Need help with my Revvl 8 Pro
My Revvl 8 Pro suddenly started having problems, and I can’t figure out what caused it. It was working fine, then it began freezing and acting glitchy, and now I need help troubleshooting it so I can get it working normally again.
Start with the easy stuff.
  1. Force restart the phone. Hold Power and Volume Up for about 10 to 15 seconds.
  2. Check storage. If you have under 5 GB free, Android starts to lag and freeze. Delete big videos, old downloads, and unused apps.
  3. Update everything. System update first, then apps in Play Store.
  4. Boot into Safe Mode. Hold Power, touch and hold Power off, then tap Safe Mode. If the phone runs fine there, a bad app is the cause.
  5. Clear cache on problem apps. Settings, Apps, pick the app, Storage, Clear cache.
  6. If it freezes all over the system, wipe cache partition if your model allows it, or clear system temp files through Device Care.
  7. Check battery health and heat. If it gets hot while doing nothing, sometihng is stuck in the background.
  8. Last step, back up your stuff and do a factory reset.
If it started right after an update, that matters. If it started after a drop, water, or charging issue, that matters too. Post how much free storage you have and whether Safe Mode helps. Tha narrows it down fast.
I’d add a couple things on top of what @himmelsjager already said, because freezing is not always just “clear cache and reset it.”
First, check RAM behavior in Developer Options if you can enable it. If one app or service is constantly sitting at the top, that’s a clue. Social apps, keyboard apps, cleaners, and battery saver junk are common offenders. I’d actually uninstall any “optimizer” app before doing anything else. Those apps love to claim they fix lag while quietly causing it.
Also, look at Accessibility services. Stuff like screen dimmers, auto clickers, overlay apps, floating toolbars, and some antivirus apps can make Android act super weird. Same with custom launchers. Temporarily switch back to the stock launcher if you changed it.
Another angle is charging. If the glitches happen mostly while plugged in, try a different cable and charger. Bad power can cause ghost touches, stutter, and random freezing. Sounds dumb, but I’ve seen it more than once.
If the touchscreen is glitchy, test it with the built in diagnostics menu if T-Mobile left that enabled, or use a simple touch test app. If dead zones showed up out of nowhere, that points more toward hardware than software.
One place I kinda disagree with @himmelsjager is jumping too quickly to a factory reset. It helps, sure, but if the phone is freezing because the storage chip is starting to fail, reset won’t fix squat. Watch for signs like apps taking forever to install, camera failing to save photos, or reboots during file transfers.
If you can, note 3 things:
  1. does it freeze in every app or only certain ones
  2. does it happen on Wi-Fi, mobile data, or both
  3. did it start after a specific app install
That narrows it down way faster than just nuking the phone and hopng for the best.
A thing I’d check that neither @himmelsjager nor the follow-up really leaned on is thermal throttling. The Revvl 8 Pro can get weird when it’s running hot, especially after an update, bad background sync loop, or weak signal area. If the phone freezes more when using camera, Maps, gaming, or video calls, heat might be the trigger. Take the case off for a day and see if behavior changes.
I also would not assume it’s an app right away. Sometimes Android system updates finish badly in the background. Go to Settings > Security & privacy > System update and also update Google Play system update if available. Then reboot twice. Sounds silly, but I’ve seen pending Play system patches cause laggy UI and random hangs.
Another overlooked one is storage health, not just storage space. If you’re under 10 to 15% free space, performance can tank hard. Clear out large videos, offline downloads, and old WhatsApp or Telegram media before deeper troubleshooting.
Try this too:
  • boot into Safe Mode
  • use it for 15 to 30 minutes
  • if freezing stops, it is almost certainly third-party software
  • if it still freezes there, that pushes suspicion toward system corruption or hardware
One small disagreement with @himmelsjager-style advice people often give: wiping cache partitions is not the magic bullet it used to be on older Android phones. Useful sometimes, sure, but not where I’d start.
Pros for the ‘’: can improve readability if it’s some screen-related accessory or utility item.
Cons for the ‘’: not relevant unless your issue is visibility or handling, so it won’t fix the root cause.
If safe mode is bad too, back up your stuff and then factory reset. If it still glitches after a clean reset with only basic apps installed, I’d call that hardware until proven otherwise.
Try a network isolation test. Turn on Airplane Mode, then enable Wi-Fi only. Use the phone for 30 minutes.
If freezing stops, the probelm likely involves mobile signal, SIM, or carrier settings. Power off, remove and reinsert the SIM, then reset network settings under Settings > System > Reset options > Reset Wi-Fi, mobile, and Bluetooth.
This erases saved Wi-Fi passwords and Bluetooth pairings, but leaves your photos and apps untouched.
Honestly all these tests pile up fast and it’s easy to lose the plot. Safe Mode is the one that actually splits the problem in half, so do that before anything else. If it freezes clean in Safe Mode with no third party apps loaded, you’ve basically ruled out the app theories @yozora and @sternenwanderer are chasing and you’re looking at system or hardware.
The one thing I’d push back on is running five different isolation tests at once. If you clear cache, reset network, and pull the SIM in the same sitting and it gets better, you won’t know which one did it. Change one thing, use the phone a bit, then move on.
And yeah, if it started right after an OTA and Safe Mode is still bad, don’t burn hours on this. That’s when a reset is worth it, not as step one.
