Should I get the iPhone 17 Pro or Pro Max?
I’m trying to decide between the iPhone 17 Pro and iPhone 17 Pro Max after upgrading from an older model. I want the best value for battery life, camera features, size, and everyday use, but I’m not sure which one fits my needs better. I’d really appreciate advice from anyone who has compared both.
If you want best value, get the Pro.
Why:
  1. Same core chip and smooth daily use.
  2. Same main camera system on most Pro tiers, unless Apple keeps one zoom feature exclusive to Max.
  3. Lower price.
  4. Easier one-handed use.
  5. Fits pockets better. This matters more than people admit.
Get the Pro Max if battery life is your top priority. Bigger iPhone almost always wins there, often by a few hours in real use. If you travel a lot, shoot tons of video, or live on 5G all day, the extra size pays off.
My short version:
Pro = best balance.
Pro Max = best battery, bigger screen, more bulk.
If you came from an older model, even the regular Pro will feel like a huge upgrade. Unless you already know you love big phones, I’d save the money and skip the Max. The bigger phone sounds great in the store, then feels annoyng in your pocket by week two.
I’d mostly split it this way:
If you’re asking “which one will make me happiest every single day,” I actually lean Pro Max a bit more than @boswandelaar did. Not because it’s a better “deal,” but because battery life changes the whole experience. A phone that ends the day at 35% just feels less annoying than one limping to bedtime.
That said, the Pro is probably the smarter buy if you care about comfort. It’s easier to hold in bed, easier in jeans pockets, easier for one-handed stuff, and you’ll notice that stuff way more than the keynote features.
Camera-wise, I would not choose based on tiny spec diffs unless there’s a very specific Max-only lens/featureset this year. For normal people, both are gonna be absurdly good.
My lazy rule:
  • Pro if you want balance and value
  • Pro Max if you hate charging and watch a lot of video
If you’re coming from an older iPhone, either one will feel like a massive upgrdae tbh. Personally, I’d only go Max if you already know you like big phones. If big phones annoy you even a littel in stores, that feeling usually gets worse, not better.
Try a physical test at home. Cut cardboard to each phone’s official dimensions, then tape coins on it until the weigth matches. Carry each mock-up in your pocket, use it one-handed, and hold it in bed for 20 minutes.
Pick the largest model that stays comfortable. If the Pro Max feels awkward during this short test, buy the Pro. If both feel fine, choose the Pro Max for longer battery life. This makes the decison clearer than comparing specs.
Nobody’s asked what you actually do with the phone all day. Battery talk means nothing without that.
The cardboard test @novanode220 mentioned is fine for size, but it won’t tell you if you’re a heavy user. If you’re mostly texting and browsing, even the Pro will end the day with plenty left, and the Max’s battery edge becomes a non-issue. The Max only earns its bulk if you’re constantly on video, maps, or gaming.
So figure out your usage first, then decide. Size comfort second, battery third.
