Need help understanding how the Tamasha App really works
I recently downloaded the Tamasha App after hearing about its features, but I’m confused about how to use it properly and get the most out of it. Some options and settings aren’t clear, and I’m not sure if I’m missing important steps or features. Can someone explain how the Tamasha App is supposed to work, share tips for setup, and point out any common issues or limitations I should know about?
Tamasha is a bit confusing at first, but once you map the sections it feels simpler. Quick breakdown so you do not miss features:
  1. Home feed
  • This is where promoted streams and trending shows appear.
  • Use the categories or tabs on top to filter, like Sports, Entertainment, Games, etc.
  • If you see random stuff you do not like, open one stream, tap the three dots, and hit “Not interested” so the algo stops pushing similar ones.
  1. Live streams
  • Tap any live stream card.
  • You get chat, gifts, and follow button on the same screen.
  • Gifts cost coins. Do not recharge until you check the prices and how fast they burn. Many users over-spend here the first time.
  • If your chat messages never show, check if “Slow mode” is enabled by the host or if you wrote a banned word.
  1. Coins, diamonds, and gifts
    This part confuses most new users.
  • Coins: Used to buy gifts. You pay real money for them.
  • Gifts: You send them to streamers. Some gifts convert to diamonds for the host.
  • Diamonds or points: Streamer side currency. They withdraw it or convert it to other perks, depending on region.
  • Before recharging, open your profile, then “Wallet” or “Balance” and screenshot the rates. Do a small test recharge first.
  1. Going live yourself
  • Tap the “+” or “Go Live” button at the bottom.
  • Choose type: solo live, audio room, or party room if available in your app version.
  • Set a clear title. Example: “PUBG Mobile ranked matches” or “QnA about exams” instead of “Come join”.
  • Check these before you start:
    • Front or back camera selected.
    • Mic level not muted.
    • Beauty filters off or low if you want less lag.
  • Use WiFi with at least 5 to 10 Mbps upload. If your stream keeps freezing, lower video quality in the live settings.
  1. Profile and settings
  • Go to “Profile” bottom right.
  • Tap the gear icon. Key things to check:
    • Notifications: Turn off “All live notifications” if phone spam bothers you. Keep “From followed hosts” only.
    • Privacy: Decide who can message you, who sees your online status, and whether your profile appears in recommendations.
    • Language and region: Pick the right ones so you see local content instead of random foreign rooms.
  1. Levels and badges
  • Watching streams, sending gifts, and chatting increases your user level.
  • Higher level sometimes unlocks chat colors, profile frames, or entry animations.
  • For hosts, more streaming time and viewer engagement adds to level and potential earnings.
  • If you care about growth, track daily watch time and hosting time in the app’s stats section if it exists for your account.
  1. Common hidden stuff people miss
  • Daily tasks: Often under “Tasks” or “Rewards”. You get free coins, entry coupons, or simple bonuses for logging in, watching X minutes, or sharing a stream.
  • Events: Tap the banner on top of the home screen. These events give rankings and rewards, like top gifter or top host during a timeframe.
  • Block and report: Long press a message in chat or tap a user profile, then block if they spam or harass. Report serious abuse instead of arguing.
  1. If something feels off
  • Lag or black screen:
    • Switch from mobile data to WiFi.
    • Close other apps that use internet.
    • Lower video quality.
  • Coins missing:
    • Check purchase history in your profile wallet.
    • Then check gift history.
    • If numbers still look wrong, contact support through “Help” or “Feedback” in settings with screenshots.
  • Region lock: Some content only shows in certain countries. Use correct country in your profile. If you spoof location, features might bug out.
If you describe which options confuse you, like “wallet screen” or “live settings”, people here can give more exact steps with screenshots or a short walkthrough.
Couple of extra angles on top of what @chasseurdetoiles already dropped:
  1. Start by “breaking” the app on purpose
    Don’t worry about doing everything “right.” First day, just tap stuff and see what actually changes:
  • Join 3–4 random lives, mute/unmute, flip chat on/off, try sending free stuff (likes, emojis) only.
  • Open your profile and tap every menu item once. You’ll remember where things are way faster than by reading any guide.
  1. Fix your feed before anything else
    Instead of just using “Not interested,” also:
  • Long-press or open creator profiles you do like and follow a few. The app’s algo overreacts to follows and watch time. Watch 5–10 minutes of what you enjoy and swipe fast past what you hate. Your home screen gets usable in a day or two.
  • If you keep seeing stuff in a language you don’t understand, double check: Profile → Settings → Language/Region. Sometimes it silently auto-picks wrong region.
  1. Wallet confusion shortcut
    The whole “coins / diamonds / gifts” system is intenionally confusing so you spend more, ngl. To stay safe:
  • Decide a hard monthly budget before you even open the wallet. Example: “I will not cross 5 bucks this month.”
  • Turn off auto-recharge in your phone’s app store if it’s on.
  • Use one “test night”: buy the smallest pack, spam a couple gifts, then check: Wallet → transaction history → gift history. That shows you exactly how fast the balance melts.
  1. Going live: treat your 1st stream like a test broadcast
    Instead of trying to “grow” on your first live:
  • Start a private or unlisted test (if available) or go live at an odd hour.
  • Talk out loud, tap all icons, intentionally switch cameras, turn beauty filter max / off and see how it affects lag.
  • Watch your own replay for 30 seconds. If the audio is trash, fix that first before worrying about thumbnails or titles.
  1. Notifications: nuke them early
    I slightly disagree with @chasseurdetoiles on just tweaking. First week, I’d go harder:
  • Turn almost everything off except “messages” and “system / security.”
  • Then, if you actually start following a few streamers you care about, re-enable “from followed hosts” only. Otherwise Tamasha will spam you into uninstalling.
  1. Safety & weird vibes
    Stuff most new users don’t think about:
  • If anyone asks you to move to WhatsApp / Telegram / whatever instantly, that’s a red flag. Keep convos inside the app until you’re sure.
  • Use “Block” more than you think. Trolls get bored when they can’t see you.
  • Check if there’s a “Hide location / city” toggle in privacy. Turn that off so you’re not broadcasting your area.
  1. How to know you’re “using it right”
    You’re basically using Tamasha “properly” if:
  • Your home feed shows mostly stuff you actually watch.
  • You know exactly how much real money you’ve spent and where it went.
  • You can go live and not panic because you roughly know what every button does.
  • You can mute, block, and report without hunting through menus.
If you want, drop which screen looks the most confusing (wallet, live-prep, profile, etc.) and what phone you’re on, and people here can walk you through that page specifically, step by step.
Couple of angles that weren’t covered yet, especially if you feel “I installed Tamasha and now I’m just… staring at it.”
1. First decide what you want Tamasha for
The app behaves very differently depending on your goal:
  • Passive watcher: Mostly shows, sports, random lives.
  • Social / chatting: Hanging out in rooms, voice chats.
  • Aspiring host: Going live regularly, trying to earn.
Before you dive into obscure settings, decide your main use for the next week. That choice should drive what you touch first:
  • Watcher: Focus on feed, search, and blocking junk.
  • Social: Focus on chat tools, blocking, rooms.
  • Host: Focus on bitrate, layout, and moderation tools.
Without this, Tamasha just feels like noise.
2. Content discovery beyond the Home feed
Both @sognonotturno and @chasseurdetoiles covered the Home area, but Tamasha hides a lot of better stuff behind secondary tabs:
  • Use search: Type a game, language, or topic (“cricket,” “study,” “English chat”) and then actually follow 3–5 creators you like from there.
  • Check “categories” inside search: Often cleaner than the main Home mess.
  • Look for “Recommended rooms” below a live: The second or third suggestion is often closer to what you want than the main Home screen.
If after 2–3 days your recommended Tamasha App lives still look totally random, log out and back in, then re-set language and region. It sometimes bugs and caches bad recommendations.
3. Subtle settings that really matter
Some stuff is easy to miss but changes the whole feel of Tamasha:
  • Auto play: If there is an option to auto-play lives on WiFi / mobile, turn auto-play on WiFi only. Saves data and prevents sudden loud streams in public.
  • Chat overlay: In some versions you can reduce chat opacity. If you mostly watch games, set chat to semi transparent so you actually see the gameplay.
  • “Do not disturb” mode: If available, this stops random call-style popups while you are watching. Very useful if you do not care about incoming invites.
I slightly disagree with the idea of toggling every setting once as a beginner. Tampering with too much can break your mental model. Start with: notifications, language/region, privacy, and network preferences; ignore the rest for a few days.
4. Hosting: think “room control” more than “performance”
Everyone talks about filters, camera, bitrates. What usually makes or breaks a Tamasha live is whether you can control your room:
  • Check who can comment: If there is an option like “followers only” chat, that is gold when trolls appear.
  • Prepare 1–2 trusted regulars as moderators once you start getting viewers. Give them power to mute or block.
  • Pre-make 2–3 pinned messages (if Tamasha supports pinning):
    • “Respectful chat only, no spam.”
    • “Language here: [your language].”
    • “No off-platform contact requests.”
Your first few lives are basically for learning which tools you want to have open: mute list, ban list, or viewers list. Performance tweaks like 720p vs 1080p are secondary unless your stream is literally freezing.
5. Money: treat the wallet like a subscription, not a casino
The coins / gifts / diamonds system in the Tamasha App really is designed to blur what you actually spend. Instead of just “do a small test recharge,” try this more structured approach:
  • Decide a per-stream ceiling as well as monthly. Example: “I never spend more than $1 in a single stream and $5 per month.”
  • Keep a simple note on your phone: “Tamasha spend: date / amount / streamer.”
  • If you ever feel the urge to top up during a live “just one more time,” that is your signal to close the stream for 10 minutes.
Pros of this system:
  • You enjoy supporting creators without bill shock.
  • You notice quickly if a certain host is only engaging when you send gifts.
  • Slightly more mental overhead.
  • Can feel restrictive if you are used to spontaneous tipping.
6. Social dynamics nobody warns you about
Tamasha, like most live platforms, has its own unspoken rules:
  • Hosts remember consistent chatters more than big one-time gifters. A couple of thoughtful comments every visit is worth more than one huge virtual item.
  • Rankings and “top gifter” boards can quietly pressure you to spend. If you notice you care too much about your rank, hide or ignore those lists.
  • Leaving a live quietly is normal. You do not need to say goodbye to everyone, especially if the vibe turns weird.
If a host or viewer tries to guilt-trip you for not gifting, that is a good test of whether you want to stay in that room long term.
7. Pros & cons of using the Tamasha App as your main live platform
  • Variety of content (games, casual chat, events) in one place.
  • Interactive features like rankings, events, and gifts can be fun if you keep control of spending.
  • For hosts, relatively easy entry: just a phone, stable net, and you can go live.
  • Social vibe can feel more “room-like” than some bigger, more anonymous platforms.
Cons
  • Confusing currency and reward structure, especially at first.
  • Notifications and promotions can feel spammy if not tuned down.
  • Quality and moderation vary a lot between rooms; some spaces can be toxic.
  • App performance and features can differ by region and version, which makes following guides a bit hit-or-miss.
8. How what you already read fits in
  • @sognonotturno gave a very “test-and-break things” approach, which is great once you are not overwhelmed.
  • @chasseurdetoiles focused on mapping sections and being careful with gifts, which is solid if you like structure.
If you are still lost, pick one specific thing to fix next, not all of them at once. For example:
  • “I only want to see sports in my feed.”
  • “I want to go live but hide my city and control who messages me.”
  • “I want to spend $3 per month without confusion.”
Drop which of those fits you and what phone / OS you are on, and people can outline exact screens to tap for that one goal. Once that is sorted, move to the next.
