Need help deleting an app on my iPhone
I’m trying to remove a few apps from my iPhone but I’m confused by the different methods I see online and nothing seems to match what I see on my screen. Did Apple change how app deletion works in recent iOS versions, and what’s the correct step-by-step way to fully delete an app and its data?
Yeah, Apple changed it a bit in newer iOS versions, so old guides look wrong now. Here are the main ways that match iOS 17 / late iOS 16.
  1. From the Home Screen
    • Find the app icon.
    • Press and hold it for about a second.
    • Tap “Remove App.”
    • You will see two options:
    – “Delete App” removes it from your iPhone and frees storage.
    – “Remove from Home Screen” hides it but keeps it in your App Library.
    If you only see “Edit Home Screen,” tap that, the icons will wiggle, then tap the minus icon on the app, then tap “Delete App.”
  2. From the App Library
    • Swipe left past your last Home Screen page.
    • Find the app in the App Library.
    • Press and hold the app icon.
    • Tap “Delete App,” then confirm.
  3. From Settings if the icons do not match what you see
    • Open Settings.
    • Tap “General.”
    • Tap “iPhone Storage.”
    • Wait for the list to load.
    • Tap the app name.
  4. If you only see “Offload App”
    • Offload removes the app itself, keeps its documents and data.
    • To fully remove it, you need “Delete App,” not “Offload App.”
    • If you first offloaded, you still see an icon with a cloud symbol. Delete again from Settings or Home Screen to clear it out.
  5. Check restrictions if “Delete App” does not appear
    • Open Settings.
    • Tap “Screen Time.”
    • Tap “Content & Privacy Restrictions.”
    • Tap “iTunes & App Store Purchases.”
    • Tap “Deleting Apps.”
    • Set it to “Allow.”
  6. System apps that will not delete
    • Some built in apps can be removed, like Mail, Music, Podcasts, etc.
    • Some others only allow “Remove from Home Screen,” not full deletion. That is normal.
Common things that confuse people
• Long press gives a quick menu now instead of going straight to wiggle mode. You need to tap “Remove App” or “Edit Home Screen” in that menu.
• If you removed an app but still see it in Search with a cloud icon, it is in your App Store history. Tap it and it will download again. It is not still installed.
• If your phone is on an older iOS, the wording might be slightly different, but the Settings > General > iPhone Storage path still works.
If your screen looks totally different than this, check: Settings > General > About and see your iOS version, then look up “delete apps iOS [your version number]”. The steps above match the current iOS, so they should line up pretty close.
Yeah, Apple absolutely changed how it works, which is why every third tutorial feels like it’s from an alternate universe. @cacadordeestrelas already covered the standard “press and hold / Remove App / Delete App” stuff really well, so I’ll just hit the weird edge cases that usually trip people up.
  1. Check what you’re trying to delete
    Some icons are not “real” apps:
  • Web clips (those from “Add to Home Screen” in Safari).
    • Those only have “Delete Bookmark” or just a little X when in edit mode. That’s normal, and it is deleting it, it just never shows up in iPhone Storage.
  • Shortcuts from the Shortcuts app.
    • You remove those inside the Shortcuts app, not via normal app deletion.
  1. If tapping and holding doesn’t show “Remove App” at all
    Sometimes you’re long‑pressing in the wrong place:
  • If you press a blank area of the Home Screen, you just get jiggle mode, not the context menu.
  • If you press too briefly, it opens the app instead of the menu.
    Try: press and hold for about a second, then lift your finger. Don’t slide. That timing is weird but matters.
  1. Deleting from Search (Spotlight)
    A trick a lot of people miss:
  • Swipe down on the Home Screen to open Search.
  • Type the app name.
  • Long press the result’s app icon.
  • If it’s installed, you should see “Delete App” in that menu.
    If you only see “Get” or a cloud icon in the App Store section, it means the app is already deleted and only in your purchase history.
  1. Profile / MDM stuff blocking you
    This is one spot where I’d tweak what @cacadordeestrelas implied. Screen Time is not the only place that stops deletion.
  • Go to Settings > General > VPN & Device Management.
  • If you see a management profile from work/school, that profile can prevent deleting certain apps completely.
    In that case, you simply will not see “Delete App” for those managed apps at all. Only your IT/admin can change that.
  1. If you “Delete App” but storage doesn’t seem to go down
    Couple of things to watch:
  • iPhone Storage is slow to update. Wait a few minutes, or restart.
  • Some apps store data in iCloud (e.g. Photos, Messages in iCloud). Deleting the app doesn’t remove the cloud data, so it looks like “nothing changed.” That’s by design, not a bug.
  • For games with very large “Documents & Data,” you must use Settings > General > iPhone Storage > [App] > Delete App, then reinstall fresh if you want to truly nuke saved data.
  1. If your screen still doesn’t match guides
    Check two places:
  • Settings > General > About > iOS Version.
    • If you’re on something like iOS 14 / 15, some menus look different from iOS 17. The “Remove App” wording might be missing and you just get the “X” in wiggle mode.
  • Settings > Home Screen.
    • There’s a setting that controls whether newly downloaded apps show up on the Home Screen or only in the App Library. If you don’t see an app icon anywhere, it might be only in App Library, not “gone.”
  1. One more gotcha: “recently removed but still here?”
    If you:
  • Deleted the app
  • Then you search and see it with a little cloud icon
    That means:
  • It is uninstalled
  • That icon simply pulls it again from the App Store. People often think “it didn’t delete” when in fact it did, it’s just still visible in your history.
If you post your exact iOS version and maybe describe what options you see when you long‑press the app (word for word), folks here can tell you exactly which of these cases you’re in. Right now it sounds like you’re caught between an older tutorial and the newer quick‑menu behavior.
