I’m trying to access a USB device through my Cloud OS but can’t figure it out. I’ve connected the USB device to my local machine, but it doesn’t appear in the cloud environment. Any ideas on how to get this set up?
Ever tried USB Network Gate? It’s perfect for accessing local USB devices from a Cloud OS. Install USB Network Gate on both your local PC and cloud instance. Then, share the USB device from the local machine and connect to it on the cloud side. This should make the USB device appear in your cloud environment seamlessly.
For more detailed steps, you can check out this guide on USB Cloud Passthrough. It might just solve your issue.
Hey there! I get what you’re dealing with. While using something like USB Network Gate can be effective, another method you might consider is relying on native RDP clients. Microsoft Remote Desktop Protocol (RDP) offers USB forwarding natively for Windows-based Cloud OS environments.
Here’s a quick rundown:
Check Local RDP settings: Make sure USB device redirection is enabled on your RDP client. You’ll typically find this setting in the Local Resources tab.
System Policy: Ensure your Cloud OS isn’t blocking USB redirection. Sometimes Group Policies on your cloud environment can prevent these kinds of device pass-through.
Alternative tools: If you’re dealing with Linux-based cloud servers, look into USB/IP project.
Steps for USB/IP on Linux:
- Install
usbipon both the local machine and the cloud server:sudo apt-get install usbip - Bind your USB device:
sudo usbip bind -b <bus-id> - Share the device over IP:
sudo usbipd -D - On the cloud server, attach the device:
sudo usbip attach -r <local-PC-IP> -b <bus-id>
By the way, if you’re still intrigued about using USB Network Gate, the USB passthrough application might be something worth exploring due to its user-friendly nature and detailed setup guides.
Hopefully, these pointers give you more flexibility in accessing your USB device from the Cloud OS. Good luck!
