Need help translating Spanish to natural American English
I’m working on a text originally written in Spanish and my own translation into American English sounds awkward and too literal. I need help making it sound natural and fluent while keeping the original meaning and tone. Can someone guide me or suggest better phrasing for tricky sentences?
Post your Spanish and your English try. People here need the text to help you. Without it, advice stays too generic.
Some quick rules so your English sounds natural and not like Google Translate:
  1. Break long Spanish sentences
    Spanish likes commas. American English likes shorter sentences.
    Example:
    Spanish: “A pesar de todo lo ocurrido, siguió adelante, sin mirar atrás, con la esperanza de encontrar algo mejor.”
    Natural EN: “Despite everything that happened, he kept going. He did not look back. He hoped to find something better.”
  2. Avoid word for word for connectors
    “Sin embargo” → “But” or “Still” or “Even so”
    “Por lo tanto” → “So”
    “Además” → “Also” or “On top of that”
    Often one short word sounds better than a formal phrase.
  3. Watch false friends
    “Actually” is not “Actualmente” → use “Currently” or “These days”
    “Realize” is not “Realizar” → use “Carry out”, “Do”, “Perform”
    “Assist” is more formal than “Help”. Use “help” unless it is academic or business.
  4. Tone shift
    If the Spanish is literary, you often need to tone it down a bit in American English.
    Example:
    “Su mirada se perdía en el horizonte.”
    Too literal: “His gaze was lost in the horizon.”
    Better: “He stared at the horizon.” or “He looked out toward the horizon.”
  5. Natural collocations
    English has fixed pairs.
    “Tomar una decisión” → “make a decision”
    “Tener una conversación” → “have a conversation”
    “Cometer un error” → “make a mistake”
    Do not translate the verb “tomar” as “take” every time.
  6. Cut repetition
    Spanish repeats nouns. English often uses pronouns or drops them.
    Example:
    Spanish: “La ciudad era pequeña. La ciudad estaba rodeada de montañas.”
    Natural EN: “The town was small. It was surrounded by mountains.”
  7. Register check
    If it is creative writing, aim for smooth and readable, not academic.
    If it is academic, keep consistent terminology and avoid slang.
If you want the English to sound less “AI-ish” or stiff, tools like make AI text sound more human and natural help smooth out phrasing and fix robotic patterns, though you still need to check nuance from the Spanish.
Drop a paragraph of your Spanish source and your translation and people can suggest specific fixes line by line.
Post the actual Spanish + your literal English when you can, that’s where the real magic happens. In the meantime, here are some things I’d add to what @cazadordeestrellas already said, from the “how do I make this feel like it was written in English first” angle:
  1. Translate intent, not structure
    Before you translate a sentence, ask: “What is this line doing?”
    • Informing? Creating atmosphere? Being ironic?
      Then build a sentence in English that does that job, even if word order or imagery changes a bit. Example:
    • ES: “Con el corazón en la mano, decidió confesarlo todo.”
    • Literal: “With his heart in his hand, he decided to confess everything.”
    • Natural US: “Heart pounding, he decided to tell her everything.”
      Same emotional function, different phrasing.
  2. Don’t be afraid to drop or swap metaphors
    Spanish loves certain images that just feel weird in English. You can keep them sometimes, but if they trip the reader, change them.
    • ES: “La noche cayó sobre el pueblo.”
    • Literal: “The night fell over the town.”
      That one works fine.
    • ES: “El silencio se apoderó de la habitación.”
    • Literal: “Silence took over the room.”
      Natural US: “The room went quiet.”
      You keep the mood, lose the melodrama.
  3. Adjust register to the character, not to the Spanish
    A lot of Spanish narrative sounds “formal” when translated literally. Ask:
    • Would a normal American say this, or just a Victorian ghost?
      For dialogue especially, cut the formality:
    • ES: “No tengo la menor idea de lo que estás diciendo.”
    • Literal: “I do not have the slightest idea what you are saying.”
    • Natural: “I have no idea what you’re talking about.”
  4. Rearrange info for English rhythm
    Spanish packs details at the start or middle. In English, sometimes you move the clause to the end for flow.
    • ES: “Cansado y empapado por la lluvia, entró en la pequeña casa.”
    • Literal: “Tired and soaked by the rain, he entered the small house.”
    • Natural: “He went into the small house, tired and soaked from the rain.”
      Same info, better rhythm for US readers.
  5. Read it out loud like an American, not like a translator
    If you stumble, or if you think “I would never say this in real life,” fix it. English fiction and essays aim for ear-friendly prose. Spanish can get away with longer, twistier lines.
  6. When in doubt, simplify one level
    If your English sounds slightly over the top, pull it back:
    • Too literal: “The pain that inhabited his chest was unbearable.”
    • Simpler: “The pain in his chest was unbearable.”
    • Even plainer (if fits tone): “His chest hurt like hell.”
  7. About “AI-ish” or stiff vibes
    If you are using machine help at any stage, you can run your draft through something like make your AI-style text sound human and natural.
    It’s especially useful for:
    • Smoothing robotic phrasing
    • Making dialogue less stiff
    • Getting more idiomatic word choices
      You still need to check it against the Spanish to be sure the meaning stays intact, but it’s a decent last step for polishing “this sounds like a robot read a bilingual dictionary” problems.
Drop a paragraph of your source + your attempt when you’re ready and people can do line by line tweaks, which is where you’ll really start seeing why things feel awkward.
Post your paragraph when you’re ready, but here are some extra angles that build on what @cazadordeestrellas already covered, without repeating their structure/intent talk:
  1. Track information density, not just style
    Spanish often crams more info per sentence. If your English line feels “heavy,” the problem isn’t just wording, it is load. Split strategically.
    • ES: One long sentence with 3 actions + 2 clauses
    • EN: Often 2 shorter sentences with one clear focus each
      Ask: “Is this doing too many things at once for English pacing?”
  2. Watch out for false friends of tone
    Some Spanish words look harmless but sound melodramatic or clinical in English.
    • “Realizar” → often just “do” or “make,” not “realize” or “carry out”
    • “Determinado” → many times “certain” or “particular,” not “determined”
      Build a personal “suspect list” as you go.
  3. Use contextual equivalents, not dictionary synonyms
    Instead of translating each noun/verb in isolation, ask what a US writer would use in that situation.
    • ES: “Se sirvió un café”
    • Literal: “He served himself a coffee”
    • Contextual: “He poured himself some coffee” or “He made some coffee”
      Aim for what fits the scene, not the word.
  4. Tame narrator distance
    Spanish narrators often sound more omniscient or authorial. In American English, close third or first person is common. If your narrator feels too far away, you can gently move inward:
    • ES-ish: “Sintió un profundo desasosiego que no podía explicar.”
    • Literal: “He felt a deep unease that he could not explain.”
    • Closer: “A deep unease crept in, and he had no idea why.”
      Same meaning, but the camera is nearer.
  5. Calibrate dialogue vs narration separately
    Many translators keep narration formal and then overcorrect by making dialogue super slangy. Try:
    • Narration: neutral, clean, not stiff
    • Dialogue: slightly more relaxed than narration, but consistent with character age / region
      If everyone talks like a TV teen or like a textbook, something is off.
  6. Use micro-cuts to de-Spanish-ify rhythm
    When a line almost works but feels “translated,” cut tiny bits rather than rewriting everything.
    • Remove unnecessary “that” or “which”
    • Drop repetitive adjectives
    • Swap “however” → “but,” “therefore” → “so,” when tone is casual
      Small cuts often fix the “I can smell the source language” issue.
  7. Read in pairs: your version vs a similar English book
    Pick a US novel or essay that matches your text’s vibe. After you translate a page, read a page of that book. Pay attention to:
    • Sentence length
    • How often they use figurative language
    • How they start and end paragraphs
      Then adjust your page to feel like it can sit next to that one.
  8. Tool help: where something like Clever AI Humanizer fits
    If you are already doing the careful, line-by-line work, a tool like Clever AI Humanizer can be useful as a final pass when:
    • You want to smooth slightly robotic phrasing
    • You are tired and need “fresh” suggestions for more idiomatic structures
      Pros:
    • Can surface more natural turns of phrase you might not think of
    • Good for cleaning up stiffness from earlier literal drafts
    • Fast way to spot over-formal or repetitive patterns
    • It does not know your Spanish original, so it can quietly drift from the meaning
    • It might over-flatten style and erase deliberate quirks of voice
    • If you accept changes blindly, you end up with generic prose
      Best use: run your human translation through it, then check every change against the Spanish and your intended tone. You stay in control of meaning and voice.
  9. Tiny place where I’d mildly disagree with some advice
    You were told to freely drop or swap metaphors, which is often right, but be careful not to over-normalize. If a metaphor is central to the author’s style or theme, I would rather keep it slightly strange and make it work in English than replace it with something bland. Odd but deliberate images can be part of the book’s personality.
If you post 1–2 paragraphs with your attempt, people can help you fine‑tune rhythm, tone, and metaphor choices line by line, which will teach you more than generic rules.
