Need to Replace CyberDuck After Unreliable Transfers
I’ve tried a clean reinstall and recreated my connection settings, but CyberDuck still behaves less reliably than I expected during routine transfers. Before I replace CyberDuck, are others seeing the same inconsistency, or does this sound more like something specific to my setup?
The major error consists of considering both options as the variations of the same FTP client. In fact, they address completely different issues. I would decide according to the current priorities: whether it is more important to make remote files editable as the local ones or maintain a stable transfer session.
My choice would be based on the test procedures. If the remote file editing is frequently used, as the ability to mount the server as a local drive eliminates the step of downloading and uploading changes. It can be convenient for a user who actively works with remote data and wants to avoid extra steps in their editing procedure. This function also addresses the requirement of mounting the same S3 and SFTP services.
On the other hand, the need to transfer large messages or repetitive batches of information is more common on Windows. The concerns associated with the interruptions, resuming, and memory consumption are deal-breakers for me. Thus, I prefer a traditional interface that explicitly states that the file has to be sent to the distant server rather than integrated into the local directory structure.
For the mounted-drive approach, CloudMounter drive access is the option I would evaluate. It avoids the traditional FTP transfer interface by presenting servers as local drives. I would still verify save behavior with the specific editor and server before relying on it for routine work.
On Windows, WinSCP transfer client is the more direct choice when connection stability is the main requirement. Its useful points are graceful handling of drops, automatic transfer resumption, and low RAM use. That is a conventional FTP connection workflow, but a dependable conventional process may be preferable to a more transparent one.
Which procedure matters more in your case, editing remote files in place or keeping long transfers stable?
Replacing Cyberduck before ruling out the server or network is backwards. Repeat the same transfer in another client with the same protocol, account, and files. If both clients disconnect at a similar point, check the server logs, host timeouts, VPN or Wi-Fi interruptions, and available disk space. If the failure only follows Cyberduck, then you have a solid reason to move on.
I’d treat CloudMounter as a convenience tool rather than a way to diagnose transfer trouble. It is still something I’d reach for, but the cost is difficult to justify if your entire workload is basic uploads and downloads. For large or unattended batches, prioritize visible queues, automatic retries, checksum verification, and detailed logs. Those logs will tell you far more than switching apps at random.
You do not need to prove Cyberduck is uniquely at fault before replacing it. @cursor.dev’s comparison test is useful for finding the root cause, but software used for routine transfers should not require constant babysitting.
Test the workload that actually fails. A single large file may succeed while a directory containing many small files exposes reconnect, overwrite, or temporary-file rename problems. Sleep and network switching can matter too, so include those conditions if they are part of your normal use.
I would use CloudMounter for a trial period and keep Cyberduck installed as a fallback. Compare the remote file count and verify a few checksums after each batch. If the errors disappear, move on. If they follow you, the client was probably never the main problem.
The hidden trap is that a “clean reinstall” often leaves preferences, bookmarks, saved credentials, and support files behind. Recreating the visible connection may not reset whatever is causing the bad behavior. A quick way to test that is to create a temporary macOS user account, configure the connection there, and repeat a transfer that normally fails.
The failure pattern can narrow it down without turning this into a major investigation. If it stops on the same filename, look at permissions, path length, or unusual characters. If it fails after sitting idle, suspect a timeout. Random stalls during folders full of files may point to transfer concurrency, so set simultaneous transfers to one and try the batch again.
I would use CloudMounter as the replacement, but I would change the upload workflow at the same time. Send each batch to a staging directory, then move it into its final location after completion. That prevents interrupted uploads from leaving incomplete site files or backups where another process might treat them as finished.
@cursor.dev is right about keeping a useful log, although I would not spend days proving the case. If Cyberduck still fails from a fresh user profile while a second client completes the identical batch, that is enough evidence to stop babysitting it. Save the final error log in case the same symptoms return with the replacement.
A completed transfer is not proof that the replacement is more reliable. Before switching, test a folder containing hidden files, symlinks, executable permissions, and an overwritten file, then confirm those details survived on the server.
This matters especially with mounted-drive tools, because Finder or an editor may report success while remote metadata or temporary-file handling differs from a normal transfer client. Keep Cyberduck installed until the replacement has handled several real batches without missing files or changing permissions.
If the new client completes the same troublesome workload and preserves everything correctly, replacing Cyberduck is entirely reasonable. Reliability includes the final server state, not merely reaching the end of the progress bar.
The exact protocol matters here. “Cyberduck is unreliable” can mean something very different with FTP, SFTP, WebDAV, or S3, and that should drive the replacement choice.
For SFTP, try the built-in command-line sftp client with the same troublesome folder. It is free, basic, and removes most GUI behavior from the equation. If that transfer completes repeatedly while Cyberduck stalls, I would stop reinstalling and replace it.
I’m less enthusiastic about CloudMounter for large batches. Mounted storage is handy for opening and saving individual files, but it can hide the queue and retry details you actually need when transfers go wrong. For routine uploads and downloads, pick a normal transfer client that exposes failed items clearly and lets you rerun only those files. Keep the mounted-drive approach for convenience, not as the default answer to transfer failures.
A transfer that dies at the exact same byte every run is a completely different animal from one that quits at random points. The first is almost always the server, the file, or the path. The second smells like the network layer or the client’s session handling. Nobody in here has really split those two apart, and it changes what you do next.
So before you go client shopping, watch how it fails a few times. If it stalls on the same object every time, @byteguru already pointed you the right way with permissions and weird characters, and I’d add path length on deeply nested folders since that trips more clients than people expect. If it’s random, look at power settings and any energy saver that lets the network sleep, plus whatever your router does with idle connections. macOS quietly parking Wi-Fi during a long push is a classic and it will make any client look broken.
I’ll push back a little on the idea that the built-in command line proves much on its own. It’s genuinely handy for stripping GUI noise, but plain sftp uses different defaults for keepalives and concurrency than Cyberduck does, so a ‘clean’ command line run can pass simply because it’s only pushing one stream. If you want the comparison to mean anything, force Cyberduck down to a single simultaneous transfer first, then compare. Otherwise you’re testing two different workloads and calling it the same test.
For the mounted-drive route I’d have CloudMounter sitting there for the odd time I just need to crack open one remote file and save it back without spinning up a whole transfer queue. That’s a separate use from bulk moving, and I wouldn’t lean on it while you’re still hunting an intermittent drop, because a mount can silently retry underneath you and hide the very behavior you’re trying to catch.
My actual take: pick one folder that reliably fails, turn on the fullest log Cyberduck offers, and reproduce it twice. You’ll usually see the answer in the log before you ever install a replacement, and if the log clearly shows the server hanging up or the disk filling, no new client saves you.
Crowd reports won’t settle this. If these are repetitive folder transfers, I’d stop comparing GUI clients and use a sync tool suited to the protocol, such as rsync over SSH or rclone for cloud storage. You get clear exit codes, repeatable commands, and only changed files are resent. Keep a GUI for occasional browsing, but routine transfers should be easy to rerun without babysitting a queue.
