I need help recovering files from a USB drive after they suddenly disappeared. The drive is still detected by my computer, but all my documents and photos seem to be gone. I really need these files back and would appreciate advice on safe USB data recovery steps or tools that might help.
If I were in your spot, I’d start with data recovery software, assuming the flash drive still behaves like a normal drive. If it is missing from the system, reports 0 bytes, drops connection every few seconds, or gets hot for no clear reason, I’d stop there and treat it like a hardware problem. For the common situation, deleted files, drive still readable, software is the cheaper first move and usually the sane one.
First thing, and yeah this matters more than people think, stop writing anything to the USB drive. Don’t paste files onto it. Don’t format it. Don’t run random cleanup stuff. On USB drives, deleted files usually do not sit in the normal Recycle Bin. The file system marks the space as available, and your old data stays there until new data lands on top of it. Once you overwrite it, the odds drop fast.
Before you scan, I’d do a boring check anyway because I’ve seen people swear files were deleted when they were hidden, moved, or copied somewhere else weeks ago.
- Show hidden files on the USB and look through it manually.
- Check for folders like $RECYCLE.BIN, RECYCLER, RECYCLED, or .Trashes if the drive touched a Mac.
- Look in your computer’s Downloads, Desktop, Documents, and any sync folders.
- Check backups and cloud stuff, File History, OneDrive, Google Drive, Dropbox, whatever you use.
If none of those turn up anything, I’d move on to recovery software.
The tools all have their own quirks. Different scan methods, different file support, different preview quality. Still, the workflow stays close to the same:
- Install the recovery app on your computer, not on the USB drive.
- Connect the USB and pick it inside the app.
- Run a deleted file or lost file scan.
- Let the scan finish. Cutting it short is how people miss the stuff they cared about.
- Use filters if the app supports them, file type, name, date, size.
- Preview files when possible.
- Select what you need.
- Save recovered files to your computer or another drive, never back onto the same USB.
I’m repeating the last part because people do it anyway. Recovering back to the same flash drive risks overwriting other deleted files you have not pulled off yet. I did this once years ago with a cheap stick full of photos. Bad call. I made the second half of the recovery worse by trying to be fast.
As for software, these are the ones I’d look at first.
- Disk Drill. This is the one I’d try first for a normal deleted-files case. It handles FAT32, exFAT, and NTFS fine, the layout is easy to follow, and the preview feature saves time. If a document or photo opens in preview, I take that as a decent sign the recovery result will be usable. I’ve also seen it do okay when the file system is a bit messed up, not dead, just off.
- PhotoRec. Free, ugly, effective. If the file system is damaged, this one still pulls stuff out more often than people expect. The catch is the mess afterward. File names and folder structure often come back mangled or gone, so you end up sorting a heap of files by hand. Good rescue tool. Not fun.
- Data Rescue. Solid enough from what I’ve seen. I never liked the interface much, felt slower to work through, and less obvious for new users. Still worth trying if your first scan misses things or you want a second pass from a different tool.
- Recuva. Old, Windows-only, still useful for simple recoveries. If you lost normal office docs, PDFs, JPGs, and similar files, it’s still worth a shot. I would not expect as much from it with newer edge-case formats or rougher file system issues.
One thing I would skip at the start is CHKDSK or any repair-first command. Those tools are for fixing file system problems. They are not made for undeleting files. Sometimes they help. Other times they rearrange things enough to make recovery harder. My rule has stayed the same for years, recover first, repair later.
So, plain answer. If the USB still mounts and looks stable, I’d scan it with Disk Drill first, save anything important to another drive, then deal with the USB itself after. If the drive is acting unstable in a physical way, disconnecting, overheating, not showing up right, I would stop the DIY route and hand it off to a recovery lab.
If the USB still shows up with the right size, I’d first check whether the files were turned into hidden or system files. This happens a lot after malware or a bad unplug. Open Command Prompt and run:
attrib -h -r -s /s /d X:*.*
Replace X with your USB letter. I’ve seen this bring whole folders back in 30 seconds. No scan needed.
I slightly disagree with @mikeappsreviewer on one part. I would not spend too long checking random local folders before testing the hidden-files angle, becuase on flash drives this is one of the most common causes when “everything vanished” at once.
Next, look in Disk Management. Make sure the partition still exists and the capacity looks normal. If the drive shows RAW instead of FAT32 or exFAT, don’t format it. At that point use recovery software. Disk Drill is a solid pick for USB file recovery since it handles lost partitions and deleted files in one interface. If Disk Drill finds your photos with preview working, your odds are decent.
One more thing. If this started after plugging the drive into a public PC, scan your computer and the USB for malware before reusing it. Shortcut virus junk is still around, annoyngly.
Also, this video guide on flash drive file recovery is worth a look:
watch this flash drive file recovery video guide
If you post what file system the USB uses, exFAT, FAT32, NTFS, and whether folders are visible but empty, people here can narrow it down fast.
One thing I’d add to what @mikeappsreviewer and @techchizkid said: check the USB on a second computer, and if possible a different OS too. I’ve had flash drives look empty on one Windows machine because of a weird driver/cache issue, then show the files normally on another PC. Sounds dumb, but it can save you a lot of time.
Also, I would avoid “repairing” the USB in Windows if it prompts you. A lot of people click scan/fix out of habit, then wonder why recovery got messier. That prompt is not your freind right now.
If the drive opens but shows empty, pay attention to these signs:
- folders still there but no files inside
- weird shortcuts instead of real folders
- file names changed to gibberish
- capacity looks partly used even though “nothing” is there
If used space is still showing on the drive, that usually means the data may still be physically there. That’s a decent sign.
I slightly disagree with going too deep into free tools first if the files matter a lot. Free stuff is fine for testing, but if you want folder structure, filenames, previews, and less chaos, Disk Drill is usually the easier first shot on a USB stick. Especially for photos and docs. Run the scan, preview what you can, and recover to your internal drive or another external, not back to the same stick obviously.
If the USB starts disconnecting mid-scan, slows to a crawl, or makes the system hang, stop. At that point you’re not really in “normal deleted files” territory anymore.
For extra reading, this thread on best USB flash drive recovery software recommendations is worth skimming too.
Post back with 3 things if you can:
- file system shown for the USB
- whether used space still appears on it
- whether files vanished all at once or after using another PC
That’ll narrow it down prety fast.
