What’s the best WiFi extender for fixing weak signal spots?
I’m struggling with weak WiFi in a couple of rooms at home, especially for streaming and video calls. My current router doesn’t cover the whole house, and moving it isn’t an option. I’m looking for recommendations on the best WiFi extender that’s reliable, easy to set up, and actually improves speed and stability, not just signal bars. Any real-world suggestions or brands/models that have worked well for you?
If your router is stuck where it is and you only have a couple of weak rooms, start with this plan:
  1. Check your house layout first
    • If the bad rooms are on the other side of thick walls, chimneys, or metal stuff, a basic plug-in extender often struggles.
    • If they are one floor up or down, you want an extender or mesh node placed halfway, not in the weak room.
  2. Use a WiFi heatmap to see dead spots
    This sounds nerdy but it helps a lot.
    Install something like NetSpot on a laptop. Walk around the house and record signal.
    You get a clear map of where your signal drops.
    Here is a good starting point for that: visual WiFi planning with NetSpot.
    That makes it easier to know where to plug the extender so you feed it a strong signal.
  3. If you want the simplest plug-in extender
    • TP-Link RE315 or RE605X
    They are cheap, support WiFi 5 or WiFi 6, and work fine if you place them in a spot where your phone still shows at least 2–3 bars from the main router.
    Use the same SSID and password as your main WiFi so your devices switch more cleanly.
  4. If you stream a lot or do many video calls
    A mesh kit usually beats a random repeater.
    • TP-Link Deco X20 or X55
    • Eero 6 or Eero 6+
    Put one node near the existing router, then a second node halfway toward the weak rooms.
    These use a smarter backhaul and handle roaming better, so your calls drop less when you walk around.
  5. If you have Ethernet in the walls or can run one cable
    Skip normal extenders.
    Get a cheap WiFi access point and plug it into Ethernet in or near the bad room.
    Something like a TP-Link EAP615 or Ubiquiti U6 Lite.
    Set the same SSID and password as your main WiFi.
    That gives you much more stable streaming than a repeater.
  6. Quick config tips
    • Use 5 GHz for streaming and calls if the room is not too far.
    • Use 2.4 GHz only for long range, smart plugs, etc.
    • Turn off “Smart Connect” on some routers if devices keep sticking to the weak signal.
    • On extenders, pick a different WiFi name only while you test. Once it works well, switch it back to match your main WiFi if you want seamless roaming.
If you want the easiest upgrade path and do not want to overthink it
• Small house or apartment, 1–2 bad rooms: TP-Link RE605X.
• Bigger place or many users: a 2- or 3-pack mesh like Deco X20 or Eero 6, placed using data from NetSpot so you do not guess on locations.
Do the NetSpot map once, place the extender or mesh node in a “yellow/green” zone on the map, not in a red dead spot, and your streaming in those rooms should stop being a pain.
If your router can’t move, the “best” WiFi extender depends on how much pain you’re willing to tolerate long‑term, not just which box has the biggest “AC/AX” number on it.
Quick answer:
  • One or two weak rooms, don’t want mesh:
    • TP‑Link RE605X or RE700X
  • Want it to “just work” for streaming and Zoom:
    • Forget pure extenders, grab a 2‑pack of TP‑Link Deco X20 or Eero 6
  • Have (or can run) one Ethernet cable:
    • A cheap WiFi 6 access point beats any repeater
@himmelsjager already laid out a solid process with heatmaps and placements. I’ll push back on one thing though: basic plug‑in extenders are often a bandaid. They work, but once you start moving around the house doing calls, you’ll notice handoff and random lag a lot more than with mesh or wired APs.
1. When a plain extender actually makes sense
Use a single plug‑in extender if all of these are true:
  • You only care about 1–2 rooms.
  • You mostly sit still (TV, work desk, console).
  • You are OK with “good enough” and occasional weirdness.
In that case, I’d look at:
  • TP‑Link RE605X
    • WiFi 6, solid for 4K streaming and calls.
    • Ethernet port, so you can wire a TV or PC into it.
    • Pretty easy app setup.
  • TP‑Link RE700X
    • Similar to RE605X but a little more headroom and slightly better radios.
    • Worth it if the price difference is small.
I’d avoid the super‑cheap extenders that top out at 2.4 GHz or have “300 Mbps” on the box. They’ll technically fix the signal bars and still leave you hating life on Zoom.
Also, I don’t love cloning the same SSID on basic extenders right away. Contrary to what @himmelsjager suggested, I prefer:
  1. Give the extender a different name at first, like MyWiFi_EXT.
  2. Test throughput and stability in your bad rooms.
  3. If it’s good, then decide if you want to match SSIDs.
That way, you know for sure when your device is on the extender vs main router instead of guessing.
2. Why mesh is usually the “best” for streaming and video calls
If you walk around on calls or have multiple people streaming, a mesh system almost always beats a lone extender:
  • Roaming is smoother, so your calls don’t freeze when you move.
  • Nodes coordinate channels and power better.
  • Backhaul is usually smarter than a random repeater link.
Good options:
  • TP‑Link Deco X20 or X55
    • Great price/performance.
    • X55 is a bit faster and better for higher‑speed internet.
    • Two‑pack usually covers most average homes if placed halfway toward the weak rooms.
  • Eero 6 / Eero 6+
    • Super simple to manage.
    • Better if you are less into tweaking settings and just want it stable.
If your house is medium‑large and you rely on Zoom / Teams / FaceTime, I’d actually put “mesh kit” ahead of “single extender” on the list of “best WiFi extender” solutions, even though it’s technically a different category.
3. If you can run even a single Ethernet cable
This is the part people ignore and then regret later.
If you can pull one Ethernet cable near the weak rooms, skip repeaters and do:
  • UniFi U6 Lite or TP‑Link EAP615
  • Mount on the ceiling or high on a wall if possible.
  • Same SSID and password as your main WiFi.
That gives you a rock‑solid link to the router with no wireless hop in the middle. Streaming and calls will feel way closer to being next to the main router.
4. Finding the best spot without guessing
Here I actually agree with @himmelsjager: guessing extender placement is how you end up with full bars and terrible speed.
Use NetSpot to map the WiFi and see exactly where the signal crashes. It’s a simple laptop app that lets you walk around and log signal strength, so you can put the extender or mesh node in a strong zone instead of parking it in the dead room and feeding it garbage.
For a clean walkthrough on how to do that and get a visual map, check out this handy WiFi optimization guide. It makes picking locations way less random.
5. Concrete picks based on your situation
Since you said:
  • Weak WiFi in “a couple of rooms”
  • Heavy streaming and video calls
  • Router location can’t move
I’d rank your choices like this:
  1. Best overall experience:
    • 2‑pack Deco X20 or Eero 6
    • Use NetSpot once, put the second node in a spot that still has “good” signal from the main router.
  2. Cheaper, but okay with some quirks:
    • RE605X or RE700X in a hallway or room between router and bad rooms
    • Test it with a separate SSID first.
  3. Best if you can run a cable now or later:
    • Single WiFi 6 access point like TP‑Link EAP615 on Ethernet
    • Treat it like a second main router broadcasting the same WiFi name.
If you just want a name to type into a store search today, for a straight “extender” product that doesn’t suck: TP‑Link RE605X is an easy recommendation. But if you don’t want to revisit this whole mess in a year, mesh plus a quick NetSpot survey is the more future‑proof path.
