I’ve been experimenting with Opendream AI Art but my outputs look low quality and inconsistent compared to examples I see online. I’m not sure if it’s my prompts, settings, or something else. Could anyone share tips, settings, or prompt formulas to improve realism and style control with Opendream AI Art?
I ran into the same thing with Opendream. First runs looked muddy and off. Here is what helped a lot.
Use a clear subject and style
Instead of
“fantasy warrior”
Try
“full body portrait of a fantasy female warrior, standing, facing camera, detailed armor, cinematic lighting, ultra sharp, 4k, digital painting, artstation style”Keep it around 20 to 60 tokens. Too long, the model gets confused.
Control the aspect ratio
If you want portraits, use something like 3:4 or 9:16.
For landscapes, use 16:9 or 3:2.
Wrong ratio often makes weird cropping and composition. -
CFG / guidance scale
If Opendream has a “guidance” or “prompt strength” slider, try:- 6 to 8 for more faithful to text
- 4 to 6 if images look overcooked or full of artifacts
High values tend to create harsh edges and extra junk.
Steps / quality
For SD style models, sweet spot is often 25 to 35 steps.
Too low: blurry.
Too high: noisy or over detailed.
Do small tests changing only one setting each time. -
Use negative prompts
Example basic negative prompt:
“blurry, low quality, lowres, extra fingers, extra limbs, disfigured, distorted, deformed, watermark, text, logo, cropped, out of frame, jpeg artifacts”If faces go weird, add:
“ugly face, asymmetrical face, deformed eyes, bad anatomy” -
Fix faces separately
If Opendream has a “face restore” or “face enhancement”, turn it on only at the end.
If not, generate at higher res, then run a face upscaler outside (like GFPGAN, CodeFormer or similar tools). -
Use good reference prompts
Look at the Opendream community or other SD galleries.
Copy a prompt that you like.
Swap subject words but keep the structure and quality terms.
Example:
“ultra detailed, 8k, sharp focus, volumetric lighting, subsurface scattering, studio photo, highly detailed skin” -
Control randomness with seeds
If you get one good result, note the seed.
Reuse same seed with small prompt tweaks.
This helps you learn which word changes affect what. -
Watch your starting resolution
Start around 512x768 or 768x768, then upscale.
Direct 4k generations often look messy and inconsistent.
Generate small, upscale with a good model after. -
Iterate, do not rewrite every time
Take one decent output.
Slightly tweak 1 or 2 words in the prompt.
Keep the same seed and settings.
This way you see cause and effect, instead of random chaos.
Common issues and quick fixes:
Everything looks washed out
Increase contrast or “sharp” wording in prompt.
Add “dramatic lighting, sharp focus, deep shadows”. -
Colors look weird
Add a color scheme line.
Example “teal and orange color grading” or “soft pastel colors” or “muted earthy tones”. -
Style jumps around
Add a consistent anchor like “studio ghibli style” or “pixar style” or “greg rutkowski style digital painting”.
Stick with the same anchor for a whole batch.
If you post one of your prompts and a sample, people here can point out exact tweaks. The gap between low quality and good output often comes from 2 or 3 small settings, not from anything huge.
I had the same “why does mine look like mashed potatoes while everyone else gets masterpieces” moment with Opendream, so here’s what helped that isn’t already in @himmelsjager’s very solid checklist.
- Stop changing everything at once
A lot of folks tweak prompt, cfg, steps, sampler, aspect ratio, seed, all in one go. Result: you have no clue what actually helped.
Pick one “baseline” setup that looks okay-ish. Then only change:
- either prompt wording
- or sampler
- or resolution
for a few runs. Treat it like A/B testing, not chaos mode.
Try different samplers, not just more steps
People love cranking steps to 40+ like it’s a magic “quality” button. Sometimes the sampler matters more.
If Opendream lets you pick stuff like Euler, DPM++, DDIM, etc, do quick 10–15 step tests across samplers with the same prompt, seed, and resolution.
You’ll see some samplers give cleaner edges, others give softer painterly vibes. Stick with one that matches your taste instead of just farming steps. -
Match style to model strengths
Opendream (like most SD-based stuff) is usually stronger at:
- stylized / digital painting
- semi-realism
than perfect photoreal faces.
If you’re pushing hardcore photoreal and it keeps looking uncanny or plastic, try: - “cinematic still frame” or “high-end fashion editorial photo” instead of “hyperreal 8k photo”
- slightly stylized: “realistic illustration” or “semi-realistic digital painting”
Leaning into what the model is good at instantly makes it look “higher quality” even with the same settings.
- Clean, prioritized prompts instead of word salad
I kinda disagree with stuffing every buzzword like “8k, 32k, octane render, unreal engine, masterpiece, award winning” into one line. That usually muddies the priorities.
Try structuring like this:
Subject & composition first
“full body portrait of a knight, standing in a ruined cathedral, centered, facing viewer” -
Then style & medium
“cinematic digital painting, semi-realistic, dramatic lighting” -
Then 3 to 6 important quality cues
“sharp focus, detailed armor, soft background, high contrast, rich colors”
That’s it. Cut the fluff. If everything is “ultra”, nothing is.
- Consistency trick: keep a “template prompt”
When I wanted consistent style across multiple characters, I made myself a fixed template:
“[SUBJECT], [pose], [environment]. cinematic digital painting, semi-realistic, soft volumetric lighting, shallow depth of field, rich colors, sharp focus, detailed textures”
Then I only replaced the [SUBJECT] and maybe [environment].
This keeps style + quality words frozen, which is huge if your outputs swing wildly from image to image.
Use negative prompts sparingly at first
I know long negative lists are popular, but too aggressive negatives can cause weird, stiff images.
Start small:
“blurry, low quality, extra limbs, extra fingers, distorted face, text, watermark”
Only add more if you actually see the issue show up repeatedly. Don’t pre-ban 50 things the model might never try to do. -
Check if your reference images are lying to you
A lot of samples online are:
- upscaled with specialized tools
- lightly photoshopped / retouched
- cherry-picked from dozens of generations
Your raw Opendream output will almost always look worse than those “finals”.
Try:
- generate 512 or 768 side
- pick the best
- run it through an upscaler or light sharpening filter
You’ll suddenly be a lot closer to what you see posted.
- Learn from your own “good accidents”
Every time you get one image you like, do this:
- save the exact prompt, settings, and seed
- make a tiny variation: change 3 to 5 words, keep everything else the same
- generate a small batch (like 4 images)
You’ll quickly learn “oh, the word cinematic really changes the lighting” or “removing ‘ultra detailed’ actually made it less noisy”. That learning is worth way more than copying 100 random prompts from others.
- Be realistic about “quality”
Some stuff is just inherently noisy or messy for these models:
- tons of tiny characters in one frame
- super wide scenes with high detail everywhere
- fast action poses with motion blur
If you’re judging Opendream’s quality by those kinds of shots, you’re setting it up to fail. Start with: - single character
- simple, readable environment
- clear lighting direction
Once that’s clean and consistent, then push to crazier compositions.
If you want, drop one actual prompt you’re using plus what you wanted it to look like, and people can dissect it line by line. That’s usually where the “aha” moment happens.
