I’ve been testing VideoProc Converter AI and I’m not sure if my experience is typical or if I’m missing key settings or features. Some videos convert well, others lose quality or have sync issues, and the AI enhancements are hit-or-miss. Can anyone explain how to properly set it up for the best results, and share whether it’s really worth using compared to other converters?
Yeah, what you see is pretty normal for VideoProc Converter AI. It is decent for quick jobs, but it breaks in some edge cases. Here is what usually helps.
Check source and target settings
• Match FPS. If source is 23.976 and you output 30 or 60, you often get sync drift. Set output FPS to “Same as source”.
• Match audio sample rate. Use 48 kHz if source is 48 kHz.
• Do not force VFR to CFR unless you need it. VFR sources can desync if you lock to a different FPS. -
Bitrate and quality
• For 1080p, try 8–12 Mbps for H.264, 5–8 Mbps for HEVC.
• For 4K, aim 25–45 Mbps for H.264, 18–30 Mbps for HEVC.
• If you use a “target size” mode, quality often tanks. Use constant quality (CRF style) if the app offers it, or a fixed bitrate. -
Hardware vs software encoding
• GPU encoding is fast but softer and sometimes glitchy. On some NVIDIA cards I see micro desync on long clips.
• Try switching to software (CPU) encoder for a test. If sync issues vanish, the GPU path is the problem.
• Disable “Auto copy” for audio and force AAC reencode. Mixed codecs in source files sometimes cause sync weirdness. -
AI enhancement quirks
• AI de-noise and AI sharpen often fight each other. Use only one at a time.
• For AI upscale 1080 to 4K, expect plastic faces if the strength is too high. Start at the lowest strength and move up.
• Do AI enhancement in a separate pass. First convert to a clean mezzanine file (like high bitrate H.264), then run AI on that. Fewer artifacts and fewer sync issues. -
Problem sources
• Screen captures, VFR phone videos, and long MKVs from streaming rips are the worst.
• For these, remux first with something like MKVToolNix or ffmpeg copy, then feed that file into VideoProc. This strips weird timestamps that confuse the app. -
Quick tests before doing big batches
• Take a 2 minute clip from each source type.
• Try one with AI off, one with AI on, GPU off, GPU on.
• Check for: lip sync at the end of the clip, banding in gradients, ghosting on motion, and audio glitches.
Honest take. For simple Blu-ray rips and camera footage it works ok if you respect FPS and audio settings. For mixed, messy internet sources and heavy AI filters, it behaves like a flaky front-end. If you want consistent results with fewer surprises, ffmpeg or Hybrid are safer but less friendly.
Yeah, what you’re seeing is pretty “normal weird” for VideoProc Converter AI. @byteguru already nailed a lot of the tech side, so I’ll try not to just repeat the same knobs and sliders.
A few extra angles to check that often get missed:
Profile vs manual settings
The built‑in presets are all over the place. Some secretly change FPS, color range, or audio layout, which leads to “why does this file look fine and that one look like mush?”
Try this: pick a preset that is closest to what you want, then manually open the advanced options and save your own custom profile. Reuse that exact profile for all tests. If your quality and sync suddenly become consistent, the presets were the chaos. -
Keyframe interval & seeking issues
Not mentioned much in the marketing, but:
• If your keyframe interval is huge, some players show weird “desync” when you scrub, even though the file is actually in sync.
• Set keyframe interval to about 2x your FPS (so ~48–60 for 23.976/25/30 fps).
This will not magically fix every sync bug, but it makes playback more reliable across players. -
Color & detail “loss” that looks like a bug but isn’t
A lot of people blame VideoProc for “washed out” or “faded” output when what’s happening is:
• Input: limited range (TV)
• Output: full range (PC) or vice versa
Some presets toggle that behind your back. Compare in the same player, with the same color settings, and try disabling any “enhance” / “improve playback” options in your video player. VLC and some GPU control panels love to “help” and just confuse the test. -
AI filters: pick a lane
You already noticed AI enhancements being inconsistent. I’d go a bit stronger here than @byteguru and say: using multiple AI filters in one go is almost always a bad idea in this app.
• AI denoise + AI sharpen + upscale = crunchy, waxy nonsense half the time.
• AI “stabilization” or motion related stuff on top of that? Even worse for sync.
I’ve had the best luck choosing one primary AI goal per file:- Just upscale
- Just denoise
- Just sharpen faces
Anything more and VideoProc feels like it’s guessing.
Don’t trust the preview window too much
The internal preview is not always identical to final export. I’ve seen:
• AI artifacts visible in preview but mostly gone in export
• Slight audio offset in preview that wasn’t in the file
So do tiny 10–20 second exports from a “problem” scene and check those in a proper player. Saves you from throwing the whole app out because of a misleading preview. -
Check the player for sync issues
Especially with long MKVs or VFR phone clips:
• Test in at least 2 players (say, VLC and MPV or your OS default).
I’ve had files from VideoProc that looked out of sync in one player and totally fine in another. If every player shows drift, that’s on VideoProc. If only one does, it is a playback quirk. -
Audio track weirdness
When you say “some videos” have sync issues, check if those are the ones with:
• Multiple audio tracks
• 5.1 or 7.1 surround
• AAC + something else in the same container
VideoProc gets confused by mixed audio setups more often than it should. You can actually try stripping down to a single stereo track first in another tool and then converting, just to see if the problem disappears. If it does, the app is choking on the track layout, not the video itself. -
Be realistic about what its AI actually is
Marketing makes it sound like Topaz + DaVinci Resolve + ffmpeg in one click. It’s not.
Think of it more like “slightly smarter filters on top of a mid‑tier converter.” You’ll get:
• Nice improvements on clean sources (Blu‑ray, decent camera footage)
• Very hit‑or‑miss results on noisy, compressed web rips or old TV caps
If you’re feeding it bad 480p YouTube grabs and expecting miracle 4K with perfect lipsync, it’s just not built for that. -
Figure out if your issues are:
- Consistent: “Every phone clip > 20 minutes goes out of sync by 300 ms near the end.”
- Random: “Sometimes it’s fine, sometimes it’s a mess with the same settings.”
Consistent problems usually mean a setting mismatch (fps/audio/container). Random behavior smells more like GPU encoder flakiness, unstable AI path, or a bug in the specific version you’re on. In that case, try:
• One run with AI totally off
• One run with GPU encoding off
• One run without changing container (MKV to MKV, not MKV to MP4)
The one that behaves tells you who the real culprit is.
So yeah, your experience is pretty typical:
- When the stars line up (simple source, sane settings, light AI), it looks surprisingly good.
- When you throw messy sources + multiple AI filters + hardware encode at it, it behaves like a fancy wrapper around a fragile workflow.
If you’re willing to keep using it, I’d treat VideoProc as your “quick job, simple profile, single AI filter” tool, and not the all‑purpose black box that the ads promise.
You are not crazy. VideoProc Converter AI is one of those “great when tamed, awful when left on auto” tools.
Let me hit the parts that often sit under what @byteguru and the other reply already covered, and slightly disagree in a couple of places.
1. Where the AI is actually worth using
I’d narrow VideoProc Converter AI’s “good” use cases to these:
Pros (when it behaves):
- Very fast hardware encode + light AI sharpen for YouTube / streaming copies
- Mild AI denoise on clean but slightly grainy camera footage
- Upscale from 720p to 1080p for casual viewing
Cons (where it falls apart):
- Old interlaced TV captures
- Mixed frame rate phone footage (clips spliced from camera + apps)
- Anything with heavy compression artifacts, especially low‑res web grabs
If most of your problem files fall into the second category, no setting voodoo will make VideoProc Converter AI feel consistent.
2. Why some encodes “look worse” even with similar settings
The part I’d emphasize more than others is source complexity:
- Two 1080p files at similar bitrates can be wildly different.
Clean anime vs noisy handheld night video. - VideoProc’s rate control is not as “smart” as something like x264/x265 in pro tools.
It often underfeeds the hard shots, overfeeds the easy ones.
So if file A and B both get 6 Mbps but B has more motion or noise, it will look like it took a huge quality hit and it is not just a setting screwup.
Workaround:
For “messy” sources, temporarily raise bitrate or lower resolution. For example, instead of 1080p at 4–5 Mbps, try 720p at similar bitrate. You often get a more stable look and fewer AI artifacts.
3. Slight disagreement: AI filters in combination
The previous reply warned hard against stacking AI effects. I mostly agree, but with a nuance:
- Stacking is bad if the strength of each filter is high.
- It can be fine if each effect is dialed down and you keep it to 2 passes at most.
What has worked decently for me:
- First pass: AI denoise only, moderate strength, export to a high bitrate intermediate.
- Second pass: Basic encode with a very mild sharpen or upscale.
Doing both in one go inside VideoProc Converter AI often goes plasticky. Splitting into two conservative passes keeps the “AI look” from going nuts.
Yes, this is slower, but if you have a few “important” videos, it can be worth the hassle.
4. Handling audio sync in a more “brute force” way
If you keep seeing sync drift only on some files, especially long ones, try this workflow:
- Extract audio first with another tool (even something basic that just demuxes to WAV/FLAC).
- Feed VideoProc Converter AI the video and mute audio in the settings.
- Re‑mux your clean audio back afterward with a container tool.
This is annoyingly manual but very effective for:
- Variable frame rate phone recordings
- Long MKVs with weird audio layouts
If that fixes your problems, the issue was how VideoProc handled audio timelines, not your hardware or AI choice.
5. Hardware quirks that look like AI bugs
A lot of “AI is glitchy” complaints are actually GPU encoder issues:
- Some GPUs get unstable on long encodes with certain drivers.
- You see random artifact bursts, single‑frame corruption, or slight drifts.
Troubleshooting trick:
- Keep AI on but flip hardware encoder off for one test.
- If the sync and glitches vanish, it is your GPU path, not AI.
Yes, this can make VideoProc Converter AI slower, but at least you will know if the accelerator is the weak link.
6. Comparing VideoProc Converter AI to other tools (without turning this into a promo)
To keep it honest:
Pros of VideoProc Converter AI:
- Simple UI for quick jobs
- Fast on supported GPUs
- One of the easier “all in one” tools for non‑editors
- Reasonable AI upsizing for decent sources
- Inconsistent on messy or mixed‑format footage
- AI stack can go ugly fast if pushed
- Audio timeline handling is not bulletproof
- Less transparent control compared to pro encoders
That is why many people (including @byteguru) treat it as a quick converter with some nice AI sprinkles, not a replacement for more specialized tools.
7. How to decide if you should stick with it
Use this practical test:
Take three typical source types you work with:
- Clean HD (Blu‑ray / good camera)
- Noisy or low‑light
- Phone footage / mixed clips
Make one conservative profile:
- Same resolution as source
- Bitrate slightly higher than what you usually use
- Only one AI function, moderate level
Run all three, watch entirely in a proper player, and note:
- If type 1 is consistently good, type 2 “meh but usable,” and type 3 a mess, that is just its design ceiling.
- If even type 1 and 2 are unpredictable, then your version / GPU / audio layout is the real issue.
If it passes that test, VideoProc Converter AI is worth keeping as a “fast, simple job” tool. If it fails even on clean sources, I would restrict it to trivial conversions and do any “important” work elsewhere.
You are not missing a secret setting. You are mostly running into the app’s real limits, which are a lot lower than the marketing suggests.
Simpler approach. Normalize before VideoProc.
- Use HandBrake. Preset Fast 1080p30.
- Frame rate Same as source. Constant frame rate.
- Encoder x264. RF 19 to 21.
- Deinterlace Decomb default if needed.
- Audio AAC 48 kHz 160 kbps.
- Export an intermediate MP4.
Then run VideoProc for light AI or straight encode. Keep resolution same. Set bitrate a bit higher than target. This removes VFR drift and weird audio layouts. It evens bitrate demand. In my tests, a 45 minute VFR phone clip stayed in sync. Try it on three vidoes first.
