I’ve been experimenting with a few AI image generators for art, marketing visuals, and social media posts, but I’m getting mixed results with quality, realism, and cost. Some tools look great in demos but fall apart on hands, faces, or text once I try them myself. Others are too slow or expensive for regular use. I’m looking for honest recommendations based on your real experience: which AI image generator gives you the best balance of image quality, control over style, speed, and pricing, and why?
Short version. There is no single “best”, but for high quality right now these are the ones worth your time:
- Midjourney v6
• Best for: stylish art, concept pieces, social media visuals.
• Strengths: strong aesthetic, great composition, good lighting, very fast.
• Weak spots: hands and text still glitchy, control is limited, no native inpainting in the web UI.
• Cost: subscription only, no free tier. If you post a lot, the Standard plan is usually enough.
If you do marketing style posts, promo banners, thumbnails, Midjourney often gives the nicest “scroll stopping” images with minimal prompt fuss.
- DALL·E 3 (through ChatGPT or API)
• Best for: prompt accuracy and “understanding” detailed instructions.
• Strengths: very good with scenes that match your description, nice colors, clean look, easy for non‑artists.
• Weak spots: less control over fine details, some outputs feel a bit samey, hands and small text still weird at times.
• Cost: through ChatGPT Plus or via API, you pay per image. Not great if you spam generations, but fine for a few polished images.
If your prompts are long and specific, DALL·E 3 stays closer to what you wrote than most tools.
- Stable Diffusion (especially SDXL)
• Best for: people who want control and do not mind tinkering.
• Strengths: free or cheap once set up, huge community, tons of models and LoRAs, strong realism if you pick good checkpoints. Great for NSFW or niche styles where other tools block you.
• Weak spots: setup takes time, output quality depends a lot on the model and settings, prompt learning curve.
• Cost: software is free, you pay with your GPU or a cloud host.
If you want consistent characters or product mockups, SDXL with ControlNet, reference images, and inpainting gives you the most control. It just takes effort.
- Kandinsky, Ideogram, others
• These are more niche.
• Ideogram is solid for logos and text in images.
• Some smaller tools use SDXL under the hood, so they look fine but do not beat Midjourney or a well tuned local SD setup.
For your use cases:
• Art:
Midjourney v6 first.
If you want deeper control or specific art styles, SDXL with a style LoRA.
• Marketing visuals:
DALL·E 3 for precise layouts and “brand‑safe” look.
Midjourney for hero images or backgrounds.
Ideogram or SDXL for text‑heavy graphics.
• Social media posts:
Midjourney for fast, on‑trend images.
DALL·E 3 if you write detailed story‑like prompts.
SDXL if you want a recurring brand character or mascot.
Quality tips so you stop getting mixed results:
Use reference images
Attach a product shot, logo, or style sample. Tools like SDXL + ControlNet or Midjourney’s “/describe” help a ton. Text prompts alone are hit or miss. -
Prompt structure
Good baseline pattern:
“Photo of [subject], [style or camera type], [lighting], [background], [mood], high detail, 8k, sharp focus”
Then refine from what you see, do not rewrite the whole idea every time. -
Keep a style library
Save prompts that worked. Reuse them with small edits, like swapping “model” for “coffee cup” or “city street” for “office”. -
For cost
• If you generate daily, Midjourney subscription is decent value.
• If you generate a few finals per week, DALL·E 3 through ChatGPT is enough.
• If you bulk‑create assets, local SDXL is cheaper long term.
If you want something plug and play with good quality for most use cases, start with:
• Midjourney for art and social.
• DALL·E 3 for precise marketing scenes.
Then bring in SDXL once you hit their limits and need more control or lower per‑image costs.
Short version: your “mixed results” are not just about which model, it’s about matching the tool to the job and how much control you actually want.
@cacadordeestrelas already covered the big three, so I’ll try not to just echo that.
1. There really isn’t a single “best” (and that’s not a cop‑out)
Right now it’s more like:
- “Best looking with least effort” vs
- “Best control and consistency” vs
- “Best cost at scale.”
If you’re doing art, marketing, and social, you’re basically asking one wrench to be a screwdriver and a hammer too.
2. Where I slightly disagree
They put Midjourney first for art and social. For pure realism and product‑accurate stuff, a well set up SDXL workflow can absolutely beat Midjourney, especially if:
- You need the same product angle 5 times
- You care about exact brand colors
- You want to fix tiny details instead of rerolling forever
Midjourney shines for fast “wow” images, but for repeatable, on‑brand visuals, I’d put SDXL + some control tools over it once you’re past the beginner phase.
Also, DALL·E 3 is not always the king of “following instructions.” It’s great at scene logic and composition, but if you need:
- “This exact logo, this exact font, this exact shirt color”
it starts to feel more like a suggestion than a rule.
3. How I’d match tools to your use cases
1) Art (concept art, pretty stuff, personal pieces)
- Start with: Midjourney if you want fast, pretty pictures from short prompts.
- Upgrade to: SDXL when you want:
- A recurring character
- Specific artist-like styles
- To fix weird details with actual editing
DALL·E 3 is fine for “storybook” and clean vector-ish style, but its aesthetic can get samey, which is annoying if you want a very distinct voice.
2) Marketing visuals (ads, banners, promos)
Different rules here, because marketing people love “can we get the same thing but slightly different?” every other day.
- For one-off hero images:
- Midjourney: good for striking hero shots, backgrounds, aspirational lifestyle scenes.
- For repeatable campaigns:
- SDXL with:
- a base style model
- ControlNet / reference images
- inpainting for small fixes
This gives you: - consistent look across a campaign
- the ability to fix that one wrong hand instead of regenerating the whole banner 12 times.
- SDXL with:
DALL·E 3 is nice if you write “billboard-style ad with text here and product there,” but you hit its limits when you need pixel-level control or strict brand guidelines.
3) Social media posts
Here speed and volume matter:
- Midjourney:
- Great for trendy, fast, aesthetic posts.
- You can churn a week of content in a night.
- DALL·E 3:
- Good for posts with a “story” or joke tied directly to the text.
- SDXL:
- Best when your brand has a character or mascot and you want that same vibe every week.
If you want a recognizable “this is us” visual identity, SDXL + a curated style model wins over the constant style drift you get from Midjourney.
4. Cost vs sanity
Very rough mental model:
- Generate rarely, need polished singles:
- DALL·E 3 via ChatGPT is fine. Pay per image, you do not drown in cost.
- Generate every day, want ease:
- Midjourney sub is ok. You pay for not having to think too hard.
- Generate a ton or need full control:
- Local or cloud SDXL. Higher setup pain, lower long‑term cost.
A lot of people overpay for Midjourney just because they do not want to deal with “technical” stuff, even though a basic SDXL UI is point and click. The barrier is psychological more than real.
5. Why your results probably feel “mixed”
It’s usually a combo of:
- Swapping models constantly instead of learning one deeply for each job.
- Expecting “photoshop-level control” from tools that are built for quick vibes.
- Letting the model pick the style instead of you reusing a stable recipe.
You do not need crazy prompt spells, but you do need a minimal system, like:
- A few “house styles” you reuse
- 1 tool you lean on for quick ideas (Midjourney / DALL·E 3)
- 1 “serious work” tool where you fix stuff (SDXL)
Once you lock those roles in, the whole “which model is best” question becomes a lot less painful and you stop chasing new shiny tools that look great in demos and then crumble when you throw a real brief at them.
I’ll zoom in on what hasn’t been said yet and push back on a couple of points.
1. The “tool per job” idea is right, but you’re probably underestimating workflow friction
@cacadordeestrelas and the other reply are correct that SDXL is a beast for control and consistency, but both gloss over the human cost of switching contexts all day:
- Prompting one way in Midjourney
- Another way in DALL·E 3
- Then juggling SDXL UIs, ControlNet, inpainting, LoRAs, etc.
For a solo creator or small marketing team, that context switching quietly kills throughput. In practice, most people end up really learning just one stack and dabbling in the others. If you want better results, picking one primary and one backup is usually more realistic than three-way specialization.
2. Where I disagree slightly on DALL·E 3
They framed DALL·E 3 as “good but drifty” on precise branding. I think its real edge right now is:
- Structured scenes from natural language like “split-screen before and after ad concept with product right side, empty space for text left side”
- Clean graphic / quasi-vector looks that are ready to drop into a deck
The catch:
- Pros:
- Incredible composition from plain English
- Strong at conceptual / metaphorical marketing visuals
- Cons:
- Inconsistent with exact typography
- Limited control once you like 90% of an image and want to surgically fix 10%
If your marketing work is slide decks, explainer visuals, or social posts that tell a micro story, DALL·E 3 can be a primary, not only a “sometimes” tool.
3. Midjourney is powerful, but not “just vibes”
People oversimplify Midjourney as “wow fast pretty pictures.” Two underused strengths:
- Style lock-in via very consistent seeds and image prompting
- Its internal aesthetic bias, which is a con for niche brands but a pro for “we want modern, aspirational, eye candy without art direction hell”
Yes, hands and micro details are still hit or miss. However, for social feeds where scrolling impact beats pixel perfection, Midjourney’s bias is actually a feature. You trade surgical control for speed and shareability.
4. SDXL: fantastic, but there is a hidden maintenance tax
Everyone talks about SDXL like the endgame. Some reality checks:
Pros:
- True iterative control with inpainting and masking
- Style and character consistency with LoRAs and checkpoints
- Cost efficient at volume or on local hardware
- You are now part-time IT:
- Model updates, broken UIs
- Folder clutter of checkpoints, LoRAs, embeddings
- Creative bottleneck can shift from “model limitations” to “too many knobs”
If you are running a serious campaign or a brand that lives on consistent imagery, the headache is worth it. If you are just posting fun Reels and rotating ad creatives casually, the overhead is real.
5. A practical division of labor that minimizes pain
Instead of “this tool for art, this for marketing, this for social,” think:
Primary ideation model
Use: fast drafts, exploring directions, getting 10 options quickly
Often: Midjourney or DALL·E 3 -
Refinement / production model
Use: final marketing visuals, campaigns, recurring characters
Often: SDXL with some editing stack -
Emergency fixer
When a brief really needs super literal text comprehension, run it through DALL·E 3 even if it is not your main tool.
That way, you are not learning three tools “fully.” You have one brain-mode for “sketching” and one for “finishing.”
6. About “” as a product angle
Since you mentioned tools in general, something like “” (if we treat it as a unified workflow layer rather than yet another raw model) can actually matter more than which base model you pick.
Pros:
- If it centralizes prompts, versions, and brand templates, you stop losing time to file chaos
- A single place to store “house styles,” seed recipes, or campaign presets
- Could act as a front door over SDXL / Midjourney / DALL·E 3 so non-technical teammates do not have to learn three different UIs
- One more subscription or tool to adopt
- If it hides too much control, you are stuck when you need low-level tweaks
- Risk of vendor lock-in if it uses a narrow set of models
In other words, your “best AI” right now might be less about the model name and more about a sane wrapper like “” that standardizes how you and your team actually work with images across campaigns.
7. Where I align / differ from @cacadordeestrelas
They are absolutely right that SDXL is underrated for realism and repeatability. Where I diverge a bit:
- I would not push beginners into SDXL-first unless they are comfortable messing with tools and settings.
- For many marketing + social workflows, Midjourney or DALL·E 3 as a primary, plus SDXL as a “fixer and continuity engine,” reduces friction.
If your results feel mixed, the biggest gain usually comes from:
- Committing to one main tool for 80% of your output
- Documenting 3 to 5 reusable “recipes” or styles
- Using a wrapper like “” or similar to keep everything consistent instead of hopping between completely separate silos
Once your workflow stabilizes, choosing between Midjourney, DALL·E 3, or SDXL becomes less existential and more like: “Which engine do I plug into this same pipeline for this type of job?”
