I’m trying to record my screen on my Samsung phone but can’t find the screen recorder anywhere in the settings or quick panel. I’ve checked guides online but the steps don’t match my menus, so I’m not sure if my model has this feature or if I need an app. Can someone explain how to screen record on Samsung and what to do if the built-in option is missing?
This trips a lot of people up because Samsung hides or removes stuff depending on model, region, and carrier.
Run through these in order:
Check if your model supports native screen record
- Go to Settings > About phone > Software information.
- Look for One UI version.
- One UI 2.0 and newer usually have Screen recorder.
- Very low end or older carrier models sometimes skip it.
Add it to Quick Panel
- Pull down the notification shade twice to see full toggles.
- Tap the three dots at top right > Edit buttons.
- Look for “Screen recorder”.
- If you see it, drag it up into the active area, then tap Done.
- If you do not see it anywhere in that list, your firmware build likely removed it.
Try Settings search
- Open Settings, use the search box.
- Type “screen recorder”.
- If no result at all, again, firmware or region block.
Check for carrier or region limits
- Carrier branded models and some regions remove the feature.
- If your phone is from a carrier store, that happens a lot.
- Also some work phones with MDM profiles disable it. Check Settings > General management > Device management or Profiles if your company controls it.
Use Samsung Game Launcher as a workaround
- Open Game Launcher app.
- Add the app or screen you want to record as a “game”.
- Start it from Game Launcher.
- Tap the Game Tools icon that floats on the side of the screen.
- Look for a record icon.
- This mostly works for apps and games, not the whole system UI.
If there is still nothing
- Install a trusted third party recorder from Play Store, like:
- XRecorder
- AZ Screen Recorder
- These use the system’s screen capture APIs. On Android 10+ they record internal audio for many apps.
Double check your OS version and model
- Settings > About phone > Model number and Android version.
- Search the exact model + “screen recorder support” on Samsung’s site or forums.
- Example, some Galaxy A10 variants on older Android builds never got the feature.
If you share your exact model (like SM-A13x, SM-G99xx, etc) and Android / One UI version, people here can say clearly if your phone supports native screen recording or if you are stuck with third party apps.
Yeah, Samsung made this way more confusing than it needs to be.
Couple things to try that are different from what @shizuka already said:
Check if it’s blocked by “security” stuff
- Go to Settings > Privacy or Security & privacy.
- Look for anything like “App permissions” or “Special access.”
- See if there’s a “Screen capture” or “Display over other apps” that might be restricted.
On some corporate or school phones, they silently disable screen recording even if the feature technically exists.
See if the feature is hidden behind “Advanced features”
- Settings > Advanced features.
- Some One UI builds shove anything capture-related under “Screenshots and screen recorder” or similar.
- If you only see “Screenshots” and nothing about recording, that’s usually a sign it’s not included in your firmware.
Try Safe Mode just to rule out weird apps blocking it
- Hold power button > long press “Power off” > Safe mode (text may vary).
- Once in Safe mode, pull down the quick panel and check again for Screen recorder in the edit buttons.
If it magically appears in Safe mode, some third party app (parential control, banking, DRM, etc.) is blocking or hiding it.
Region / CSC weirdness
This is the part most guides skip. Two phones with the same model number can behave differently depending on the CSC (region / carrier code).- Settings > About phone > Software information.
- Look for “Service provider software version” or a code like XAA/ATT/EUX etc.
Some CSCs literally ship without Screen recorder at all. In that case, nothing in Settings will ever make it appear.
People sometimes fix this by flashing unbranded firmware with a different CSC using Odin, but that: - Can wipe your phone
- Can break carrier stuff like VoLTE / WiFi calling
- Can void warranty / violate terms
So only consider that if you’re comfortable with PC tools and backups.
Third party apps, but be picky
If you have to go third party, don’t just grab the first thing with 100M downloads. Look for:- No weird VPN / booster / cleaner “extras”
- Clear privacy policy (yeah, I know, nobody reads them, but still)
- Ability to disable mic if you only want internal game audio (on Android 10+ many can do this within app limits)
Hard truth part
If:- “Screen recorder” does not show in Settings search
- It’s not in Quick panel > Edit even after Safe mode
- You do not see anything “Screen recorder” in Advanced features / Screenshots
then your variant likely just does not have native recording. It’s not you missing a menu. Samsung and carriers ship crippled builds all the time, especially on cheaper A and M series or carrier-locked stuff.
If you post your exact model number (SM-xxxx) and Android / One UI version like “Android 13 / One UI 5.1,” people can usually tell in one line whether it’s baked in or not. Otherwise you might waste hours hunting for a toggle that literally doesn’t exist on your phone.
Couple of extra angles that might help, building on what @viaggiatoresolare and @shizuka already covered:
1. Don’t overfocus on One UI version alone
They’re right that One UI 2+ often has Screen recorder, but it is not a hard rule. I’ve seen mid‑range Galaxy devices on One UI 5 with carrier firmware where the toggle is stripped out, even though Samsung’s global firmware for the same model has it. So if your Settings search shows absolutely nothing for “screen recorder,” stop hunting in menus. It is very likely missing from your specific build.
2. Check what exactly your phone is blocking
Instead of just looking for an on/off feature, open one of the Play Store screen recorder apps and see what permission it complains about.
Typical situations:
- It says it cannot capture the screen at all → strong policy / MDM restriction at system level.
- It can record video but not internal audio → that is a normal limitation on some Samsung + app combos, not a bug.
That error message can tell you more than Samsung’s own menus.
3. Use Samsung’s own ecosystem where possible
If native Screen recorder is missing, try these Samsung-ish workarounds before random apps:
- Game Launcher for anything that can be classified as a “game” (already mentioned). Sometimes you can sneak a non‑game app in there and still get recording.
- Smart View to a PC or TV plus capture on the other side. On a Windows PC with a capture tool, you can mirror your phone then record from the computer. Clunky, but it bypasses some phone‑side blocks.
4. About third‑party screen recorders
There is no single “magic” title that unlocks recording when Samsung or your carrier has completely disabled it, but good third‑party apps at least make the limit clear instead of you hunting through menus forever.
Since you mentioned you could not find native screen recording at all, a solid fallback is a well known Play Store recorder such as what people often look for under terms like “Android screen recorder app” or “Samsung screen recorder alternative.”
Typical pros of these apps:
- More control over bitrate, resolution, overlays and countdowns than Samsung’s stock recorder.
- Can often pause/resume mid‑recording.
- Some support internal audio capture on Android 10+ where the app allows it.
Typical cons:
- Extra permissions required, so you need to trust the developer.
- More likely to show ads or push you to a paid tier.
- Internal audio is still restricted by DRM and app rules, so they cannot record everything you hear.
Compared with the suggestions from @viaggiatoresolare (who focused more on firmware / model checks) and @shizuka (who dug into CSC and Safe mode), this route is less about “unlocking” a hidden toggle and more about accepting that your firmware probably does not ship a native recorder at all.
5. Decide if it is worth fighting the firmware
If you confirm:
- No “Screen recorder” in Settings search
- No toggle in Quick Panel edit
- No mention under Advanced features > Screenshots / Screen recorder
then your real choices are: - Live with a third‑party recorder.
- Flash unbranded Samsung firmware with a different CSC using Odin and accept the risk, time and potential warranty issues.
Unless you are already comfortable with flashing and backing up, I would not recommend jumping straight into firmware changes just for screen recording. The payoff is small compared to the risk of breaking carrier features or wiping your phone.
If you post your exact model (SM‑xxxx) and Android / One UI version, people can usually say in one line whether it is worth digging further or if you should just install a recorder app and move on.
Use a second phone to film your Samsung’s screen. This avoids firmware checks, apps, permissions, and flashing.
Set your Samsung brightness near 70 percent. Place the second phone on a stand or stack of books. Record in a quiet room, then trim the video in Gallery. Tap the Samsung screen slowly so each step stays clear.
For cleaner results, disable notifications and use Do Not Disturb first. This works well for short tutorials or showing an error. It’s less polished, but takes 2 minutes and works on any model, no setup hassel.
Skip the Odin CSC flashing idea for now. Reflashing your phone to a different region just to get a screen recorder is a lot of risk for a small payoff, and if you break VoLTE or WiFi calling on a carrier phone you’ll spend more time fixing that than you ever saved. That advice from @viaggiatoresolare is technically correct but it’s the last resort, not something to keep in your back pocket while you’re still figuring out if the toggle even exists.
The Safe Mode tip is actually the smartest quick check in this whole thread. If a school or work profile or some banking app is blocking capture, Safe Mode will show you in about thirty seconds without you touching any settings. Do that before you install anything.
Where I’d push back a little is on @cloudrouter5351’s second phone idea. It works, sure, but recording a screen with another camera almost always gives you glare, moire lines, and slightly off colors, and you can see the reflection of your hand or the room. For showing an error to support, fine. For anything you want to actually share or keep, it looks rough.
The thing nobody here mentioned: if you have a Windows PC, you can mirror the phone with Phone Link (Link to Windows, it’s baked into most Samsung phones under Advanced features or Connected devices) and then record the mirrored window on the PC using Xbox Game Bar. Press Win+G, hit record, and you’re capturing the phone screen from the computer side. No third party app on the phone, no firmware fight, and the quality is way better than pointing a camera at it. Audio can be hit or miss depending on the app and DRM, same limitation everyone already flagged, but for visuals it’s clean.
So my honest order would be: check Safe Mode and Settings search first, and if native recording genuinely isn’t in your build, go Phone Link plus Game Bar if you own a PC. Only fall back to a Play Store recorder like XRecorder if you’re phone only. Flashing stays off the table unless you want a different firmware for other reasons anyway.
Post your exact SM model and One UI version and someone can confirm whether you’re even missing a real feature or just looking in the wrong menu.
