What dictionary list you apply.
  • Whether you allow code-mixed output.
This is a product decision, not just an ML one, and it matters more than obscure BLEU optimizations.
2. Introduce “explain the translation” as a killer feature
Most EN → BN apps only output Bengali. You can stand out by adding:
  • A button “Explain” that shows:
    • Word/phrase alignment for tricky bits
    • Notes like “Used আপনি because tone set to formal”
    • Glossary: “initiative → উদ্যোগ (commonly used in media / official contexts)”
LLMs are especially good for this, even if you use a classic NMT model for the main translation. Route like:
  1. NMT/MT engine produces Bengali.
  2. LLM gets {English, Bengali, user’s tone} and generates a short explanation.
Pros:
  • Educational angle. Great if your app is used by students or learners.
  • Gives users confidence when wording feels unusual.
  • Slightly higher latency and cost for “Explain” calls.
  • Need to cache explanations if users tap multiple times.
3. Add in-place editing with structured feedback
Rather than just “rate this translation 1–5,” let users correct output in a controlled way:
  • Tap on a word or phrase to see alternatives:
    • More formal / more casual
    • Synonym choices
Under the hood:
  • Keep a small, structured map of “alternatives by style” instead of thousands of loose rules.
  • Record which alternative they pick. That is labeled signal that is way more useful than a thumbs-down.
Over time:
  • You can learn which synonyms people prefer by domain and mode.
  • You can promote those preferences to default behavior.
This gives you a data loop without running a full fine-tuning pipeline on day 1.
4. Think hard about code mixing instead of “pure Bengali only”
Both previous replies focus a lot on “correct Bengali.” Bengali users in practice often prefer:
  • “আমার laptop টা খুব slow হয়ে গেছে”
  • “ওখানে একটা shortcut আছে, ওটা press করলেই হবে”
So design explicit policies:
  • When English noun phrases are present, allow a mixed output if user toggles “Banglish.”
  • Optionally show:
    • Pure Bengali version
    • Mixed version
You can implement this even with API-based translation:
  1. Pre-label English spans that you want to keep.
  2. Ask the engine: “Translate to Bengali but keep the bracketed phrases in Latin script.”
  3. Replace places accordingly.
This is not just “post processing.” It is shaping the output to match how bilingual people actually talk.
5. Lightweight test sets tailored to your app
Instead of only using standard corpora and metrics, build a tiny but sharp internal benchmark:
  • 100 to 300 sentences that:
    • Contain slang, idioms, pronoun ambiguity
    • Cover your main domains, such as school, office, shopping, travel
    • Include some code-mixed English
Then:
  • Compare engines and rule sets on this custom set.
  • Ask 2 or 3 native speakers who match your target user group to score:
    • Fluency (1–5)
    • Naturalness / “sounds like something I’d say” (1–5)
    • Faithfulness to source (1–5)
This small benchmark is more useful for your product than chasing one more BLEU point on general news.
6. Strategic disagreement: when not to fine tune early
Both @techchizkid and @sternenwanderer described fine tuning and GPU hosting. I’d actually delay that for a typical solo or small-team app unless:
  • You already have at least tens of thousands of in-domain pairs, or
  • You are sure API costs will explode soon.
Otherwise:
  • Start with 1 or 2 APIs plus a thin rules/dictionary layer.
  • Invest in product features: modes, explanations, editing, code-mix toggles.
  • Only move to custom models when:
    • You hit a clear cost wall, or
    • Your custom data clearly differs from anything public MT models were trained on.
You will likely get more real user love from better UX around translations than from marginal model gains.
7. Quick pros / cons snapshot for an “English to Bengali translation app”
Assuming you build something like this as a product:
  • Very high practical demand: students, migrant workers, content readers, elders.
  • A lot of room to differentiate:
    • Modes (chat / exam / Banglish)
    • Explanations and learning tools
    • Better handling of real-life messy input
  • You can start with APIs then gradually optimize costs and latency.
  • Once architecture is modular, you can experiment with new engines without rewriting the app.
Cons
  • Hard to compete on raw translation quality alone with big providers.
  • Bengali formality and regional variation can upset users if not handled cleanly.
  • Latency and cost constraints show up quickly on mobile-heavy user bases.
  • Collecting and managing user feedback data safely and ethically takes real effort.
Competitors in terms of approach, like the ones suggested by @techchizkid (more engine-ensemble and domain-first thinking) and @sternenwanderer (deeper dive into infrastructure, metrics, and training), are largely about how deep you want to go on ML vs product. Your edge will probably come from how opinionated your app is about tone, context, and user control rather than which single API or model you plug in.
If you share your main user persona (e.g., “Bangladeshi uni students prepping for English exams” or “parents reading English school notices”), it becomes much easier to pick which of these knobs to hard-code and which to expose as toggles.
